1 Reply Latest reply on Sep 21, 2010 12:18 PM by tochie007
    Uploading XML Packets to Server Side Script(PHP) from AIR (HTML)
    tochie007
      Hello folks,
      I have a need to send xml packet from my Air app to a remote server. I have searched the net for days without finding any solution to this, so this is my last resort. I did find an example on the example on Adobe help page but I couldn't get it to work for me. I'll just post the scripts below.
      ***This is the script from Adobe help
      var secondsUTC = new Date().time;
      var dataXML = "<login>"
                          + "<time>" + secondsUTC + "</time>"
                          + "<username>Ernie</username>"
                          + "<password>guru</password>"
                      + "</login>";
      var request = new air.URLRequest("http://www.mysite.com/xml.php");
      request.contentType = "text/xml";
      request.data = dataXML;
      request.method = air.URLRequestMethod.POST;
      var loader = new air.URLLoader();
      ***I added listeners to tell me whats going on on the server
      loader.addEventListener(air.Event.COMPLETE, completeHandler);
      try
           loader.load(request);
      catch (error)
           air.trace("Unable to load URL");
      function completeHandler(event)
           air.trace(event.target.data);
      ***On my php script, I simply (for now) wanted to check if my script was seeing any data from AIR
      <?php
           echo $_REQUEST["dataXML"];
      ******** The RESULT *********
      I keep getting an error message saying the variable "dataXML" was unknown or undefined. Where am I missing it? The script in AIR or the PHP script?
      Pls someone help me out! Thanks
        • 1. Re: Uploading XML Packets to Server Side Script(PHP) from AIR (HTML)
          tochie007 Level 1
          I discovered my mistake. In my php script I was trying to read the XML packet like I would read the normal POST date "name=value". This little code below has brought an end to my search. Hope it helps someone someday!
          ***This reads the XML Packet sent from AIR to PHP.
          $postText = trim(file_get_contents('php://input'));
          *** from here you can use PHP to play with the XML Packet which is contained in "$postText";
