2 Replies Latest reply on Sep 22, 2010 4:14 AM by MazAwushu
    Detect peer diconnection
    MazAwushu Level 1
      Hello,
      I'm trying to make one peer application detect when another connected peer disconnets (for example just closes the browser window).
      I tried adding NetStatusEvent.NET_STATUS to all the opened NetStreams and I also tried adding the onPeerDisconnect handlers to NetStream clients. None of them fire when peer disconnects.
      However, onPeerConnect works perfectly fine for me.
      Any ideas?
      Thanks!
        • 1. Re: Detect peer diconnection
          AdamLane
          I think that when a peer connection closes, you will see a NetStream.Connect.Closed status
          event on the NetConnection.  So, install an NetEvent handler on the NetConnection and look for NetStream.Connect.Closed events.
          That particular event will have a property called "stream" which indicates which NetStream closed.
          • 2. Re: Detect peer diconnection
            MazAwushu Level 1
            Thanks a lot, it works perfectly fine now.
            Just to make it totaly clear, for anyone having the same problem:
            - you have to add the NetStatusEvent.NET_STATUS to the NetConnection object, and NOT to the NetStream object.
            Cheers!
