0 Replies Latest reply on Sep 21, 2010 5:46 AM by opalcom
    ClearType use prevents install, and interferes with use of CF Builder
    opalcom
      This is a strange situation.  On my Windows 2003 Server development machine, running Java Version 6 Update 21, there appears to be a conflict between some aspect of Java and ClearType.  The InstallAnywhere would crash with no message (and no indication in the install log of why it stopped).  As soon as I changed the Windows 2003 from using ClearType to Standard font smoothing, the installation worked.
      Then I went back to ClearType use.  When I run ColdFusion Builder, a lot of it works, but the File tab displays the error below instead of a list of files. The File tab works if I change to Standard smoothing instead of ClearType).  Any ideas?  Here is the error message inside CF Builder:
      Could not create the view: An unexpected exception was thrown.
      java.lang.IllegalArgumentException: -53687091 incompatible with Text-specific LCD contrast key
          at java.awt.RenderingHints.put(RenderingHints.java:1057)
          at sun.awt.windows.WDesktopProperties.getDesktopAAHints(WDesktopProperties.java:293)
          at sun.awt.windows.WToolkit.getDesktopAAHints(WToolkit.java:911)
          at sun.awt.SunToolkit.getDesktopFontHints(SunToolkit.java:1858)
          at sun.awt.windows.WDesktopProperties.getProperties(WDesktopProperties.java:230)
          at sun.awt.windows.WToolkit.updateProperties(WToolkit.java:868)
          at sun.awt.windows.WToolkit.lazilyInitWProps(WToolkit.java:820)
          at sun.awt.windows.WToolkit.lazilyLoadDesktopProperty(WToolkit.java:809)
          at java.awt.Toolkit.getDesktopProperty(Toolkit.java:1746)
          at javax.swing.UIManager.<clinit>(UIManager.java:357)
          at javax.swing.filechooser.FileSystemView.getFileSystemView(FileSystemView.java:63)
          at com.aptana.ide.core.ui.io.file.LocalFile.<clinit>(LocalFile.java:68)
          at com.aptana.ide.core.ui.io.file.LocalFileManager.getBaseFile(LocalFileManager.java:141)
          at com.aptana.ide.core.ui.views.fileexplorer.FileExplorerView.getVirtualRoots(FileExplorerVi ew.java:1678)
          at com.aptana.ide.core.ui.views.fileexplorer.FileExplorerView.createViewer(FileExplorerView. java:951)
          at com.aptana.ide.core.ui.views.fileexplorer.FileExplorerView.createPartControl(FileExplorer View.java:736)
          at org.eclipse.ui.internal.ViewReference.createPartHelper(ViewReference.java:367)
          at org.eclipse.ui.internal.ViewReference.createPart(ViewReference.java:226)
          at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
          at org.eclipse.ui.internal.WorkbenchPage$ActivationList.setActive(WorkbenchPage.java:4212)
          at org.eclipse.ui.internal.WorkbenchPage$18.runWithException(WorkbenchPage.java:3271)
          at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
          at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
          at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
          at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3855)
          at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3476)
          at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
          at org.eclipse.ui.internal.Workbench$28.runWithException(Workbench.java:1384)
          at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2316)
          at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
          at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
          at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
          at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
          at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
          at com.adobe.ide.coldfusion.rcp.intro.Application.start(Unknown Source)
          at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:110)
          at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:79)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
          at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
          at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
          at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
          at java.lang.reflect.Method.invoke(Method.java:597)
          at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
          at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
          at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
