7 Replies Latest reply on Sep 21, 2010 12:28 PM by Flex harUI
    Referencing Flex stage through Flex Component made in Flash
    wilsonsilva7 Level 1
      Hello. I'm developing a Flex Component in Flash CS4, named Navigator. The Navigator is just a slider (I will use the slider to zoom onto something). It consists of a MovieClip with a child MovieClip named "magnifier" which is the slider handle. Here's the Navigator class:
      package {
      import flash.display.MovieClip;
          i
      mport flash.events.Event;
          import flash.events.MouseEvent;
          import flash.geom.Rectangle;
          import mx.flash.
      UIMovieClip;
      public class Navigator extends UIMovieClip {
      private var _dragging:Boolean;
      private var _zoom:Number;
      public  var _bounds:Rectangle;
              public function Navigator() {
                  _dragging = false;
                  _bounds = new Rectangle(68,22.5,100,0);
                  _zoom = 0;
                  this.magnifier.buttonMode = true;
                  this.magnifier.addEventListener(MouseEvent.MOUSE_DOWN, startDragging);
      stage.addEventListener(MouseEvent.MOUSE_UP, stopDragging);
             private function startDragging(event:Event):void {
                  this.magnifier.startDrag(false,_bounds);
                  _dragging = true;
              private function stopDragging(event:Event):void {
                  if (_dragging == true) {
                      this.magnifier.stopDrag();
                      _dragging = false;
                      _zoom =((magnifier.x-68)*100)/(168-68);
                      dispatchEvent(new Event("zoomChanged"));
              public function get zoom():Number {
                  return _zoom;
      This code works on Flash but in Flex I keep gettin this error "TypeError: Error #1009: Cannot access a property or method of a null object reference."- on that red line. Probably because it is referencing the Flex's stage and not Flash's stage. This is my Flex MXML Component:
      <mx:Canvas xmlns:mx="http://www.adobe.com/2006/mxml" width="220" height="64" creationComplete="init()">
          <mx:Script>
              <![CDATA[
                 import mx.core.UIComponent;
      private var ui:UIComponent = new UIComponent();
      private var navigator:Navigator = new Navigator();
      public function init():void {
                      navigator.addEventListener("zoomChanged", onZoom);
                      ui.addChild(navigator);
                     this.addChild(ui);
      public function onZoom(event:Event):void {
                      trace(navigator.zoom);
          </mx:Script>
      </mx:Canvas>
        • 1. Re: Referencing Flex stage through Flex Component made in Flash
          God! I spen't a lot of time coloring the code for nothing The "red line" I'm talking about is this line:
          • 2. Re: Referencing Flex stage through Flex Component made in Flash
            Maybe a stage reference is not what I really need. I just need some container to add the MOUSE_UP event listener. I'm just trying to make a simple slider .__.
            • 3. Re: Referencing Flex stage through Flex Component made in Flash
              Flex harUI Adobe Employee
              Flex apps are initialized off-stage.  I think you can access the stage via
              systemManager.stage, but it is better to add the mouseup listener in your
              mouseDown handler.
              • 4. Re: Referencing Flex stage through Flex Component made in Flash
                thanks for your answer. I've already tried to use the SystemManager. I tried to "import mx.managers.SystemManager;" but I keep getting this error: 1172: Definition mx.managers:SystemManager could not be found. I think it is only available in Flex, not in Flash.
                     _dragging = true;
                Here's my problem, visually:
                • 5. Re: Referencing Flex stage through Flex Component made in Flash
                  Then I would definitely recommend changing to add the mouseUp listener in
                  the mouseDown handler.
                  • 6. Re: Referencing Flex stage through Flex Component made in Flash
                    Do you mean instead of having this:
                                _dragging = false;
                                _zoom = 0;
                                this.plus_btn.addEventListener(MouseEvent.CLICK, increaseZoom);
                                this.minus_btn.addEventListener(MouseEvent.CLICK, decreaseZoom);
                                _dragging = true;
                    Have this?:
                                _dragging = false;
                                _zoom = 0;
                                _dragging = true;
                    If so, I would still have the same problem. The Flash's stage object doesn't exist in Flex.
                    • 7. Re: Referencing Flex stage through Flex Component made in Flash
                      The stage object is the same for Flash and Flex.  It just isn't available in
                      Flex until after APPLICATION_COMPLETE or ADDED_TO_STAGE.  And in general, it
                      is better not to add listeners like MOUSE_UP until needed.
