6 Replies Latest reply on Jul 27, 2007 6:45 AM by Newsgroup_User
    FW CS3 - problem with exporting states of object.
    Level 7
      Hi!
      Here is the file illustrating the problem
      http://fireworks.eu.interia.pl/test.png
      Could anybody recreate this file using frames and/or pages under FW CS3 to
      avoid exporting many unneeded files? My intention is to get only one file
      containing panel body and 5 files with panel titles. I tried to move each
      panel title to separate page and leave panel body on master page and then
      export manually each page by page. Unfortunatelly FW doesn't allow to use
      page slices which overlaps between pages. I gave up!
      Marek
        • 1. Re: FW CS3 - problem with exporting states of object.
          Level 7
          Marek wrote:
          > Hi!
          > Marek
          Move your frames to pages
          Remove panelbody slice from all pages except page 1
          rename title slice on each page so it has a different file name
          File > Export
          make sure Include Areas Without Slices and Current page only are UNCHECKED
          Worked like a charm.
          Jim Babbage - .:Community MX:. & .:Adobe Community Expert:.
          Extending Knowledge, Daily
          http://www.communityMX.com/
          CommunityMX - Free Resources:
          http://www.communitymx.com/free.cfm
          .:Adobe Community Expert for Fireworks:.
          news://forums.macromedia.com/macromedia.fireworks
          news://forums.macromedia.com/macromedia.dreamweaver
          • 2. Re: FW CS3 - problem with exporting states of object.
            Level 7
            Hi Jim again,
            > File > Export
            Please visit http://fireworks.eu.interia.pl/test2.png
            The export creates 2 files even if slices in page 2 and 3 have different
            names. Moreover I can't even export selected slice on those pages.... Always
            I'm getting exported slice from master page instead of current page.
            • 3. Re: FW CS3 - problem with exporting states of object.
              Level 7
              Marek wrote:
              > Hi Jim again,
              >> File > Export
              I have a better idea; here's the link to your original png that I
              modified:
              http://www.newmediservices.ca/jim_babbage/test.png
              • 4. Re: FW CS3 - problem with exporting states of object.
                Level 7
                Hi Jim,
                > modified:
                Small spelling was in delivered URL but I have guessed proper version. I can
                see the difference between my and yours ideas. You have created copy of
                project between pages which is usually inconvenient. I did another
                modification: common graphics is placed on master page but all changable
                elements as panel titles are moved to other pages. It was necessary to
                delete slice "pageTitle" from master page because otherwise overlapped
                slices on other pages was not exported. Conclusion is to avoid keeping the
                first state of changable element on master page. The first state (and its
                slice in consequence) must be created on second and next pages.
                Now it works fine however FW asks a lot of times whether I want to overwrite
                files or not. Always must exists any "but" :-)))
                Thanks a lot Jim for your help!
                • 5. Re: FW CS3 - problem with exporting states of object.
                  Level 7
                  Marek wrote:
                  > Hi Jim,
                  >> modified:
                  oops I left out an a in the url. sorry about that!
                  • 6. Re: FW CS3 - problem with exporting states of object.
                    Level 7
                    Marek wrote:
                    > Hi Jim,
                    >> modified:
                    I'd like to see your PNG if you're willing to share it. Chances are
                    you're getting that overwriting slice prompt because your pagebody slice
                    is on the master page.
                    Master pages may not be what you need in this case, because slices are
                    shared across all pages unless you intentionally break the link between
                    the Master and sub pages.
