3 Replies Latest reply on Sep 23, 2010 8:36 AM by Bob Stucky
    Keypress event
    DavideBarranca Level 1
      Hello,
      I'm having troubles trying to catch a key-press, I can't understand what's going wrong...
      My extension has a button that opens a NativeWindow component:
      private var newWindow:myNativeWindow;
      public function buttonClick():void
      newWindow = new myNativeWindow();
      newWindow.open();
      newWindow.addEventListener(KeyboardEvent.KEY_UP, myFunction)
      Well, it doesn't work, myFunction is never called (I'd like to intercept ESC and return, but for testing any keypress is ok)
      I've tried to write the event listener inside the Window component in a creationComplete function, with no luck.
      I'm surely missing something, but I can't figure out what.
      Thanks for your help,
      Davide
        • 1. Re: Keypress event
          Bob Stucky Adobe Employee
          Hi Davide
          What does myNativeWindow (the class file) look like?
          Bob
          • 2. Re: Keypress event
            Hello Bob,
            here it is (still under construction, but the scheme is this one):
            <mx:Window xmlns:mx="http://www.adobe.com/2006/mxml"
               layout="absolute"
               width="300"
               height="200"
               resizable="false"
               systemChrome = "standard"
               type = "utility"
               transparent="false" title="WARNING!"
              creationComplete="window1_creationCompleteHandler(event)" >
            <mx:Script>
            <![CDATA[
            import mx.events.FlexEvent;
            import mx.core.Window;
            protected function window1_creationCompleteHandler(event:FlexEvent):void
            addEventListener(KeyboardEvent.KEY_UP, chiudi)
            private function chiudi(event:KeyboardEvent):void
            this.close();
            </mx:Script>
            <mx:Button x="26" y="141" label="STOP"/>
            <mx:Button x="163" y="141" label="GO" click="chiudi"/>
            <mx:Label x="57" y="68" text="There's no active selection!" height="22" width="161"/>
            <mx:Label x="92" y="98" text="Continue anyway?"/>
            <mx:Label x="133" y="42" text="WARNING"/>
            </mx:Window>
            • 3. Re: Keypress event
              Hi Davide,
              A personal preference is to include they key handler in the mx:Window tag:
              <mx:Window keyDown="myKeyHandler( event )"....>
              Adding an event listener does the same thing, though.
              Here's the keyHandler that worked for me:
                          private function keyHandler( event: KeyboardEvent ): void
                              trace( "Keypressed: " + String.fromCharCode( event.charCode ) );
                              if ( event.keyCode == Keyboard.ESCAPE ) {
                                  trace( "Escape Pressed!" );
                                  dispatchEvent( new Event(ESCAPE_KEY_DOWN) );
                          private function onCreationComplete(): void
                              addEventListener( ESCAPE_KEY_DOWN, chiudi );
                          private function chiudi( event: Event = null ):void
                          {  trace( "closing" );
                              this.close();
              One thing to note is that to get key presses, the window has to be open, active, with some control somewhere in the window selected/active. I was a little surprised that I never received a key down event for an escape key unless the window type was set to CSXSWindowType.MODAL_DIALOG.
              Bob
