6 Replies Latest reply on Sep 23, 2010 11:15 PM by Thorsten Kummer
    TLF in Flex 4: Textflowcomposer returns wrong number of lines
    Thorsten Kummer
      the TextFlowComposer returns a value for myTextArea.textFlow.flowComposer.numLines. It depends on the height of the control although there's much more text in it after an import of text. What's wrong here?
      best regards
      thorsten
      Sample code
      var myTextFlow:TextFlow
      this.myTextArea.text=TextConverter.export(this.anotherTextArea.textFlow,TextConverter.PLAIN_TEXT_FORMAT,ConversionType.STRING_TYPE).toSt ring();
      var nLines:uint = exportResult.textFlow.flowComposer.numLines
      Alert.show(nLines.toString());
        • 1. Re: TLF in Flex 4: Textflowcomposer returns wrong number of lines
          Thorsten Kummer Level 1
          Just an addition:
          When I code the Alert.show of NumLines in a buttonclick event and trigger that from my procedure after the import, it gives me a 9 which is wrong.
          The next time I call my proc it gives me 10 which is wrong too. When I scroll down the textArea and re-import the text it gives me 13 which is correct.
          Something's wrong here, isn't it?
          th
          • 2. Re: TLF in Flex 4: Textflowcomposer returns wrong number of lines
            Hi, does nobody have an idea?
            I'm totally frustrated...
            Regards
            th
            • 3. Re: TLF in Flex 4: Textflowcomposer returns wrong number of lines
              Flex harUI Adobe Employee
              What is exportResult?
              • 4. Re: TLF in Flex 4: Textflowcomposer returns wrong number of lines
                Oh sorry, bad code snippet...
                exportresult is a textarea
                Here's a full test app:
                   xmlns:mx="library://ns.adobe.com/flex/mx" viewSourceURL="srcview/index.html">
                <fx:Script>
                <![CDATA[
                import flashx.textLayout.conversion.ConversionType;
                import flashx.textLayout.conversion.TextConverter;
                import flashx.textLayout.elements.TextFlow;
                import mx.controls.Alert;
                import mx.events.FlexEvent;
                import spark.utils.TextFlowUtil;
                [Bindable]private var myTextFlow:TextFlow;
                [Bindable]private var myTextXML:XML;
                private var myText:String
                private var firstLine:String
                private var nLines:uint
                protected function source_creationCompleteHandler(e:FlexEvent):void
                source.text = "Lorem ipsum dolor sit amet, consetetur sadipscing elitr, sed diam nonumy eirmod tempor invidunt ut labore et dolore magna aliquyam erat, sed diam voluptua. At vero eos et accusam et justo duo dolores et ea rebum. Stet clita kasd gubergren, no sea takimata sanctus est Lorem ipsum dolor sit amet. Lorem ipsum dolor sit amet, consetetur sadipscing elitr, sed diam nonumy eirmod tempor invidunt ut labore et dolore magna aliquyam erat, sed diam voluptua. At vero eos et accusam et justo duo dolores et ea rebum. Stet clita kasd gubergren, no sea takimata sanctus est Lorem ipsum dolor sit amet.Lorem ipsum dolor sit amet, consetetur sadipscing elitr, sed diam nonumy eirmod tempor invidunt ut labore et dolore magna aliquyam erat, sed diam voluptua. At vero eos et accusam et justo duo dolores et ea rebum. Stet clita kasd gubergren, no sea takimata sanctus est Lorem ipsum dolor sit amet. Lorem ipsum dolor sit amet, consetetur sadipscing elitr, sed diam nonumy eirmod tempor invidunt ut labore et dolore magna aliquyam erat, sed diam voluptua. At vero eos et accusam et justo duo dolores et ea rebum. Stet clita kasd gubergren, no sea takimata sanctus est Lorem ipsum dolor sit amet."
                private function onComplete(e:Event):void
                myTextFlow=TextConverter.importToFlow(e.target.data, TextConverter.PLAIN_TEXT_FORMAT);
                protected function button_clickHandler(e:MouseEvent):void
                switch (e.target.label)
                case "1. Export as TLF":
                this.exportResult.text=TextConverter.export(this.source.textFlow, TextConverter.PLAIN_TEXT_FORMAT, ConversionType.STRING_TYPE).toString();
                var event:MouseEvent
                msg_clickHandler(event)
                break;
                protected function msg_clickHandler(event:MouseEvent):void
                exportResult.textFlow.invalidateAllFormats()
                nLines = exportResult.textFlow.flowComposer.numLines
                </fx:Script>
                <s:BorderContainer width="466" height="411">
                <s:RichText id="source"
                width="350"
                textFlow="{myTextFlow}"
                creationComplete="source_creationCompleteHandler(event)"
                paddingLeft="5"
                paddingRight="5"
                paddingTop="5" enabled="true" height="74" x="35" y="178"/>
                <s:TextArea width="281"
                paddingTop="20"
                id="exportResult" height="123" x="66" y="37"/>
                <s:Button label="1. Export as TLF"
                  click="button_clickHandler(event)" x="37" y="265"/>
                <s:Button x="42" y="303" label="2. Count Lines" id="msg" click="msg_clickHandler(event)"/>
                </s:BorderContainer>
                </s:Application>
                • 5. Re: TLF in Flex 4: Textflowcomposer returns wrong number of lines
                  IFlowComposer.numlines is documented as the number of lines composed, not
                  the total number of lines that the textflow would represent if the entire
                  thing was composed.
                  • 6. Re: TLF in Flex 4: Textflowcomposer returns wrong number of lines
                    I did the following additionally:
                    theTextArea.textFlow.flowComposer.composeToPosition()
                    theTextArea.textFlow.flowComposer.updateAllControllers()
                    After that everythings seems to be as espected.
                    Thank you so much!
                    th
