1. Re: AS3 content not showing up in Flash CS4
kglad Sep 21, 2010 1:11 PM (in response to T_Townrampage)take a screenshot of your main timeline (at least its left side if it's too long to be included in its entirety) and your stage and attach to this forum.
2. Re: AS3 content not showing up in Flash CS4
T_Townrampage Sep 21, 2010 2:19 PM (in response to kglad) -
3. Re: AS3 content not showing up in Flash CS4
kglad Sep 21, 2010 2:44 PM (in response to T_Townrampage)upload your fla to a server and post a link. i'll check it.
4. Re: AS3 content not showing up in Flash CS4
T_Townrampage Sep 21, 2010 3:32 PM (in response to kglad)Here is a link to the fla.
On the stage I drew a few squares and some squiggly lines, although I cant see any of it unless I test movie.
http://www.foresthillstudios.com/no_content.fla
Thanks for you help.
5. Re: AS3 content not showing up in Flash CS4
kglad Sep 21, 2010 3:58 PM (in response to T_Townrampage)i see the on-stage objects without problem.
try saving your fla to a new directory with a new name. then close your cs4, right click on your fla in the new directory and click open with... cs4.
6. Re: AS3 content not showing up in Flash CS4
T_Townrampage Sep 21, 2010 5:58 PM (in response to kglad)No luck.
Do you think I should reinstall?
7. Re: AS3 content not showing up in Flash CS4
kglad Sep 21, 2010 10:04 PM (in response to T_Townrampage)do you have the same problem with every fla you create?
8. Re: AS3 content not showing up in Flash CS4
T_Townrampage Sep 23, 2010 7:15 PM (in response to kglad)Hey Kglad, it only bugs on me when I create an as3 file. All as2 files work fine.
Ive tried doing some research but I cant find any info on this.
9. Re: AS3 content not showing up in Flash CS4
kglad Sep 23, 2010 9:10 PM (in response to T_Townrampage)that is strange and something i know nothing about.
see if you can get jan dehaan's attention for this thread. she may know something about this.
10. Re: AS3 content not showing up in Flash CS4
mr Rotzer Apr 5, 2011 1:49 AM (in response to T_Townrampage)Hi. Bumping this post as I have exactly the same problem.
I have been developing in AS2 for a while, when going back to AS3 I have the same problem. All graphics, bitmaps any visual output is gone, I can still compile and the compiled result works well.
Have tried to delete all the preferences ( http://kb2.adobe.com/cps/520/cpsid_52048.html ), basically everything short of a full reinstall.
Has anyone seen a fix on this issue?
Anyways, I'm six months late so... well. Anyway.
B
11. Re: AS3 content not showing up in Flash CS4
T_Townrampage May 24, 2011 3:44 AM (in response to mr Rotzer)El Borodei,
I had to do a full reinstall. I couldnt find any info to help fix this super wierd problem.
But since I did a reinstall it works just fine.
12. Re: AS3 content not showing up in Flash CS4
m.althoff Sep 19, 2011 8:43 PM (in response to T_Townrampage)I do have exactly the same problem but reinstall does not help. Additionally flash crashes after a while. Is there any other solution to this? This problem came out of the sudden, no content in as3 mode, no objects in the library. Publishing works. I have removed preferences, disabled all fonts and changed video card drivers...please help
