5 Replies Latest reply on Jul 30, 2007 4:58 PM by kglad
    checkbox embed fonts ?
    phil1943 Level 1
      Hello, are there any inherent problems or issues with embedding fonts used within checkbox components ?
      I have tried many times, but cant get it to work.
      thanks for any tips.
        • 1. Re: checkbox embed fonts ?
          what problem are you having and what are you trying to do?
          • 2. Re: checkbox embed fonts ?
            phil1943 Level 1
            thanks for helping.
            I am trying to embed the font used in my checkbox components.
            The reason is so that I can manipulate it's alpha values (fade-in effect) when that SWF is loaded by another SWF.
            I have added this code to my SWF checkboxes
            _global.styles.CheckBox.setStyle("fontFamily", "Arno Pro");
            _global.styles.CheckBox.setStyle("embedFonts", "true");
            I have created a font symbol for Arno Pro.
            That symbol has been clicked as "Export for runtime sharing".
            A URL has been provided to the resultant SWF.
            however... when I load that SWF into another swf, the checkbox text "Arno Pro" still cannot be alpha manipulated. (I have tried other fonts, but to no avail.)
            Any ideas would be appreciated.
            • 3. Re: checkbox embed fonts ?
              once you have your external swf working correctly you'll need to check shared library assets so you main swf can access those embedded fonts.
              • 4. Re: checkbox embed fonts ?
                phil1943 Level 1
                thanks, my host SWF does not want to directly use the imported SWF's font symbol. It simply wants to control the alpha value of them.
                In that case, does my host SWF still need to access the embedded fonts ?
                You mention I need to "check shared library assets ". Where exactly do I "check" shared library assets ?
                thanks kindly.
                • 5. Re: checkbox embed fonts ?
                  your embedded font won't work unless the _level0 swf has access to that font.
                  check the flash help files for "shared library assets".
