• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
cfquery fails with conditional query stored in a variable
Guest
Sep 22, 2010 Sep 22, 2010
Following code doesnt work. Can anyone explain why?
<cfset myquery="select * from employee where id = '10'">
<cfquery name="a" datasource="mydsn">
#myquery#
</cfquery>
TOPICS
Advanced techniques
Views
934
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , Sep 22, 2010 Sep 22, 2010
What do you mean by "doesn't work"?  You really ought to read this before posting: http://forums.adobe.com/thread/607238.
Is the ID really a string-oriented column?  I would expect it to be an integer, so it oughtn't have the quotes.
Also, if you are doing what you're doing, if your variable has single quotes in it, you'll need to use preserveSingleQuotes() to stop CF escaping them.
Adam
Votes
Translate
Translate
LEGEND ,
Adam
Votes
Translate
Translate
Report
Report
Guest
My sincere apologies for not reading that thread before posting because of which my post which seemed fine to me doenst seem the same any longer.
Anyway, yes you are right that the column is a string oriented one because of which I am using single quotes. And you are right again about escaping single quotes which was the real problem. Once I used the function mentioned, it worked prefectly.
Thanks again.
Votes
Translate
Translate
Report
Report
Valorous Hero ,
While PreserveSingleQuotes() is the correct function to use to resolve that error, be sure you understand the security ramifications of using it. ColdFusion automatically escapes single quotes to help combat sql injection.  PreserveSingleQuotes() prevents that from happening.  So if your sql string includes user supplied values, it may be vulnerable to sql injection.
Message was edited by: -==cfSearching==-
Votes
Translate
Translate
Report
Report
LEGEND ,
Are you sure about that?  All of my sql injection test results suggest otherwise.
Votes
Translate
Translate
Report
Report
Valorous Hero ,
As I mentioned on another thread, a quick search of google will turn up many articles that concur.  So your comments suggest that either your tests are incorrect, or perhaps you have a database that is not capable of executing multiple statements.  Please post more details about which database and what tests you are using.  Since it is rather trivial to reproduce, either something in your tests is very wrong or you are omitting some key details ...
Votes
Translate
Translate
Report
Report
LEGEND ,
To summarize, with MSSql, which does allow multiple queries in a cfquery tag, you can get a user entered query to execute if the datatype is numeric.  If the field was char or varchar, the form field would be treated as a single string.   It was awhile ago, but I think with date fields, the query would simply crash.
My tests also include javascript.  To make a long story short, those who rely only on cfqueryparam for security are unprotected.
But then again, maybe my tests were wrong.
Votes
Translate
Translate
Report
Report
Valorous Hero ,
unprotected.
I disagree with that statement, and you do not really explain why you think it is unprotected. Could you provide an example of a query that is unprotected with cfqueryparam?
But .. the previous conversation was about your disagreement with my statement: "using PreserveSingleQuotes() makes queries insecure." If you are not able to easily reproduce that vulnerability in a simple test against MS SQL, then I would agree. Your tests are wrong.
http://www.coldfusionmuse.com/index.cfm/2008/7/21/query-string-with-cfqueryparam
-Leigh
Votes
Translate
Translate
Report
Report
LEGEND ,
Regarding:
insert into sometable
(somefield)
values
(<cfqueryparam value = "<script>code goes here;</script>">
Votes
Translate
Translate
Report
Report
Valorous Hero ,
LATEST
(somefield)
values
here;</script>">
That is not sql injection. It is script injection which requires totally different protection methods.  As I am sure you know.  We were talking about a specific sql injection risk posed by using PreserveSingleQuotes().  http://en.wikipedia.org/wiki/SQL_injection
>> PreserveSingleQuotes() .... it may be vulnerable to sql injection.
>>>> suggest otherwise.
... Are you suggesting PreserveSingleQuotes() IS safe from your script injection example?
Votes
Translate
Translate
Report
Report
Resources
Documentation
