7 Replies Latest reply on Sep 23, 2010 9:14 PM by Anitha Selvaraj
    sorting
    bindu84
      How to sort date type data using sort field
      <?xml version="1.0"?>
      <mx:Application
      xmlns:mx="http://www.adobe.com/2006/mxml"
      initialize="initDP();" width="
      550" height="400">
      <mx:Script>
      <![CDATA[
      import mx.events.DataGridEvent;
      import mx.collections.*;
      // Declare storage variables and initialize the simple variables.
      // The data provider collection.
      private var myDPColl:ArrayCollection;
      // The Sort object used to sort the collection.
      private var sortA:Sort;
      // The sort fields used to determine the sort.
      private var sortByInStock:SortField;
      private var sortByDate:SortField;
      private var sortByAlbum:SortField;
      private var sortByPrice:SortField;
      // The data source that populates the collection.
      private var myDP:Array = [
      {Date:
      '10/12/2006', Album:'Slanted and Enchanted',
      Price:11.99, InStock:
      true},
      {Date:
      '10/11/2005', Album:'Crooked Rain, Crooked Rain',
      Price:10.99, InStock:
      false},
      {Date:
      '10/05/2003', Album:'Wowee Zowee',
      Price:12.99, InStock:
      true},
      {Date:
      '10/12/2004', Album:'Brighten the Corners',
      false},
      {Date:
      '10/09/2006', Album:'Terror Twilight',
      true},
      {Date:
      '10/12/2008', Album:'Buildings Meet the Sky',
      Price:14.99, InStock:
      true},
      {Date:
      '10/08/2006', Album:'Other', Price:5.99, InStock: true}
      //Initialize the DataGrid control with sorted data.
      private function initDP():void {
      //Create an ArrayCollection backed by the myDP array of data.
      myDPColl =
      new ArrayCollection(myDP);
      //Create a Sort object to sort the ArrrayCollection.
      sortA =
      new Sort();
      //Initialize SortField objects for all valid sort fields:
      // A true second parameter specifies a case-insensitive sort.
      // A true third parameter specifies descending sort order.
      // A true fourth parameter specifies a numeric sort.
      sortByInStock =
      new SortField("InStock", true, true);
      sortByDate =
      new SortField("Artist", true);
      sortByAlbum =
      new SortField("Album", true);
      sortByPrice =
      new SortField("Price", true, false, true);
      // Sort the grid using the sortByDate fields.
      sortA.fields=[sortByDate];
      myDPColl.sort=sortA;
      // Refresh the collection view to show the sort.
      myDPColl.refresh();
      // Set the ArrayCollection as the DataGrid data provider.
      myGrid.dataProvider=myDPColl;
      // Set the DataGrid row count to the array length,
      // plus one for the header.
      myGrid.rowCount=myDPColl.length +1;
      // Re-sort the DataGrid control when the user clicks a header.
      private function headRelEvt(event:DataGridEvent):void {
      // The new third priority was the old second priority.
      sortA.fields[2] = sortA.fields[1];
      // The new second priority was the old first priority.
      sortA.fields[1] = sortA.fields[0];
      // The clicked column determines the new first priority.
      if (event.columnIndex==0) {
      sortA.fields[0] = sortByDate;
      else if (event.columnIndex==1) {
      sortA.fields[0] = sortByAlbum;
      else if (event.columnIndex==2) {
      sortA.fields[0] = sortByPrice;
      else {
      sortA.fields[0] = sortByInStock;}
      // Apply the updated sort fields and re-sort.
      // Refresh the collection to show the sort in the grid.
      myDPColl.refresh();
      // Prevent the DataGrid from doing a default column sort.
      event.preventDefault();
      </mx:Script>
      <!-- The Data Grid control.
      By default the grid and its columns can be sorted by clicking.
      The headerRelease event handler overrides the default sort
      behavior. -->
      <mx:DataGrid id="myGrid" width="100%" headerRelease="headRelEvt(event);">
      <mx:columns>
      <mx:DataGridColumn minWidth="120" dataField="Date" />
      <mx:DataGridColumn minWidth="200" dataField="Album" />
      <mx:DataGridColumn width="75" dataField="Price" />
      <mx:DataGridColumn width="75" dataField="InStock"
      headerText="
      In Stock"/>
      </mx:columns>
      </mx:DataGrid>
      </mx:Application>
        • 1. Re: sorting
          jfb00 Level 3
          Here is a nice exaple using arraycollection.
          http://blog.flexexamples.com/2007/08/12/sorting-date-columns-in-a-datagrid/
          Johnny
          Please rate my answer
          • 2. Re: sorting
            bindu84 Level 1
            i want to sort dataprovier with out any click,
            initially want to aplly DataGrid sort order,
            • 3. Re: sorting
              jfb00 Level 3
              ok,
              Just call the sort function from your init function.
              The example just give you the idea how to do the sort.
              Johnny
              • 4. Re: sorting
                bindu84 Level 1
                i m not gtting can u plesae
                tell me in my code
                • 5. Re: sorting
                  Anitha Selvaraj Level 2
                  Check the modified code below. This will work.
                  <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" initialize="initDP();" width="550" height="400">
                  <mx:Script>
                      <![CDATA[
                          import mx.utils.ObjectUtil;
                          private var myDP:Array = [{Date:'10/12/2006', Album:'Slanted and Enchanted',Price:11.99, InStock:true},
                              {Date:'10/11/2005', Album:'Crooked Rain, Crooked Rain',Price:10.99, InStock:false},
                              {Date:'10/05/2003', Album:'Wowee Zowee',Price:12.99, InStock:true},
                              {Date:'10/12/2004', Album:'Brighten the Corners',Price:11.99, InStock:false},
                              {Date:'10/09/2006', Album:'Terror Twilight',Price:11.99, InStock:true},
                              {Date:'10/12/2008', Album:'Buildings Meet the Sky',Price:14.99, InStock:true},
                              {Date:'10/08/2006', Album:'Other', Price:5.99, InStock: true}];
                              myDPColl = new ArrayCollection(myDP);
                              myDPColl.refresh();
                          private function date_sortCompareFunc(object1:Object, object2:Object):int {
                              /* Date.parse() returns an int, but
                                 ObjectUtil.dateCompare() expects two
                                 Date objects, so convert String to
                                 int to Date. */
                              var dateA:Date = new Date(Date.parse(object1.Date));
                              var dateB:Date = new Date(Date.parse(object2.Date));
                              return ObjectUtil.dateCompare(dateA, dateB);
                          private function date_dataTipFunc(object:Object):String {
                              return dateFormatter.format(object.Date);
                  </mx:Script>
                  behavior. -->
                  <mx:DateFormatter id="dateFormatter" formatString="DD/MM/YYYY" />
                  <mx:DataGrid id="myGrid" width="100%">
                      <mx:columns>
                          <mx:DataGridColumn minWidth="120" dataField="Date" sortCompareFunction="date_sortCompareFunc" showDataTips="true" dataTipFunction="date_dataTipFunc" />
                          <mx:DataGridColumn width="75" dataField="InStock" headerText="In Stock"/>
                      </mx:columns>
                  </mx:DataGrid>
                  </mx:Application>
                  Regards,
                  Anitha
                  • 6. Re: sorting
                    bindu84 Level 1
                    thanx
                    But i want the sort data in datagrid with any hader click
                    • 7. Re: sorting
                      Do you mean only on header release event?
