2 Replies Latest reply on Aug 1, 2007 1:35 PM by sem1128
    Edit Recording Into Individual Animations
    sem1128
      Here's the problem: Using Captivate, I have created a full motion recording of an application. When the output is viewed it appears as a series of slides; each slide a single screen shot with mouse movement and text captions.) I want to take one slide at a time (with its mouse movement and text captions) and insert it as an one-slide animation into an already existing slide. Every time I try to insert just one slide out of a recording, I get the entire multi-slide animation.
      (I am doing an "insert animation", instead of an "import recording", because my project uses a background slide with multiple panes and the animation has to fit inside one of these panes. If I import the slides, they can't be reduced to fit in the pane.)
      Does anyone have any suggestions? Thanks in advance for your help!
