2 Replies Latest reply on Oct 8, 2010 1:55 PM by xbytemanx
    Proxy-config wsdl question
      When defining my destenatoin in the proxy-config.xml, Is it possible to point to a wdsl  located on the local file system?
      I am trying to connect TIBCO web-services which do not advertise the WSDL.
        • 1. Re: Proxy-config wsdl question
          You peaked my interest so I did the following.
          FIrst, I found a simple service (calculate) online and copied it's WSDL to my local drive.
          I added the file reference to it in my proxy-config.xml.
          No luck!
          However, since I had the WSDL, I placed it on my local TOMCAT (LCDS) instance so that I could reference it via HTTP.
          <destination id="testWSDLFile">
          <adapter ref="soap-proxy"/>
          Once i did that, I could use the Data Service wizard in FlashBuilder and everything seemed to work. I was worried that I might have crossdomain issue-something to consider I suppose. Otherwise .. all good.
          Hope that helps some
          • 2. Re: Proxy-config wsdl question
            xbytemanx Level 1
            That did help ~ sorry for the late response, I just decided to include the
            WSDL file in the war deployment and self reference it.
            I figured that any change i needed to make would require me to redeploy the war anyways.
