• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
has anyone created MS filetime converter for CF?
New Here ,
Sep 22, 2010 Sep 22, 2010
I'm trying to authorize user via ldap to see if they are currently 'logged in'.
normal method would be compare login time against current time and require a new login every 4 hours.
my problem is that LDAP time string is huge (ex: 129296092840348948) .. lots of googling leads me to believe this is MS filetime data type (a composite of two 32-bit numbers).
problem is converting it into something usable.. everything I find about converting refers to a MS system call named FileTimeToSystemTime()
has anyone done this in CF?
TOPICS
Advanced techniques
Views
648
Translate
Translate
Report
Report
Community guidelines
community guidelines
Valorous Hero ,
I cannot say I know anything about it. But a quick google suggests there there is a .net function that might be of use: DateTime.FromFileTime
http://bytes.com/topic/net/answers/123957-filetimetosystemtime-dotnet
http://msdn.microsoft.com/en-us/library/system.datetime.fromfiletime.aspx
-Leigh
Votes
Translate
Translate
Report
Report
Enthusiast ,
http://bit.ly/bdC4KT
Votes
Translate
Translate
Report
Report
Valorous Hero ,
Haha. I should have known the time master would have something in his arsenal
Votes
Translate
Translate
Report
Report
New Here ,
cfsearching... ya.. I could just do an exec vb script inside the cf code.. yeah.. uh..    ... actually , that was what I found when I was out looking around.. MS has built in functions for doing the conversion.. but its not a CF solution.
PaulH - you've got a lot of good stuff there
I eventually found my answer on a unix forum (after 4 hours of searching and digging thru all the crap) .. and here is the CF solution:
<cffunction name="fileTimeConvert" access="public" output="false">
<cfargument name="timeString" required="true" type="Numeric">
     <cfset var result = ''>
      <!--- remove last 7 digits: --->
     <cfset var myTempTime = Left(arguments.timeString,11)>
     <!--- subtract 11644473600, which is seconds from 1601 to 1970 I think --->
     <cfset myTempTime = myTempTime -11644473600 >
     <!--- myTempTime is now UNIX epoch time, and do dateAdd: --->
     <cfset result = DateAdd("s", myTempTime, "January 1 1970 00:00:00")>
     <cfreturn result>
</cffunction>
Votes
Translate
Translate
Report
Report
Valorous Hero ,
I was thinking if it was some weird MS specific time, and all else failed, you could always call a .net library from CF. But obviously I did not look into it that deeply Glad you found a simpler solution.
-Leigh
Votes
Translate
Translate
Report
Report
New Here ,
actually, I think it is a weird ms-specific thing ... they have a built-in function in VB and C/+ to do the conversions, and I had to dig a long time to figure out what it was. CF was blowing up because it couldn't handle 64-bit integers when I was just trying to do simple math on the values.
Votes
Translate
Translate
Report
Report
Valorous Hero ,
LATEST
True. There is the 32-bit limitation.
it was.
Yeah, it does seem like an ms-specific thing. But by "weird" I was thinking really twisted, complex stuff like the old Office format. Stuff only masochistic people (like the developers at POI) could ever stick with long enough to figure out
Votes
Translate
Translate
Report
Report
Resources
Documentation
