1. Re: Effect Envelopes?
ryclark Sep 23, 2010 3:34 AM (in response to Stephen Finton)If you click on the white Automation arrow head along side the Read field at bottom left of track box Automation lanes will become visible. You can then add an Insert FX Power On/Off or Dry/Wet mix envelope.
2. Re: Effect Envelopes?
therealdobro Sep 26, 2010 10:24 AM (in response to ryclark)Brilliant! I was just wondering about that yesterday. Nice timing! Keep up the good work, fellows!
3. Re: Effect Envelopes?
M Vodo May 11, 2011 4:30 AM (in response to ryclark)Mr.ryclark
I have this problem to...I used to use FX Power on\off in Adobe Audition 3
but I can't find it when Upgraded to Audition CS 5.5
How can I use the insert FX power on\off in Audition CS5.5 ??
5. Re: Effect Envelopes?
M Vodo May 12, 2011 12:53 AM (in response to ryclark)Online help doesn't explain where's the FX Power On\Off
7. Re: Effect Envelopes?
Corns99 Aug 22, 2014 10:07 PM (in response to M Vodo)In a multi session track you can hit FX button to see your effects. Then like ryclark said, "If you click on the white Automation arrow head along side the Read field at bottom left of track box Automation lanes will become visible."
Then click the arrow head by Show Envelopes and select Rack Power (I think this replaces FX Power). If you want to key frame wet and dry, select Rack Mix.
