1 Reply Latest reply on Jul 26, 2007 8:41 AM by Mike Crisp
    Check if Windows media player present
    Mike Crisp
      Hi
      I have used the script below to get a QuickTime prompt
      What would be the same to check if either
      a) Win Media Player is present or
      b) What version a user has
      If none of early version prompt to go online and updtae / download.
      on mouseUp
      if quicktimeversion()<7 then
      go frame 2 -- on this frame I explain what has happened and prompt them to install / download
      else
      play movie "start"
      end if
      end
        • 1. Re: Check if Windows media player present
          Mike Crisp Level 1
          I have figured it out, thanks to a earlier post (sorry should have searched harder) earlier post
          Add the following as a movie script:
          on DirectXVersion
          oldDelim=the itemDelimiter
          the itemDelimiter="."
          dxVersion=integer(the environment.directXVersion.item[1])
          the itemDelimiter=oldDelim
          return dxVersion
          end
          Then add the following script onto a button
          On mouseUp
          if directXVersion()<=11 then
          go frame 2
          --do something if it is 9 or better
          else
          --do something if it needs to be installed
          play movie "start"
          end if
          end
          BE CAREFUL as version 11 is only available on XP and above
