13 Replies Latest reply on Sep 23, 2010 7:18 AM by ArrowUpRight
    Events & Static Classes
    ArrowUpRight Level 2
      Can only an instance of a class dispatch an event, or the static class can too?
      We have MyManager static class:
      package managers
           import mx.rpc.CallResponder;
           import services.MyDataService;
           import valueObjects.MyValueObject;
           public static class MyManager
                public static var updateDataResult:CallResponder = new CallResponder();
                private static var myDataService:MyDataService = new MyDataService ();
                private static var myValueObject:MyValueObject = new MyValueObject();
                public static function updateMyDataService():void {
                     updateDataResult.token = myDataService.update(myValueObject);
      And the other class wich calls:
      import managers.MyManager;
      MyManager.updateMyDataService();
      MyManager.updateDataResult.addEventListener(ResultEvent.RESULT,resultReceived);
      and this Event Listener does not work.
        • 1. Re: Events & Static Classes
          BhaskerChari Level 4
          Hi Banditizm,
          I dont think there is any such called Static class in Flex. I think we can have static members and static methods of a class. But we cannot declare something like...
          public static class IdentificationManager
          and yes you can dispatchEvent and listen from a class which has static members and static methods.
          Bhasker
          • 2. Re: Events & Static Classes
            Yes, you are right, there is no "static" keyword in the class declaration, and i mean Global Classes Without Instantiating, you know, when i said Static Classes, but the construction i show above does not work. It likes, the static callResponder can not dispatch any event
            • 3. Re: Events & Static Classes
              Hi Banditizm,
              Yes you can even dispatch the events from your static callResponders but I think the difficulty you might be facing is you cannot capture or listen to those events dispatched.
              You can do one thing you can dispatch these events w.r.t systemManager and also listen to these events w.r.t. it.
              I mean from your call reponder dispatch the event as below..
              systemManager.dispatchEvent(new Event("dataLoadComplete"));
              //And you can listen it in your mxml or .as file as below...
              systemManager.addEventListener("dataLoadComplete", onDataLoadComplete);
              Bhasker
              • 4. Re: Events & Static Classes
                Thank you Bhasker!
                Now i realise that event dispatched but i can't listen to it.
                But, for future, what is w. r. t. deсoding?
                And, you mean, the SystemManager with capital S.
                • 5. Re: Events & Static Classes
                  Hi Banditizm,
                  w. r. t ---> with respect to..
                  I have used short hand notation for it..
                  Have you made a test for listening the event..dispatched..and also try to remove the eventListener w.r.t systemManager only when it is no longer needed..
                  Otherwise it still retains memory.
                  Note: systemManager is with small s only..not capitalized..
                  Bhasker
                  • 6. Re: Events & Static Classes
                    oops, only the instance of SystemManager can dispatchEvent. So, i can't have only one instance of something to be accessed from any file just by importing it.
                    • 7. Re: Events & Static Classes
                      You need not create any instance of systemManager . Actuallt the systemManager itself refers to the top level application.
                      You can directly use systemManager.dispatchEvent and systemManager.addEventListener with out creating any reference to it anywhere and you can use the same any where in your application.
                      Hope you now understand it.
                      Bhasker
                      • 8. Re: Events & Static Classes
                        OK, the correct question is, why can not i acces systemManager(current SystemManager used by this component) from my custom manager class wich extends nothing? Otherwise, i can acces it from the mxml component.
                        • 9. Re: Events & Static Classes
                          Note: i'm trying to connect to systenManager from static function.
                          • 10. Re: Events & Static Classes
                            From where ever you use the systemManager in your application it refers to only one reference that is a reference for the whole application.
                            Its not like it will be seperate for different components, it refers to same and only single topLevel SystemManger class form where ever you try to access.
                            You can also access it from your custom manager class also. If your class is a .as file then you can try
                            Application.application.systemManager.dispatchEvent(new Event("someEvent"));
                            Bhasker
                            • 11. Re: Events & Static Classes
                              God bless you Bhasker.
                              Now when i use this construction
                              Application.application.systemManager.dispatchEvent(new Event('whereAreYouEvent'));
                              codecompletion helps me, but error thrown:
                              1119: Access of possibly undefined property application through a reference with static type Class.
                              IdentificationManager.as    /PR5/src/managers    line 48    Flex Problem
                              It looks like madness i know but why does not this work to me?
                              • 12. Re: Events & Static Classes
                                Are you using FlashBuilder(Flex4) or Flex3..??
                                Have you imported the below namespace..
                                import mx.core.Application;
                                If you are using Flex4 I think you need to use FlexGlobals.topLevelApplication instead of Application.application also dont forget to import the correct namespace..
                                Bhasker
                                • 13. Re: Events & Static Classes
                                  Wooh! Yes, i use Flex4, and now when i respond to FlexGlobala.topLevelApp both in .as and .mxml files everything woks!
                                  Thank you a lot once more, such a beautiful learning day!
