2 Replies Latest reply on Sep 23, 2010 9:28 AM by Extreme911
    XML->VoObj and VoObj -> XML
    Extreme911
      I have a problem with creating proper VO object for the following xml:
      example:
      <Journey>
                 <Origin LocationCode="SYD" CodeContext="CRS"/>
                 <Destination LocationCode="GOS" CodeContext="CRS"/>
                 <DateTime>
                      <OutBound>
                              <DepartureDateTime WindowAfter="P1970Y1M1DT7H">2010-02-18T06:43:00</DepartureDateTime>
                      </OutBound>
                 </DateTime>
      </Journey>
      The problem is with the RED part of the xml... How do i create a VOobject for this so i can TypeCast my ObjXml to VoObj ?
      Also How my VO class should look if i want to get exact same XML if i will encode it from my VOt?
      Thanks.
        • 2. Re: XML->VoObj and VoObj -> XML
          Extreme911 Level 1
          Thanks for a quick reply...
          I wish it was that simple... however... here is a source.
          Im basicaly loading XML to the obj, and then converitng it back to xml..
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute"   xmlns:reservation="services.reservation.*" creationComplete="application_creationCompleteHandler(event)">
          <mx:Script>
          <![CDATA[
          import mx.controls.Alert;
          import mx.events.FlexEvent;
          import mx.rpc.events.FaultEvent;
          import mx.rpc.events.ResultEvent;
          import mx.rpc.events.SchemaLoadEvent;
          import mx.rpc.events.XMLLoadEvent;
          import mx.rpc.xml.Schema;
          import mx.rpc.xml.SchemaLoader;
          import mx.rpc.xml.SchemaManager;
          import mx.rpc.xml.SchemaTypeRegistry;
          import mx.rpc.xml.SimpleXMLDecoder;
          import mx.rpc.xml.SimpleXMLEncoder;
          import mx.rpc.xml.XMLDecoder;
          import mx.rpc.xml.XMLEncoder;
          import mx.utils.ObjectUtil;
          protected function application_creationCompleteHandler(event:FlexEvent):void
          /* Convert XMLNode to XMLDocument. */
          var xmlStr:String = <Journey>
          <DateTime>
          <OutBound>
          </OutBound>
          </DateTime>
          </Journey>;
          var xmlDoc:XMLDocument = new XMLDocument(xmlStr);
          var decoder:SimpleXMLDecoder = new SimpleXMLDecoder(true);
          var resultObj:Object = decoder.decodeXML(xmlDoc);
          var xml:XML = objectToXML(resultObj);
          private function objectToXML(obj:Object):XML {
          var qName:QName = new QName("root");
          var xmlDocument:XMLDocument = new XMLDocument();
          var simpleXMLEncoder:SimpleXMLEncoder = new SimpleXMLEncoder(xmlDocument);
          var xmlNode:XMLNode = simpleXMLEncoder.encodeValue(obj, qName, xmlDocument);
          var xml:XML = new XML(xmlDocument.toString());
          trace(xml.toXMLString());
          return xml;
          </mx:Script>
          <mx:CallResponder id="RailDist_ScheduleAvailabilityResult"/>
          <reservation:Reservation id="reservation" fault="Alert.show(event.fault.faultString + '\n' + event.fault.faultDetail)" showBusyCursor="true"/>
          <mx:CallResponder id="RailDist_ScheduleAvailabilityResult2"/>
          </mx:Application>
          And its not the same as
          i need to recreate exact copy of this TAG and not <value>2010-02-18T06:43:00</value>
          RETURN WOULD BE:
            <Journey>
              <DateTime>
                <OutBound>
                  <DepartureDateTime>
                    <value>2010-02-18T06:43:00</value>     // This part is not good. has to be as before
                    <WindowAfter>P1970Y1M1DT7H</WindowAfter>
                </OutBound>
              </DateTime>
              <Destination>
                <CodeContext>CRS</CodeContext>
                <LocationCode>GOS</LocationCode>
              </Destination>
              <Origin>
                <LocationCode>SYD</LocationCode>
              </Origin>
            </Journey>
          Message was edited by: Extreme911
