5 Replies Latest reply on Jul 7, 2011 11:15 PM by Benoitcn
    Make Spark DropDownList look like Halo Combobox
    etr34t
      I want to use Spark DropDownList in an application that contains no other Spark components(i.e. only Halo) and uses the Halo theme. If I use Spark DropDownList, it stands out too much because it uses the Spark theme even though Halo is set as the project theme.
      The documentation says:
      If you use the Halo theme, then the Halo theme is applied only to MX components in your application. The Spark components continue to use the Spark theme unless you specifically override them.
      How can I do that, i.e. override a Spark component to use the Halo theme?
