I have a project that is using two library projects (not in the default location).
When I tried to navigate to the source of one of this libraries classes (using command + click, or command + shift + T) i get a message saying that the sources could not be found. I tried to configure it in the project properties, but even the absolute path to the sources is not working.
Does anybody run into the same issue or has suggestions about how to solve it ?
Olivier
Have you added the library projects to your project's Build Path? (Project Properties -> Flex Build path -> Add Project).
If you have a SWC and a source in a location unknown by flash builder, you should be able to configure that’s SWC's property in build path to point to the source folder.
In that case, make sure you point to src/ and project/. That is, for a class foo.bar.ClassX, you point to the folder which has the folder foo.
Anirudh
Thanks for your answer,
Yes, i did this for both of the library but it's not working.
Something specific to my projects :
Any ideas ?
Olivier
Would it be possible to send us the project?
If it is confidential, we understand. If that is the case, then could you please attach a screenshot showing your Flex Build Path property page? (Project Properties, Flex Build Path)
Cheers,
Anirudh
