2 Replies Latest reply on Jul 30, 2007 8:45 AM by kpete1
    Import Audio Error Message
    kpete1
      When trying to import audio into a Captivate 2 project I receive the following error:
      "Unable to decode and import the selected wav/mp3 file"
      I have seen other posting where this is a problem in Vista but I am running Windows XP. I can listen to these clips in the Windows Media Player. I have also verified that they are in the PCM Format.
      How can I get this fixed? I need to have these projects posted by Monday morning!!!
      Thanks for your help!
        • 1. Re: Import Audio Error Message
          Hi kpete1
          I know you said that you are certain that the file is already in PCM format. But just for grins, you might try clicking Start > Run... and typing sndrec32.exe into the Run dialog. Then press Enter. The generic Windows Sound Recorder application should open. Open the file giving you fits. Then click File > Save As... and note what format is listed at the bottom of the Save As dialog next to the Format: area. You may be surprised to see it's not PCM. Even if it is PCM, click the Change... button. And this is all you need to do! From there, just click the OK button to dismiss the Sound Selection dialog. Then click the Save button to dismiss the Save As dialog. You might wish to change the file name of the original .WAV file in case you ever need it in the original format for anything.
          Give that a go and let us know if it helps. Hopefully it will.
          Cheers... Rick
          • 2. Re: Import Audio Error Message
            kpete1 Level 1
            Rick,
            Thanks for your help! Unfortunately, that did not work. I still receive the unable to decode and import the selected wav/mp3 file error message. Any other ideas?
