9 Replies Latest reply on Aug 1, 2007 1:45 PM by Newsgroup_User
    sprite properties in property inspector
    Level 7
      Rather than typing in each sprite property name with the sprite number in
      the property inspector, I'd like to show all properties of a particular
      sprite with one entry. This has been answered before here but I've
      forgotten how to do it.
      I thougth it was something like:
      sprite (1).scriptInstanceList [1]
      but that's not it. I'm sure Sean will know.
      Craig Wollman
      Lingo Specialist
      Word of Mouth Productions
      212-928-9581
      www.wordofmouthpros.com
        • 1. Re: sprite properties in property inspector
          Level 7
          That's a lot of faith you seem to be investing, Craig!
          You could try adding simply 'sprite(num)'
          • 2. Re: sprite properties in property inspector
            Level 7
            Nah, I tried that. It was something like what I posted but I'm missing one
            small element.
            Craig
            Craig Wollman
            Lingo Specialist
            212-928-9581
            "Sean Wilson" <webforumsuser@macromedia.com> wrote in message
            news:f8o6uc$b0a$1@forums.macromedia.com...
            • 3. Re: sprite properties in property inspector
              Level 7
              Are you talking about "default" properties like loc, blend, etc., or
              properties of attached behaviors, or member properties specific to type?
              • 4. Re: sprite properties in property inspector
                Level 7
                I'm referring to user defined properties that fall next to the property
                keyword in a behavior.
                sprite (5).scriptinstancelist[1]
                ...gives the object name and memory position but there's something I can add
                to that that will break out the properties I've added to that behavior so I
                don't have to type each one into the Property Inspector when I want to watch
                them.
                Craig Wollman
                Lingo Specialist
                212-928-9581
                news:f8ofkg$krb$1@forums.macromedia.com...
                • 5. Re: sprite properties in property inspector
                  Level 7
                  When I add the above to my Object Inspector and hit the (+) next to it,
                  it shows me all the assigned properties and associated values. Do you
                  not see this?
                  • 6. Re: sprite properties in property inspector
                    Level 7
                    Yes, I now see that. For some bazaar reason, when I use sprite 5, I get
                    VOID but when I use sprite 8 I get all the child instance and all of the
                    properties. Both sprites have the same graphic and same behavior attached.
                    It's a card game so sprites 2 - 53 are exactly the same.
                    I'm not going to try to figure this one out.
                    Thanks for your help Sean.
                    Craig Wollman
                    Lingo Specialist
                    212-928-9581
                    news:f8qnj5$fea$1@forums.macromedia.com...
                    > When I add the above to my Object Inspector and hit the (+) next to it, it
                    > shows me all the assigned properties and associated values. Do you not see
                    > this?
                    • 7. Re: sprite properties in property inspector
                      Level 7
                      Sean,
                      I restarted Director and sprite 5 now has the list of properties. It's
                      interesting that I happen to use sprite 5 as an example and my test sprite.
                      Chalk it up to memory or something unexplainable.
                      Craig Wollman
                      Lingo Specialist
                      212-928-9581
                      > this?
                      • 8. Re: sprite properties in property inspector
                        Level 7
                        If you have sprite(5).scriptInstanceList in the Object Inspector, pretty
                        often, sprite(5) stops using it's script. It is not 100% of the time,
                        but I have found, as a general rule, that very odd things happen when
                        you try that. Be careful.
                        Sometimes you can get away with something like this:
                        global gSprite5
                        on startMovie
                        gSprite5=sprite(5).scriptInstanceList
                        end
                        and you can put gSprite5 into the Object Inspector. Sometimes it works.
                        Not always...
                        • 9. Re: sprite properties in property inspector
                          Level 7
                          Thanks Mike. It's always nice to know when it's a bug and not one's
                          imagination.
                          Craig
                          Craig Wollman
                          Lingo Specialist
                          212-928-9581
                          "Mike Blaustein" <mblaustein@gmail.com> wrote in message
                          news:f8qqnq$j2o$1@forums.macromedia.com...
                          > often, sprite(5) stops using it's script. It is not 100% of the time, but
                          > I have found, as a general rule, that very odd things happen when you try
                          > that. Be careful.
                          > global gSprite5
                          > on startMovie
                          > end
                          > Not always...
