1 Reply Latest reply on Oct 24, 2010 2:34 AM by vabhatia
    browseForSave
    Mykle Sm Level 1
      Why First Alert issued. I need to first calls browseForSave
      var docsDir = air.File.documentsDirectory;
      var fn;
      try
         docsDir.browseForSave("Сохранить файл как...");
          fn = docsDir.addEventListener(air.Event.SELECT, saveData);
      catch (error)
          air.trace("ошибка сохранения:", error.message)
      function saveData(event){
      filename = event.target;
      if (filename.nativePath.substr(filename.nativePath.length - 4, filename.nativePath.length - 1) != '.txt') {
      filename.nativePath = filename.nativePath + '.txt';
      return filename.nativePath;
      alert('11');
        • 1. Re: browseForSave
          vabhatia Adobe Employee
          Try this
          <!-- http://blog.flexexamples.com/2008/08/25/saving-files-locally-using-the-filereference-classs-save-method-in-flash-player-10/ -->
          <s:Application name="FileReference_save_test"
                  xmlns:fx="http://ns.adobe.com/mxml/2009"
                  xmlns:mx="library://ns.adobe.com/flex/mx"
                  xmlns:net="flash.net.*"
                  creationComplete="init();">
              <fx:Script>
                  <![CDATA[
                      private function init():void {
                          textArea.text = describeType(FileReference).toXMLString();
                      private function btn_click(evt:MouseEvent):void {
                          fileReference.save(textArea.text, "describeType.txt");
              </fx:Script>
              <fx:Declarations>
                  <net:FileReference id="fileReference" />
              </fx:Declarations>
              <s:Panel id="panel"
                      width="500" height="300"
                      verticalCenter="0" horizontalCenter="0">
                  <s:controlBarContent>
                      <s:Button id="btn"
                              label="Save Text"
                              click="btn_click(event);" />
                  </s:controlBarContent>
                  <s:TextArea id="textArea"
                          editable="true"
                          width="100%"
                          height="100%" />
              </s:Panel>
          </s:Application>
          You can also pass the XML object directly to the FileReference class’s save() method.
          I hope this helps you.
