4 Replies Latest reply on Sep 25, 2010 11:38 PM by cwenet
    merge 2 pdf docs
    cwenet
      with this I want merge 2 pdf files to 1:
      // Create a new PDF document:
      var newDoc = app.newDoc();
      // Insert doc1.pdf:
      newDoc.insertPages({
      nPage : -1,
      cPath : "/d/Cover.pdf",
      // Insert doc2.pdf:
      nPage : newDoc.numPages,
      cPath : "/d/Book.pdf",
      // Save the new document:
      newDoc.saveAs("/d/myNewDoc.pdf");
      // Close the new document without notifying the user:
      newDoc.closeDoc(true);
      The cover.pdf has 2 pages
      The Book.pdf has for example 200 pages.
      But there is an error:
      TypeError: Ungültiger Argumenttyp.
      ===> Parameter nPage.
      What is wrong with the script?
      Regards
      Christoph
        • 1. Re: merge 2 pdf docs
          nPage is 0-based, while numPages returns the actual number of pages in the
          file.
          If you want to insert doc2 at the end of the files, use nPage:
          this.numPages-1
          • 2. Re: merge 2 pdf docs
            cwenet Level 1
            Thank you.
            Now, the script looks like this:
            // Insert doc1.pdf:
            nPage : -1,
            // Insert doc2.pdf:
            nPage : newDoc.numPages-1,
            The merging works. But there is one empty page between Cover.pdf and Book.pdf in myNewDoc.pdf.
            Do you have an idea, why?
            Best regards
            Christoph
            • 3. Re: merge 2 pdf docs
              That's the single, empty page that is created when you execute newDoc(). A
              file must have at least one page.
              You can delete it using deletePages. It's location will be the size of doc1
              + 1.
              • 4. Re: merge 2 pdf docs
                cwenet Level 1
                Thank you try67,
                for your help. Now it works perfect.
                regards
                Christoph
