0 Replies Latest reply on Sep 24, 2010 11:16 AM by Ashu***
    New Bie Question: Doing Flex Salesforce integration for the first time
    Ashu***
      Dear Friends,
      I want to connect to Salesforce using Flex API and I have tried two-three approaches but all in vain.
      It give me an error 'INVALID_LOGIN: Invalid username, password, security token; or user locked out.'
      PLEASE HELP ME TO FIX THIS .
      Also, I would like the highlight the fact that my username and password work only for 'test.salesforce.com' and not for ' login.salesforce.com'. Could it be reason for login failure. I have used the token as suggested.
      I have also tried setting different serverURL like ''serverUrl=https://test.salesforce.com/services/Soap/u/9.0 and https://login.salesforce.com/services/Soap/u/9.0 .
      Below are two of the techniques I have used.
      (1) Using AIR API.
      For this I have done as mentioned in 'http://wiki.developerforce.com/index.php/Force.com_Flex_Quick_Start_Tutorial'.
      (2) Trying to tun the below code, that I found in one of the quick start tutorial.
      <s:WindowedApplication
      xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:s="
      library://ns.adobe.com/flex/spark"
      xmlns:mx="
      library://ns.adobe.com/flex/mx" xmlns:salesforce="http://www.salesforce.com/">
      <fx:Declarations>
      <salesforce:AIRConnection id="force"/>
      <!-- Place non-visual elements (e.g., services, value objects) here -->
      </fx:Declarations>
      <mx:DataGrid id="dgSolutions" right="10" top="10" left="10" bottom="10" />
      <fx:Script>
      <![CDATA[
      import com.salesforce.AsyncResponder;
      import com.salesforce.objects.LoginRequest;
      import com.salesforce.results.LoginResult;
      import com.salesforce.results.QueryResult;
      import mx.collections.ArrayCollection;
      import mx.controls.Alert;
      import mx.rpc.AsyncRequest;
      private function init():void {
      var lr:LoginRequest = new LoginRequest();
      lr.username =
      'myusername'; // I have given my username here
      lr.password =
      'mypassword'; // I have given my password here
      lr.callback =
      new AsyncResponder(loadGrid);
      force.login(lr);
      private function loadGrid(lr:LoginResult):void {
      Alert.show(
      'Hi');
      force.query(
      "Select Id, FirstName, LastName From Contact",
      new AsyncResponder( function (qr:QueryResult):void {
      dgSolutions.dataProvider = qr.records;
      </fx:Script>
      </s:WindowedApplication>
      ANYHELP IN THIS REGARD WOULD BE REALLY APPRECIATED.
      THANKS IN ADVANCE.
