2 Replies Latest reply on Sep 27, 2010 8:57 AM by LuisRM
    Making a movie stop/fade out at a certain frame
    LuisRM Level 1
      I'm looking for some help with the following code. I'm using the code and assets from this page.
      http://www.kirupa.com/developer/flash8/snow.htm
      I'm creating ads for websites and they don't allow continual  animation after 3 loops. With some help, I added to the above code to make it fade at the end. I think I'm close, but it doesn't seem to fade away as I had hoped, it just keeps  falling.
      Am I missing some code that I need to replace?
      Do I need to put a frame # somewhere when I  want it to fade?
      Does the last part of the code go on a frame at the  end?
      The snow just keeps falling even though it's reached the last frame. What do I add to make it stop?
      I appreciate the help!
      Here is the code. The link above will show you exactly the type of animation I'm looking at. I added the fade part after "init ( );"
      init = function () {
          width = 300;
          // pixels
          height = 250;
          // pixels
          max_snowsize = 10;
          // pixels
          snowflakes = 50;
          // quantity
          for (i=0; i<snowflakes; i++) {
              t = attachMovie("snow", "snow"+i, i);
              t._alpha = 20+Math.random()*60;
              t._x = -(width/2)+Math.random()*(1.5*width);
              t._y = -(height/2)+Math.random()*(1.5*height);
              t._xscale = t._yscale=50+Math.random()*(max_snowsize*10);
              t.k = 1+Math.random()*2;
              t.wind = -1.5+Math.random()*(1.4*3);
              t.onEnterFrame = mover;
      mover = function() {
          this._y += this.k;
          this._x += this.wind;
          if (this._y>height+10) {
              this._y = -20;
          if (this._x>width+20) {
              this._x = -(width/2)+Math.random()*(1.5*width);
              this._y = -20;
          } else if (this._x<-20) {
              this._y = -20;
      init();
      function fadeOutAllSnow():Void {
          this.onEnterFrame = function() {
              if (snow._alpha>0) {
                  // 10 is the fade speed
                  snow._alpha -= 10;
              } else if (snow._alpha<=0) {
                  // we remove the cont_mc once its faded out
                  removeMovieClip("snow");
                  delete this.onEnterFrame;
        • 1. Re: Making a movie stop/fade out at a certain frame
          at some point you need to delete all those t.onEnterFrame methods.
          • 2. Re: Making a movie stop/fade out at a certain frame
            LuisRM Level 1
            I tried to cobble two different codes together before and it obviously wasn't working, but I'm better now since the code is from one source. I've attached the fla file for viewing. I'm just stuck as to how to fade the snow out by the last frame. I put a stop so it doesn't loop, but I just can't seem to figure out how to make that snow fade out properly at the last frame.
            http://www.mediafire.com/file/c3jl881lc0203fa/snow_test.zip
            [AS]stop();
            // Width of area
            var wNum:Number = Stage.width;
            // Height of area
            var hNum:Number = Stage.height;
            // Max size of item
            var maxSize:Number = 5;
            // Number of items
            var flakesNum:Number = 150;
            // Area outside of 0,0,wNum,hNum before reset
            var buffNum:Number = 30;
            var i:Number = 0;
            var t:MovieClip;
            // container MC
            var cont_mc:MovieClip;
            // Make it snow, confetti, whatever baby!
            startSnow();
            function startSnow():Void {
                // Make a MovieClip so we can Attach the snow into a container MC
                cont_mc = this.createEmptyMovieClip("cont_mc", 1);
                cont_mc._alpha = 0;
                for (i=0; i<flakesNum; i++) {
                    // Attach items into cont_mc
                    t = cont_mc.attachMovie("snow", "snow"+i, i);
                    t._x = -(wNum/2)+Math.random()*(1.5*wNum);
                    t._y = -(hNum/2)+Math.random()*(1.5*hNum);
                    t._xscale = t._yscale=50+Math.random()*(maxSize*10);
                    t.onEnterFrame = moveSnow;
                    if (cont_mc._alpha<100) {
                        cont_mc._alpha += 5;
                    } else if (cont_mc._alpha>=100) {
            function moveSnow():Void {
                // Added fade as it falls
                if (this._alpha>0) {
                    // .1 is the fade speed
                    this._alpha -= .1;
                this._y += this.k;
                if (this._y>hNum+buffNum) {
                    this._y = -buffNum;
                    // reset alpha once outside area
                    this._alpha = 20+Math.random()*60;
                if (this._x>wNum+buffNum) {
                    this._x = -(wNum/2)+Math.random()*(1.5*wNum);
                    this._y = -buffNum;
                } else if (this._x<-buffNum) {
                    this._y = -buffNum;
            // Fade Out, then remove
                    if (cont_mc._alpha>0) {
                        cont_mc._alpha -= 10;
                    } else if (cont_mc._alpha<=0) {
                        removeMovieClip("cont_mc");
            }[/AS]
            Again, I'm super new at code and have been trying to get the basics down at lynda.com, but it is tough. :confused:
            I really appreciate it!
