2 Replies Latest reply on Sep 25, 2010 10:41 AM by sboyse
    Special Formatting after Simple Calculation
    sboyse
      I've got a set form field that each asks for a numbers, does some math, and displays the results in a separate field.
      What I'd like it to do is simply add together all the inputs (not a problem) but then take the result and modify them as follows: If you can subtract 5 from the result and still get a positive real number, it also displays those number after it.
      For example:
      Input 4
      Output w/formatting: +4
      Input: 8
      Output w/formatting: +8/+3
      Input: 5, 3, 6, 7
      Output w/formatting: +21/+16/+11/+6/+1
      I'm beat after a days worth of syncing up fields, if someone could lob this one over the plate for me, I'd really appreciate it.
      (Adobe Acrobat 9 Pro)
        • 1. Re: Special Formatting after Simple Calculation
          George_Johnson MVP & Adobe Community Professional
          You can use the following as the custom Format script of the Total field, but you owe me a six-pack.
          (function () {
              // do nothing if field is blank
              if (!event.value) return;
              // get field value as a number
              var num = +event.value;
              var d = 5;          // divisor
              var s = "+" + num;  // begin building output string
              var it;             // number of iterations
              // determine remainder
              var r = num % d;
              // if remainer is not less than divisor...
              if (r !== num) {
                  // determine number of iterations
                  it = (num - r) / d;
                  // build up output string
                  for (var i = 0; i < it; i += 1) {
                      s += "/+" + (num - (d * (i + 1)));
              // display output string
              event.value = s;
          This code is based on the assumption that the input is a positive integer. If you don't already enforce that with a Keystroke/Validate script on this or other fields that this field value is based upon, you should.
          • 2. Re: Special Formatting after Simple Calculation
            sboyse Level 1
            If you don't already enforce, you should
            Done, and also that worked perfectly. Gotta love the people on Adobe forums, first rounds on me!
