2 Replies Latest reply on Sep 25, 2010 7:45 AM by enloz
    Problem: Dynamically add rich text
    enloz
      Hello to all,
      in advance sorry for my bad english,
      I have major problem and trying to solve it... for days...
      In basic, i want to add RichEditableText or TextArea in runtime, and have ability to bold, italic, change color,size, drag it etc. and change default text
      If anyone have any idea or solution i would be veery thankful
      This is my idea;
      Code:
                     xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600"  >
          <fx:Script>
              <![CDATA[
                  import spark.components.RichEditableText;
                  [Bindable]public var selID:int;
                  public var newID:int = new int(0)
                  public var ret:RichEditableText;
                  public var retTemp:RichEditableText;
                  protected function theClick(event:Event):void{
                      selID = event.target.id
                  protected function btnAdd_clickHandler(event:MouseEvent):void{
                      ret = new RichEditableText;
                      ret.text = "Rich Text"
                      ret.id = newID.toString()
                      ret.addEventListener(MouseEvent.CLICK,theClick)
                      hBox.addElementAt(ret,newID);
                      newID++
                  protected function btnBold_clickHandler(event:MouseEvent):void{
                      retTemp = hBox.getElementAt(selID) as RichEditableText
                      retTemp.setStyle("fontWeight","bold");
                      hBox.addElementAt(retTemp,selID);
                  protected function btnItalic_clickHandler(event:MouseEvent):void{
                      retTemp.setStyle("fontStyle","italic");
          </fx:Script>
          <mx:Label x="10" y="24" text="Selected ID: {selID.toString()}" id="idTxt"/>
          <mx:HBox x="10" y="53" width="565" height="44" id="hBox"  verticalAlign="middle">
          </mx:HBox>
          <s:Button x="10" y="117" label="Add" id="btnAdd" click="btnAdd_clickHandler(event)"/>
          <s:Button x="193" y="117" label="Italic" id="btnItalic" click="btnItalic_clickHandler(event)" />
          <s:Button x="115" y="117" label="Bold" id="btnBold" click="btnBold_clickHandler(event)"/>
      </s:Application>
      App works while "RichEditableText" text stays Rich Text, if you change text, it has no more ID
        • 1. Re: Problem: Dynamically add rich text
          lsxf_xin
          Why just read the Flex CookBook ,inside it tells how all most every UI control dynamically added to your application by AS.
          • 2. Re: Problem: Dynamically add rich text
            enloz Level 1
            ... I've searched CookBook
            For the App that I am trying to build, I need add RichText that have his own unique ID.
            If I use Canvas, Label,Button etc... in above code (replacing RichEditableText) it works fine but,
            in this case problem is when I change RichEditableText text, in this case "Rich Text", it's ID just vanish.
            ... if I setStyle ID remains
            If you have any specific solution other than "search CookBook"...please post it...
            Thanks in advance,
            PS:
            I've tried with
               import mx.core.UIComponent
               protected var uiComp:UIComponent
                       uiComp = UIComponent(event.target)
                       selID = uiComp.id
            ... and so on
            ... problem still remains
