8 Replies Latest reply: Sep 30, 2010 3:44 PM by auctioneer RSS
    How do I blend this HARD line?
    auctioneer Community Member
      Hi
      In the attached image I have circled an area at the end of my gradient I don't like, the edge of the gradient is too hard and noticeable.  How do I blend this so the end of gradient isn't so obvious?
      Thanks..
        • 1. Re: How do I blend this HARD line?
          Scott Falkner Community Member
          You could use a gradient mesh…
          Or create a blend…
          Or create a white to black gradient over your gradient and make it into an opacity mask (Transparency panel flyout menu)…
          • 2. Re: How do I blend this HARD line?
            Thanks Scott
            I've chosen the opacity mask option but I'm not having much luck.
            I've taken my rectangle tool and drawn over top of my gradient object.  In my layers pallet the only thing unlocked is the gradient object.  In my gradient panel I've selected a gradient (linear) at 45% black on the right, white left.
            Opened my transparency panel, selected 'make an opacity mask' from the flyout menu' and the only thing that happens is my entire gradient shows with no change to the right hard line.
            I must be missing a step ))-:
            Thx
            • 3. Re: How do I blend this HARD line?
              Joe Paris Community Member
              It sounds like you have only selected the b/w gradient and hit create opacity mask whereas you need to select both the gradient AND the object to be masked - your green gradient in this case.
              • 4. Re: How do I blend this HARD line?
                JETalmage Community Member
                Auctioneer,
                A basic but often overlooked principle is that you can blend between grad-fills.
                In graphics that will be re-purposed in many ways (like identity graphics), it's best to avoid objects (like opacity masks) that are going to end up being rasterized in many workflows. (In fact, in identity graphics, it's best to avoid contone elements entirely. For example: How will that graphic be rendered in a medium that can't do fine-grain halftone dots (like vinyl signage, embroidery, silkscreen, engraving, casting....)?
                JET
                • 5. Re: How do I blend this HARD line?
                  Here’s how I would blend between gradients. It is not clear to my coffee-straved brain that James did it this way, but he may have…
                  • 6. Re: How do I blend this HARD line?
                    Jacob Bugge CommunityMVP
                    Auctioneer,
                    To get a really soft and (partial rotational) symmetric transition, you may, after ticking the lower left Reference Point in the Transform palette/panel:
                    1) Add a quarter of a green circle at the end (same height);
                    2) Copy 1), reduce the size to almost nothing (the littler the bettler), and change the colour to the pale background colour;
                    3) Create a blend of 1) and 2) (smooth or with a suitable number of steps);
                    4) Extend the line at the bottom.
                    This will extend past the name.
                    To avoid that, you may shorten the normal gradient first, but it may look funny if the c ends floating in the background colour instead of resting on the green.
                    • 7. Re: How do I blend this HARD line?
                      Scott,
                      Do you use coffee blends or straight Yirgacheffe/Sidamo, and is it dry processed or washed?
                      • 8. Re: How do I blend this HARD line?
                        Sorry for not getting back sooner.  You guys have sure given me lots of 'food for thought'.  This just proves I've got lots to learn.  I appreciate all the input....thanks again!
