2 Replies Latest reply on Sep 26, 2010 10:30 PM by BhaskerChari
    how to change 'dataprovider' using 'states'
    Scaljeri
      Hi All
      I have 2 arrays and a HorizontalList. I want to be able to switch between the arrays using states. The states and horizontal list look like
      <mx:Array id="arr1">
      </mx:Array>
      <mx:states>
         <mx:State name="state1">
            <mx:SetProperty name="dataprovider" target="{horizontalList}">
               <mx:value>
                  arr1
               </mx:value>
            </mx:SetProperty>
         </mx:State>
         <mx:State name="state2">
               <mx:value>
                  arr2
               </mx:value>
            </mx:SetProperty>
         </mx:State>
      </mx:states>
      <mx:HorizontalList id="horizontalList"
        dataProvider="{arr1}"
      This code doesn't work, the mx:Value is probably not what I need. Any suggestions how to fix this ?
      thnx
      Luca
        • 1. Re: how to change 'dataprovider' using 'states'
          Anitha Selvaraj Level 2
          Small correction in your setProperty tag.
          Check the below code.
          <mx:SetProperty name="dataProvider" target="{horizontalList}" value="{arr1}" />
          Hope the code will work now.
          Regards,
          Anitha
          • 2. Re: how to change 'dataprovider' using 'states'
            BhaskerChari Level 4
            Hi Luca,
            Try the code below...
            Instead of  <mx:value>arr1</mx:value> assign the value in the SetProperty tag itself....as shown below
            <mx:SetProperty name="dataProvider" target="{horizontalList}" value="{arr1}">
            </mx:SetProperty>
            Also you have used the name of the property as dataprovider instead of dataProvider.(P should be uppercase)
            <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute">
              <mx:Object data='bar' label="bar1"/>
              <mx:Object data='bar' label="bar2"/>
              <mx:Object data='bar' label="bar3"/>
              <mx:Object data='bar' label="bar4"/>
              <mx:Object data='bar' label="bar5"/>
              <mx:Object data='bar' label="bar6"/>
            </mx:Array>
            <mx:Array id="arr2">
              <mx:Object data='bar' label="bar7"/>
              <mx:Object data='bar' label="bar8"/>
              <mx:Object data='bar' label="bar9"/>
              <mx:Object data='bar' label="bar10"/>
              <mx:Object data='bar' label="bar11"/>
              <mx:Object data='bar' label="bar12"/>
            </mx:Array>
            <mx:states>
                   </mx:SetProperty>
                </mx:State>
                   <mx:SetProperty name="dataProvider" target="{horizontalList}" value="{arr2}">
                   </mx:SetProperty>
                </mx:State>
            </mx:states>
            <mx:HorizontalList id="horizontalList"  dataProvider="{arr1}" labelField="label" height="100"/>
            <mx:HBox horizontalGap="5" top="200">
              <mx:Button id="btn1" label="Go to State1" click="this.currentState='state1'" />
              <mx:Button id="btn2" label="Go to State2" click="this.currentState='state2'" />
            </mx:HBox>
            </mx:Application>
            Bhasker
