4 Replies Latest reply on Nov 16, 2011 5:32 PM by pierre.rodrigue
    Flex spark dropdownlist to mySQL using php
    bertg1jm
      Hello. I am creating a flex app that uses php to populate several spark dropdownlists with strings from a mySQL database. The application is a MLB playoff bracket that allows the user to select their desired winners. Inside of a panel are text input boxes that ask for name and email address from the user. The submit button then calls a method called addNewUser(). I am having a very difficult time sending the selectedItem from each dropdownlist and the username and email to the database. I am able to add just the username into the database.  the table layout in the database is (user_id, user_name, email, alds_winner, alwcds_winner, nlds_winner, nlwcdc_winner, alcs_winner, nlcs_winner, ws_winner). As of now, Im just sending the user_name, email, and the nlds select from dropdownlist7 to the database as alds_winner. Ive tried so many things and am just confused on why its not working. The alert box that pops up on submit button click does display nldsSelect1 as "Twins" or whatever dropdownlist7 selectedItem is. Thanks for any help.
      PHP: newUser.php
      <?php
          $hostname_conn = "localhost";
          $username_conn = "admin";
          $password_conn = "admin";
          $conn = mysql_connect($hostname_conn, $username_conn, $password_conn);
          mysql_select_db("mlb_playoff_db");
          //mysql_real_escape_string POST'ed data for security purposes
          $newuser = mysql_real_escape_string($_POST["newuser"]);
          $newemail = mysql_real_escape_string($_POST["newemail"]);
          $nldsselect = mysql_real_escape_string($_POST["nldsselect"]);
          $sql = "INSERT INTO logins (user_name,email, alds_winner) VALUES ('$newuser', '$newemail', '$nldsselect')";
          if (!mysql_query($sql, $conn))
              echo "<status>Failed adding new user</status>";
          else
              echo "<status>New user added!</status>";
      mlb_playoff screenshot
      MXML: mlb_playoffs.mxml
                     xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" backgroundColor="#07002A"  xmlns:teamsservice2="services.teamsservice2.*" viewSourceURL="srcview/index.html">
          <fx:Script>
              <![CDATA[
                  import com.adobe.serializers.utility.TypeUtility;
                  import mx.controls.Alert;
                  import mx.controls.Text;
                  import mx.events.FlexEvent;
                  import mx.rpc.events.ResultEvent;
                  import spark.components.*;
                  import spark.components.supportClasses.DropDownController;
                  import spark.events.*;
                  [Bindable]
                  public var newUsername:String;
                  [Bindable]
                  public var newEmail:String;
                  [Bindable]
                  public var nldsSelect1:String;
                  [Bindable]
                  public var dataDump:String = "dataDump";
                  protected function addNewUser():void
                      newUsername = newUserTxt.text;
                      newEmail = newEmailTxt.text;
                      nldsSelect1 = dropDownList7.labelDisplay.text;
                      newUserTxt.text = "";
                      newEmailTxt.text = "";
                      Alert.show("DropDownList item selected: " + nldsSelect1);
                      newUser.send();
                  private function newUserResult(evt:ResultEvent):void
                      Alert.show(evt.result.status, "Result");
                      //getUsers.send();
                  protected function dropDownList_creationCompleteHandler(event:FlexEvent):void
                      getTeamsByIDResult.token = teamsService2.getTeamsByID(1);
                  protected function dropDownList2_creationCompleteHandler(event:FlexEvent):void
                      getTeamsByIDResult2.token = teamsService2.getTeamsByID(2);
                  protected function label2_creationCompleteHandler(event:FlexEvent):void
                      getTeamsByIDResult3.token = teamsService2.getTeamsByID(1);
                  protected function label3_creationCompleteHandler(event:FlexEvent):void
                      getTeamsByIDResult4.token = teamsService2.getTeamsByID(2);
                  protected function label4_creationCompleteHandler(event:FlexEvent):void
                      getTeamsByIDResult5.token = teamsService2.getTeamsByID(3);
                  protected function label5_creationCompleteHandler(event:FlexEvent):void
                      getTeamsByIDResult6.token = teamsService2.getTeamsByID(4);
                  protected function label6_creationCompleteHandler(event:FlexEvent):void
                      getTeamsByIDResult7.token = teamsService2.getTeamsByID(5);
                  protected function label7_creationCompleteHandler(event:FlexEvent):void
                      getTeamsByIDResult8.token = teamsService2.getTeamsByID(6);
                  protected function label8_creationCompleteHandler(event:FlexEvent):void
                      getTeamsByIDResult9.token = teamsService2.getTeamsByID(7);
                  protected function label9_creationCompleteHandler(event:FlexEvent):void
                      getTeamsByIDResult10.token = teamsService2.getTeamsByID(8);
                  protected function dropDownList3_creationCompleteHandler(event:FlexEvent):void
                      getTeamsByIDResult11.token = teamsService2.getTeamsByID(3);
                  protected function dropDownList5_creationCompleteHandler(event:FlexEvent):void
                      getTeamsByIDResult12.token = teamsService2.getTeamsByID(5);
                  protected function dropDownList4_creationCompleteHandler(event:FlexEvent):void
                      getTeamsByIDResult13.token = teamsService2.getTeamsByID(4);
                  protected function dropDownList6_creationCompleteHandler(event:FlexEvent):void
                      getTeamsByIDResult15.token = teamsService2.getTeamsByID(6);
                  protected function dropDownList7_creationCompleteHandler(event:FlexEvent):void
                      getTeamsByIDResult17.token = teamsService2.getTeamsByID(7);
                  protected function dropDownList8_creationCompleteHandler(event:FlexEvent):void
                      getTeamsByIDResult18.token = teamsService2.getTeamsByID(8);
                  /* protected function dropDownList9_creationCompleteHandler(event:FlexEvent):void
                      getTeamsByDivID.token = teamsService2.getTeamsByDivID(1);
                      getTeamsByDivIDResult.token = teamsService2.getTeamsByDivID(1);
                  protected function dropDownList10_creationCompleteHandler(event:FlexEvent):void
                      getTeamsByDivIDResult2.token = teamsService2.getTeamsByDivID(2);
                  protected function dropDownList11_creationCompleteHandler(event:FlexEvent):void
                      getTeamsByLeagueIDResult.token = teamsService2.getTeamsByLeagueID(1);
                  protected function dropDownList12_creationCompleteHandler(event:FlexEvent):void
                      getTeamsByDivIDResult4.token = teamsService2.getTeamsByDivID(3);
                  protected function dropDownList13_creationCompleteHandler(event:FlexEvent):void
                      getTeamsByDivIDResult5.token = teamsService2.getTeamsByDivID(4);
                  protected function dropDownList14_creationCompleteHandler(event:FlexEvent):void
                      getTeamsByLeagueIDResult2.token = teamsService2.getTeamsByLeagueID(2);
                  protected function dropDownList15_creationCompleteHandler(event:FlexEvent):void
                      getAllTeamsResult4.token = teamsService2.getAllTeams();
          </fx:Script>
          <fx:Declarations>
              <s:CallResponder id="getTeamsByIDResult"/>
              <teamsservice2:TeamsService2 id="teamsService2" fault="Alert.show(event.fault.faultString + '\n' + event.fault.faultDetail)" showBusyCursor="true"/>
              <s:CallResponder id="getTeamsByIDResult2"/>
              <s:CallResponder id="getTeamsByIDResult3"/>
              <s:CallResponder id="getTeamsByIDResult4"/>
              <s:CallResponder id="getTeamsByIDResult5"/>
              <s:CallResponder id="getTeamsByIDResult6"/>
              <s:CallResponder id="getTeamsByIDResult7"/>
              <s:CallResponder id="getTeamsByIDResult8"/>
              <s:CallResponder id="getTeamsByIDResult9"/>
              <s:CallResponder id="getTeamsByIDResult10"/>
              <s:CallResponder id="getTeamsByIDResult11"/>
              <s:CallResponder id="getTeamsByIDResult12"/>
              <s:CallResponder id="getTeamsByIDResult13"/>
              <s:CallResponder id="getTeamsByIDResult14"/>
              <s:CallResponder id="getTeamsByIDResult15"/>
              <s:CallResponder id="getTeamsByIDResult16"/>
              <s:CallResponder id="getTeamsByIDResult17"/>
              <s:CallResponder id="getTeamsByIDResult18"/>
              <s:CallResponder id="getAllTeamsResult"/>
              <s:CallResponder id="getTeamsByDivID"/>
              <s:CallResponder id="getAllTeamsResult2"/>
              <s:CallResponder id="getTeamsByDivIDResult"/>
              <s:CallResponder id="getTeamsByDivIDResult2"/>
              <s:CallResponder id="getTeamsByDivIDResult3"/>
              <s:CallResponder id="getTeamsByDivIDResult4"/>
              <s:CallResponder id="getTeamsByDivIDResult5"/>
              <s:CallResponder id="getTeamsByIDResult19"/>
              <s:CallResponder id="getTeamsByIDResult20"/>
              <s:CallResponder id="getAllTeamsResult3"/>
              <s:CallResponder id="getTeamsByLeagueIDResult"/>
              <s:CallResponder id="getTeamsByLeagueIDResult2"/>
              <s:CallResponder id="getAllTeamsResult4"/>
              <mx:HTTPService id="newUser" url="newUser.php" method="POST" result="newUserResult(event)">
                  <mx:request xmlns="">
                      <newuser>{newUsername}</newuser>
                      <newuser>{newEmail}</newuser>
                      <nldsselect>{nldsSelect1}</nldsselect>
                  </mx:request>
              </mx:HTTPService>
              <s:CallResponder id="updateTeamsResult"/>
          </fx:Declarations>
          <s:DropDownList x="109.35" y="141.05" id="dropDownList" prompt = "NL West" creationComplete="dropDownList_creationCompleteHandler(event)" labelField="division_champ" contentBackgroundColor="#F8F8F8" chromeColor="#F5F5F5" rollOverColor="#3035FF" selectionColor="#FF3C3C" focusColor="#9B9B9B" fontFamily="Georgia" dropShadowVisible="true" borderColor="#C8C8C8" requireSelection="true" >
              <s:AsyncListView list="{TypeUtility.convertToCollection(getTeamsByIDResult.lastResult)}"/>
          </s:DropDownList>
          <s:DropDownList x="109.3" y="252.55" id="dropDownList2" prompt = "NL East" creationComplete="dropDownList2_creationCompleteHandler(event)" labelField="division_champ" contentBackgroundColor="#F8F8F8" chromeColor="#F5F5F5" rollOverColor="#3035FF" selectionColor="#FF3C3C" focusColor="#9B9B9B" fontFamily="Georgia" dropShadowVisible="true" borderColor="#C8C8C8" requireSelection="true">
              <s:AsyncListView list="{TypeUtility.convertToCollection(getTeamsByIDResult2.lastResult)}"/>
          </s:DropDownList>
          <s:DropDownList x="108.85" y="335.9" id="dropDownList3" prompt = "NL Central" creationComplete="dropDownList3_creationCompleteHandler(event)" labelField="division_champ" contentBackgroundColor="#F8F8F8" chromeColor="#F5F5F5" rollOverColor="#3035FF" selectionColor="#FF3C3C" focusColor="#9B9B9B" fontFamily="Georgia" dropShadowVisible="true" borderColor="#C8C8C8" requireSelection="true">
              <s:AsyncListView list="{TypeUtility.convertToCollection(getTeamsByIDResult11.lastResult)}"/>
          </s:DropDownList>
          <s:DropDownList x="108.35" y="447.25" id="dropDownList4" prompt = "NL Wildcard" labelField="division_champ" creationComplete="dropDownList4_creationCompleteHandler(event)" contentBackgroundColor="#F8F8F8" chromeColor="#F5F5F5" rollOverColor="#3035FF" selectionColor="#FF3C3C" focusColor="#9B9B9B" fontFamily="Georgia" dropShadowVisible="true" borderColor="#C8C8C8" requireSelection="true">
              <s:AsyncListView list="{TypeUtility.convertToCollection(getTeamsByIDResult13.lastResult)}"/>
          </s:DropDownList>
          <s:DropDownList x="733.1" y="141.55" id="dropDownList5" prompt = "AL West" creationComplete="dropDownList5_creationCompleteHandler(event)" labelField="division_champ" selectionColor="#FF3C3C" rollOverColor="#3035FF" fontFamily="Georgia" dropShadowVisible="true" borderColor="#C8C8C8">
              <s:AsyncListView list="{TypeUtility.convertToCollection(getTeamsByIDResult12.lastResult)}"/>
          </s:DropDownList>
          <s:DropDownList x="733.05" y="253.05" id="dropDownList6" prompt = "AL East" creationComplete="dropDownList6_creationCompleteHandler(event)" labelField="division_champ" selectionColor="#FF3C3C" rollOverColor="#3035FF" fontFamily="Georgia" dropShadowVisible="true" borderColor="#C8C8C8">
              <s:AsyncListView list="{TypeUtility.convertToCollection(getTeamsByIDResult15.lastResult)}"/>
          </s:DropDownList>
          <s:DropDownList x="733.05" y="336.35" id="dropDownList7" prompt = "AL Central" creationComplete="dropDownList7_creationCompleteHandler(event)" labelField="division_champ" selectionColor="#FF3C3C" rollOverColor="#3035FF" fontFamily="Georgia" dropShadowVisible="true" borderColor="#C8C8C8">
              <s:AsyncListView list="{TypeUtility.convertToCollection(getTeamsByIDResult17.lastResult)}"/>
          </s:DropDownList>
          <s:DropDownList x="733.1" y="447.7" id="dropDownList8" prompt = "AL Wildcard" creationComplete="dropDownList8_creationCompleteHandler(event)" labelField="division_champ" selectionColor="#FF3C3C" rollOverColor="#3035FF" fontFamily="Georgia" dropShadowVisible="true" borderColor="#C8C8C8">
              <s:AsyncListView list="{TypeUtility.convertToCollection(getTeamsByIDResult18.lastResult)}"/>
          </s:DropDownList>
          <mx:HRule x="105.65" y="169.45" width="148"/>
          <mx:HRule x="105.3" y="280.95" width="148"/>
          <mx:VRule x="251.65" y="170.1" height="113"/>
          <mx:HRule x="105.65" y="364.45" width="148"/>
          <mx:HRule x="105.3" y="475.95" width="148"/>
          <mx:VRule x="251.65" y="365.1" height="113"/>
          <mx:HRule x="252.65" y="267.45" width="148"/>
          <mx:HRule x="399.1" y="296.2" width="121"/>
          <mx:HRule x="433.05" y="349.75" width="121"/>
          <mx:HRule x="252.3" y="378.95" width="148"/>
          <mx:VRule x="398.65" y="268.1" height="113"/>
          <mx:HRule x="701.55" y="169.35" width="148"/>
          <mx:HRule x="701.2" y="280.85" width="148"/>
          <mx:VRule x="700.55" y="170" height="113"/>
          <mx:HRule x="701.55" y="364.35" width="148"/>
          <mx:HRule x="701.2" y="475.85" width="148"/>
          <mx:VRule x="700.55" y="365" height="113"/>
          <mx:HRule x="553.15" y="267.4" width="148"/>
          <mx:HRule x="552.8" y="378.9" width="148"/>
          <mx:VRule x="552.15" y="268.05" height="113"/>
          <s:DropDownList x="276" y="238"  id="dropDownList9" prompt = "NLDS" creationComplete="dropDownList9_creationCompleteHandler(event)" labelField="division_champ" contentBackgroundColor="#F8F8F8" chromeColor="#F5F5F5" rollOverColor="#3035FF" selectionColor="#FF3C3C" focusColor="#9B9B9B" fontFamily="Georgia" dropShadowVisible="true" borderColor="#C8C8C8">
              <s:AsyncListView list="{TypeUtility.convertToCollection(getTeamsByDivIDResult.lastResult)}"/>
          </s:DropDownList>
          <s:Label x="117.75" y="60.95" text="NLDS" fontSize="21" fontFamily="Georgia" width="84" height="31" color="#FFFFFF"/>
          <s:Label x="291.5" y="61" text="NLCS" fontSize="21" fontFamily="Georgia" width="84" height="31" color="#FFFFFF"/>
          <s:DropDownList x="275" y="349" id="dropDownList10" prompt = "NLDS" creationComplete="dropDownList10_creationCompleteHandler(event)" labelField="division_champ" contentBackgroundColor="#F8F8F8" chromeColor="#F5F5F5" rollOverColor="#3035FF" selectionColor="#FF3C3C" focusColor="#9B9B9B" fontFamily="Georgia" dropShadowVisible="true" borderColor="#C8C8C8">
              <s:AsyncListView list="{TypeUtility.convertToCollection(getTeamsByDivIDResult2.lastResult)}"/>
          </s:DropDownList>
          <s:DropDownList x="566" y="238" id="dropDownList12" prompt = "ALDS" creationComplete="dropDownList12_creationCompleteHandler(event)" labelField="division_champ" selectionColor="#FF3C3C" rollOverColor="#3035FF" fontFamily="Georgia" dropShadowVisible="true" borderColor="#C8C8C8">
              <s:AsyncListView list="{getTeamsByDivIDResult4.lastResult}"/></s:DropDownList>
          <s:DropDownList x="566" y="349" id="dropDownList13" prompt = "ALDS" creationComplete="dropDownList13_creationCompleteHandler(event)" labelField="division_champ" selectionColor="#FF3C3C" rollOverColor="#3035FF" fontFamily="Georgia" dropShadowVisible="true" borderColor="#C8C8C8">
              <s:AsyncListView list="{getTeamsByDivIDResult5.lastResult}"/></s:DropDownList>
          <s:DropDownList x="408" y="267" id="dropDownList11" prompt = "NLCS" creationComplete="dropDownList11_creationCompleteHandler(event)" labelField="division_champ" chromeColor="#F5F5F5" selectionColor="#FF3C3C" rollOverColor="#3035FF" focusColor="#9B9B9B" fontFamily="Georgia" dropShadowVisible="true" borderColor="#C8C8C8">
              <s:AsyncListView list="{TypeUtility.convertToCollection(getTeamsByLeagueIDResult.lastResult)}"/>
          </s:DropDownList>
          <s:DropDownList x="433" y="360" id="dropDownList14" prompt = "ALCS" creationComplete="dropDownList14_creationCompleteHandler(event)" labelField="division_champ" selectionColor="#FF3C3C" rollOverColor="#3035FF" fontFamily="Georgia" dropShadowVisible="true" borderColor="#C8C8C8">
              <s:AsyncListView list="{TypeUtility.convertToCollection(getTeamsByLeagueIDResult2.lastResult)}"/>
          </s:DropDownList>
          <s:Label x="612.35" y="61.45" text="ALCS" fontSize="21" fontFamily="Georgia" width="84" height="31" color="#FFFFFF"/>
          <s:Label x="786.1" y="61.5" text="ALDS" fontSize="21" fontFamily="Georgia" width="84" height="31" color="#FFFFFF"/>
          <s:Label x="13" y="150" text="{getTeamsByIDResult3.lastResult.division}" color="#FFFFFF" id="label2" creationComplete="label2_creationCompleteHandler(event)"/>
          <s:Label x="13" y="260.95" text="{getTeamsByIDResult4.lastResult.division}" color="#FFFFFF" id="label3" creationComplete="label3_creationCompleteHandler(event)"/>
          <s:Label x="13" y="344.8" text="{getTeamsByIDResult5.lastResult.division}" color="#FFFFFF" id="label4" creationComplete="label4_creationCompleteHandler(event)"/>
          <s:Label x="13" y="456.75" text="{getTeamsByIDResult6.lastResult.division}" color="#FFFFFF" id="label5" creationComplete="label5_creationCompleteHandler(event)"/>
          <s:Label x="865.8" y="150" text="{getTeamsByIDResult7.lastResult.division}" color="#FFFFFF" id="label6" creationComplete="label6_creationCompleteHandler(event)" textAlign="right"/>
          <s:Label x="865.8" y="260.95" text="{getTeamsByIDResult8.lastResult.division}" color="#FFFFFF" id="label7" creationComplete="label7_creationCompleteHandler(event)" textAlign="right"/>
          <s:Label x="865.8" y="344.8" text="{getTeamsByIDResult9.lastResult.division}" color="#FFFFFF" id="label8" creationComplete="label8_creationCompleteHandler(event)" textAlign="right"/>
          <s:Label x="865.8" y="456.75" text="{getTeamsByIDResult10.lastResult.division}" color="#FFFFFF" id="label9" creationComplete="label9_creationCompleteHandler(event)" textAlign="right"/>
          <s:DropDownList x="421" y="314" id="dropDownList15" prompt = "World Series" creationComplete="dropDownList15_creationCompleteHandler(event)" labelField="division_champ" selectionColor="#FF3C3C" rollOverColor="#3035FF" fontFamily="Georgia" dropShadowVisible="true" borderColor="#C8C8C8">
              <s:AsyncListView list="{getAllTeamsResult4.lastResult}"/>
          </s:DropDownList>
          <s:Label x="371.85" y="127.7" text="2010 World Series" width="187" height="76" fontSize="23" color="#D1D1D1" fontFamily="Verdana" verticalAlign="top" textAlign="center" fontWeight="bold"/>
          <s:Panel x="382" y="420" width="181" height="145" title=" Submit Your Bracket" color="#4229FF" fontSize="13" textAlign="left" fontFamily="Verdana">
              <s:TextInput x="51.85" y="10" width="121" height="24" id="newUserTxt" contentBackgroundColor="#4B4BFF" color="#FFFFFF" borderVisible="true" borderAlpha="1.0"/>
              <s:TextInput x="51.85" y="44" width="121" height="24" id="newEmailTxt" contentBackgroundColor="#4B4BFF" color="#FFFFFF" borderVisible="true" borderAlpha="1.0"/>
              <s:Label x="4" y="17" text="NAME" fontFamily="Arial" fontWeight="bold" color="#000000" fontSize="16"/>
              <s:Label x="2" y="53" text="EMAIL" fontFamily="Arial" fontWeight="bold" color="#000000" fontSize="16"/>
              <s:Button x="54" y="77" label="Submit" click="addNewUser() ; "/>
          </s:Panel>
      </s:Application>
