1 Reply Latest reply on Oct 21, 2010 9:08 AM by Barqx
    [InD. CS5 Server][JS] XML-Import, how to receive data?
      Hello everybody!
      I tried to import an simple XML with the ExtendScript Toolkit on InDesign CS5 Server with the following script:
      var myXmlFile = new File("../path/blubb.xml");
      var myContent;
      myXmlFile.open("r", undefined, undefined);
           myContent = myXmlFile.read();
           var xml_value = myContent.childNodes[0].getElementsByTagName('ROOT').nodeValue;
           //var xml_value = myContent.getElementsByTagName('ROOT').item(0).firstChild.nodeValue;
      the XML-FIle is this:
      <?xml version="1.0" encoding="UTF-8"?>
      If i alert myContent, there is the whole XML in the terminal output in one line. And the console of the ExtendScript Toolkit says "Execution finished. Ergebnis: undefined". (why is the result: unfinished?)
      Now i tried to get some nodeValues in different ways (from different tutorials) but sometimes theres an error "myContent.getElementsByTagName is not a function". So i tried different ways, without this functions but if i tried to access the nodes like this:
      var xml_value = myContent.item[0];
      or some other compositions with "firstChild", "item[x]" and "nodeValue", there is the error message "undefined is not an object".
      Could anyone please give me a hint, how to read the xml-data in a loop? I need to parse some XML-FIles from InDesign-CS2-Documents and create new InDesign-CS5-Documents, but stucked already at the first step...
      Thanks for your reponses!
