8 Replies Latest reply on Jul 13, 2011 3:48 AM by Aldo Marsilio
    Flash Bulder+MySQL,PHP - Channel disconnected before an acknowledgement was received
    simPod_
      Hi, I tried some basics with Flash Builder and PHP MySQL. I walked throught this tutorial http://www.flashrealtime.com/flash-builder-4-and-php-data-services/ but when I added a function btnSearch_clickHandler and launched the project in browser to test it, it gave me this error:
      I don't know why is this happening. I followed the tutorial step by step. The only difference is that I use Windows 7 with WAMP and Tomas uses MacOS with MAMP
      I uploaded my project http://www.mediafire.com/file/6ri44igt1hbssrf/phpConnect.zip , can someone take a look at it please? Thanks
        • 1. Re: Flash Bulder+MySQL,PHP - Channel disconnected before an acknowledgement was received
          SunilAdobe Adobe Employee
          What does it tell when you use the Test operation to call the same operation in Flash Builder?
          Sunil
          • 2. Re: Flash Bulder+MySQL,PHP - Channel disconnected before an acknowledgement was received
            simPod_ Level 1
            Test operation - Service: EmployeesService; Operation: getAllEmployees
            InvocationTargetException:There was an error while  invoking the operation. Check your operation inputs or server code and try  invoking the operation again.
            Reason:
            Warning:  mysqli_connect() expects parameter 5 to be long, string given in  C:\wamp\www\phpConnect\services\EmployeesService.php on line  44
            Warning: mysqli_error() expects parameter 1 to be  mysqli, null given in  C:\wamp\www\phpConnect\services\EmployeesService.php on line  259
            Warning: mysqli_prepare() expects parameter 1 to be  mysqli, null given in  C:\wamp\www\phpConnect\services\EmployeesService.php on line  60
            Warning: mysqli_stmt_execute() expects parameter 1 to  be mysqli_stmt, null given in  C:\wamp\www\phpConnect\services\EmployeesService.php on line  64
            Warning: mysqli_stmt_bind_result() expects parameter 1  to be mysqli_stmt, null given in  C:\wamp\www\phpConnect\services\EmployeesService.php on line  69
            Warning: mysqli_stmt_fetch() expects parameter 1 to be  mysqli_stmt, null given in  C:\wamp\www\phpConnect\services\EmployeesService.php on line  71
            Warning: mysqli_stmt_free_result() expects parameter 1  to be mysqli_stmt, null given in  C:\wamp\www\phpConnect\services\EmployeesService.php on line  77
            Warning: mysqli_close() expects parameter 1 to be  mysqli, null given in  C:\wamp\www\phpConnect\services\EmployeesService.php on line  78
                /0/onResult˙˙˙˙ � Uflex.messaging.messages.AcknowledgeMessage correlationId clientId destination messageId timestamp timeToLive headers  body IC8EF4525-730F-BAB2-DBAB-83FBBE072AC9 I65CC210E-A04D-CC48-4ADA-000037765A55  I06052A08-C992-9588-1B12-00005079FAB8  128561039300
            And the PHP file is like this:
            <?php
            *  README for sample service
            *  This generated sample service contains functions that illustrate typical service operations.
            *  Use these functions as a starting point for creating your own service implementation. Modify the
            *  function signatures, references to the database, and implementation according to your needs.
            *  Delete the functions that you do not use.
            *  Save your changes and return to Flash Builder. In Flash Builder Data/Services View, refresh
            *  the service. Then drag service operations onto user interface components in Design View. For
            *  example, drag the getAllItems() operation onto a DataGrid.
            *  This code is for prototyping only.
            *  Authenticate the user prior to allowing them to call these methods. You can find more
            *  information at http://www.adobe.com/go/flex_security
            class EmployeesService {
                var $username = "root";
                var $password = "";
                var $server = "localhost";
                var $port = "";
                var $databasename = "test";
                var $tablename = "employees";
                var $connection;
                 * The constructor initializes the connection to database. Everytime a request is
                 * received by Zend AMF, an instance of the service class is created and then the
                 * requested method is invoked.
                public function __construct() {
                      $this->connection = mysqli_connect(
                                              $this->server,
                                              $this->username,
                                              $this->password,
                                              $this->databasename,
                                              $this->port
                    $this->throwExceptionOnError($this->connection);
                 * Returns all the rows from the table.
                 * Add authroization or any logical checks for secure access to your data
                 * @return array
                public function getAllEmployees($q) {
                $sql = "SELECT * FROM $this->tablename WHERE first_name LIKE '%$q%' OR last_name LIKE '%$q%' OR email_address LIKE '%$q%'";
                $stmt = mysqli_prepare($this->connection,$sql);
                $this->throwExceptionOnError();
                mysqli_stmt_execute($stmt);
                $rows = array();
                mysqli_stmt_bind_result($stmt, $row->emp_no, $row->birth_date, $row->first_name, $row->last_name, $row->gender, $row->hire_date, $row->phone_no, $row->email_address, $row->job_title);
                while (mysqli_stmt_fetch($stmt)) {
                  $rows[] = $row;
                  $row = new stdClass();
                mysqli_stmt_free_result($stmt);
                mysqli_close($this->connection);
                return $rows;
                 * Returns the item corresponding to the value specified for the primary key.
                 * Add authorization or any logical checks for secure access to your data
                 * @return stdClass
                public function getEmployeesByID($itemID) {
                    $stmt = mysqli_prepare($this->connection, "SELECT * FROM $this->tablename where emp_no=?");
                    mysqli_stmt_bind_param($stmt, 'i', $itemID);
                    if(mysqli_stmt_fetch($stmt)) {
                      $row->birth_date = new DateTime($row->birth_date);
                      $row->hire_date = new DateTime($row->hire_date);
                      return $row;
                    } else {
                      return null;
                 * @return stdClass
                public function createEmployees($item) {
                    $stmt = mysqli_prepare($this->connection, "INSERT INTO $this->tablename (birth_date, first_name, last_name, gender, hire_date, phone_no, email_address, job_title) VALUES (?, ?, ?, ?, ?, ?, ?, ?)");
                    mysqli_stmt_bind_param($stmt, 'ssssssss', $item->birth_date->toString('YYYY-MM-dd HH:mm:ss'), $item->first_name, $item->last_name, $item->gender, $item->hire_date->toString('YYYY-MM-dd HH:mm:ss'), $item->phone_no, $item->email_address, $item->job_title);
                    $autoid = mysqli_stmt_insert_id($stmt);
                    return $autoid;
                 * Updates the passed item in the table.
                 * @param stdClass $item
                 * @return void
                public function updateEmployees($item) {
                    $stmt = mysqli_prepare($this->connection, "UPDATE $this->tablename SET birth_date=?, first_name=?, last_name=?, gender=?, hire_date=?, phone_no=?, email_address=?, job_title=? WHERE emp_no=?");
                    mysqli_stmt_bind_param($stmt, 'ssssssssi', $item->birth_date->toString('YYYY-MM-dd HH:mm:ss'), $item->first_name, $item->last_name, $item->gender, $item->hire_date->toString('YYYY-MM-dd HH:mm:ss'), $item->phone_no, $item->email_address, $item->job_title, $item->emp_no);
                 * Deletes the item corresponding to the passed primary key value from
                 * the table.
                 * @return void
                public function deleteEmployees($itemID) {
                    $stmt = mysqli_prepare($this->connection, "DELETE FROM $this->tablename WHERE emp_no = ?");
                 * Returns the number of rows in the table.
                public function count() {
                    $stmt = mysqli_prepare($this->connection, "SELECT COUNT(*) AS COUNT FROM $this->tablename");
                    mysqli_stmt_bind_result($stmt, $rec_count);
                    mysqli_stmt_fetch($stmt);
                    return $rec_count;
                 * Returns $numItems rows starting from the $startIndex row from the
                 * table.
                 * @return array
                public function getEmployees_paged($startIndex, $numItems) {
                    $stmt = mysqli_prepare($this->connection, "SELECT * FROM $this->tablename LIMIT ?, ?");
                    mysqli_stmt_bind_param($stmt, 'ii', $startIndex, $numItems);
                    $rows = array();
                      $rows[] = $row;
                    return $rows;
                 * Utility function to throw an exception if an error occurs
                 * while running a mysql command.
                private function throwExceptionOnError($link = null) {
                    if($link == null) {
                        $link = $this->connection;
                    if(mysqli_error($link)) {
                        $msg = mysqli_errno($link) . ": " . mysqli_error($link);
                        throw new Exception('MySQL Error - '. $msg);
            • 3. Re: Flash Bulder+MySQL,PHP - Channel disconnected before an acknowledgement was received
              So, looks like there are errors when passing parameters, can you check your code are just hardcode the parameters for time being to check whether everything is working fine.
              -Sunil
              • 4. Re: Flash Bulder+MySQL,PHP - Channel disconnected before an acknowledgement was received
                simPod_ Level 1
                Ok, I tried to not to change the generated PHP code and launch function getAllEmployeesResult.token = employeesService.getAllEmployees(); instead of getAllEmployeesResult.token = employeesService.getAllEmployees(txtSearch.text);
                still the same error
                • 5. Re: Flash Bulder+MySQL,PHP - Channel disconnected before an acknowledgement was received
                  What is the error when you try to run it from Test operation from the Data/Services panel?
                  • 6. Re: Flash Bulder+MySQL,PHP - Channel disconnected before an acknowledgement was received
                    simPod_ Level 1
                    Reason:
                    Warning: mysqli_error() expects parameter 1 to be  mysqli, null given in  C:\wamp\www\phpConnect\services\EmployeesService.php on line  258
                    Warning: mysqli_prepare() expects parameter 1 to be  mysqli, null given in  C:\wamp\www\phpConnect\services\EmployeesService.php on line  58
                    Warning: mysqli_stmt_execute() expects parameter 1 to  be mysqli_stmt, null given in  C:\wamp\www\phpConnect\services\EmployeesService.php on line  61
                    Warning: mysqli_stmt_bind_result() expects parameter 1  to be mysqli_stmt, null given in  C:\wamp\www\phpConnect\services\EmployeesService.php on line  66
                    Warning: mysqli_stmt_fetch() expects parameter 1 to be  mysqli_stmt, null given in  C:\wamp\www\phpConnect\services\EmployeesService.php on line  68
                    Warning: mysqli_stmt_free_result() expects parameter 1  to be mysqli_stmt, null given in  C:\wamp\www\phpConnect\services\EmployeesService.php on line  76
                    Warning: mysqli_close() expects parameter 1 to be  mysqli, null given in  C:\wamp\www\phpConnect\services\EmployeesService.php on line  77
                        /0/onResult˙˙˙˙ � Uflex.messaging.messages.AcknowledgeMessage correlationId clientId destination messageId timestamp timeToLive headers  body I22F739C2-7008-D1FF-4C6F-C37EF031B6F4 I37DE091D-AC33-2488-4A61-00002154B7E3  I204A7F21-8C87-90C9-E2B3-0000211F7CC6  128622908400
                    • 7. Re: Flash Bulder+MySQL,PHP - Channel disconnected before an acknowledgement was received
                      Unisda
                      i know this is an old post but in case someone stumbles onto it with the same problem, having just started with Flex, and using Xampp I had the same problem, but once I specified the port to mysql as 3306 - this problem stopped.
                      Hope it helps.
                      • 8. Re: Flash Bulder+MySQL,PHP - Channel disconnected before an acknowledgement was received
                        Aldo Marsilio
                        Even if you are using Wamp it's the same, I want to remind you that you have to use port 3306 during the connection setup inside your Flex IDE.20110713-i19-281kb.jpg
                        Message was edited by Aldo Marsilio www.flashbackstage.com
                        Message was edited by: aldo marsilio
