5 Replies Latest reply on Sep 27, 2010 7:50 AM by Radu Cristian Dimitrie
    Complex Names
      maybe there might have been a discussion just like this, but i don't even know how ot search the internet..
      Pseudocode:
      var array1;
      var array2;
      var array3;
      case 1:
           myFunction(1);
      case 2:
           myFunction(2);
      case 3:
           myFunction(3);
      function myFunction(myNumber)
           a = ["array"+myNumber];
           b = ["array"+(myNumber+1)];
           trace(a) //output is array1 but is not the array1 that i declared, it's only a string
      How do i point it to the array i want?
        • 1. Re: Complex Names
          Radu Cristian Dimitrie Level 1
          Solved
          It needed a source to get the arrays from..
          var array1 = [1,2,3];
          var array2 = [2,3,4];
          var array3 = [4,5,6];
          case 1:
               myFunction(1, this);
          case 2:
               myFunction(2, this);
          case 3:
               myFunction(3, this);
          function myFunction(myNumber, from)
               a = from["array"+myNumber];
               b = from["array"+(myNumber+1)];
               trace(a) // output is:  1,2,3
               trace(b) // output is:  2,3,4
          • 2. Re: Complex Names
            use array notation to coerce flash to convert strings as objects:
            var tl:MovieClip = this
                 var a:Array = tl["array"+myNumber];
                 var b:Array = tl["array"+(myNumber+1)];
                 trace(a);
            • 3. Re: Complex Names
              you'll need to be careful about the location of your function calls if you use your code.  you can easily be out of scope of the timeline where your arrays are defined.
              it's better to use the code i suggested.
              • 4. Re: Complex Names
                what this does, or at least should do, is return an array of neighbouring tiles from the unit's location depending on it's moving points..
                the pseudo code:
                if moving points > 1 { get neighbours and put them in array1}
                if moving points > 2 { get neighbours for each element in array1, and put them in array2 and final array} (calls function 'getNextRange')
                if moving points > 3 { get neighbours for each element in array2, and put them in array3 and final array} (calls function 'getNextRange')
                function getRange(from) //from is the soldier
                     rangeArray1 = new Array();
                     rangeArray2 = new Array();
                     rangeArray3 = new Array();
                     rangeArray4 = new Array();
                     rangeArray5 = new Array();
                     rangeArrayF = new Array();
                     range = from.MP; //Mp = moving points
                     place = from.place; //place = the tile that the unit is standing on
                     if (range > 0)
                          range1 = _root.getNeighbours(place);
                          for (i = 0; i < 6; i++)
                               rangeArray1.push(range1[i]);
                               rangeArrayF.push(range1[i]);
                     if (range > 1)
                             getNextRange(1, this);
                        if (range > 2)
                             getNextRange(2);
                //      if (range > 3)
                //          getNextRange(3);
                //     if (range > 4)
                //          getNextRange(4);
                     function getNextRange(no, from)
                          a = from["rangeArray" + 1];
                          b = from["rangeArray" + (no+1)];
                          for (i = 0; i < a.length; i++)
                               b.push(a[i]);
                               for (j = 0; j < 7; j++)
                                    b.push(_root.getNeighbours(a[i][j]));
                                    rangeArrayF.push(_root.getNeighbours(a[i][j]));
                          b = b.getUniqueValues();
                     Array.prototype.getUniqueValues = function() //returns array without duplicates
                     rangeArrayF = rangeArrayF.getUniqueValues();
                     return rangeArrayF;
                function getNeighbours returns an array of 6 elements, because it's a hexagonal tiled game, so i need to loop trough each 0 > 5 index element to push it to other array..
                although it identifies the arrays a and b in the getNextRange function, there something messed up i need to find and fix, because function doesn't return what it should..
                • 5. Re: Complex Names
                  i solved the function getNextRange..
                  i misplaced the 'j':
                  b.push(_root.getNeighbours( a[i][j]) ); is wrong
                  b.push(_root.getNeighbours( a[i])[j] ); is correct
                  if you have any other suggestions i welcome them
