3 Replies Latest reply on Sep 27, 2010 1:39 PM by hernanls
    Advanced Datagrid dinamical pagination Component
    balhk
      Hi everyone,
      I'm a new developer in flex, (like 1 year ...) and I developed this dinamic Advanced Data Grid pagination component.
      • Why I did this?
        • I stumbled across an issue to show just a few lines from a really long list of objects from the dataProvider of my datagrid.
      • yeah, right .. but dinamic ?
        • sure it is dinamic, why not? This component don't have columns, you can add any quantity of columns with any format you need.
      • but, What about the dataProvider?
        • as we use and AdvancedDataGrid, the source of dataProvider, is an object, in the case I felt better using an ArrayCollection, cause it fits almost everything that provides; we can have an arrayCollection of XML, classes .. and that kind of stuff.
      • the number of rows in the dataGrid? can I change? .. I dont want a lot of then...
        • sure we can, there is a way to set the number from outside the component(code) and a numericStepper to set it manually.
      a good question, I made myself, and had a bit problem with it ..
      • The source ArrayCollection I will add to the component have a FilterFunction .. working pretty good outside it .. will it work property inside the component?
        • all right, I had a little headache to solve this, but the answer came as easy as the question, and YES IT WORKSSS.
      so lets see .. columns added,  provider (with/without filter) added, number of rows shown added from user/code.
      I think that this is all.
      it is just a VERSION 1.0 but I think it will fit almost everything it is used for.
      the example is shown bellow.
      Running Example
      PS.: it seen the code wont open in the running example, so I will put the codes here ...
        • 1. Re: Advanced Datagrid dinamical pagination Component
          balhk Level 1
          mail.mxml code
          <s:Application
           xmlns:fx="http://ns.adobe.com/mxml/2009"
                            xmlns:s="
          library://ns.adobe.com/flex/spark"
                            xmlns:mx="
          library://ns.adobe.com/flex/mx"                   minWidth="
          955" minHeight="600" xmlns:local="*"
                            creationComplete="init()" viewSourceURL="
          srcview/index.html">
          <fx:Declarations>
          <!-- Place non-visual elements (e.g., services, value objects) here -->
          </fx:Declarations>
          <fx:Script>
                    <![CDATA[
          import mx.collections.ArrayCollection;
          import mx.controls.advancedDataGridClasses.AdvancedDataGridColumn;
          private var columns:Array = [];
          private function init():void{
          //here we cam change by code, the number of rows in the data grid
                              advDataGrid.setRowCount(100);
          //set the text for the label of rows in the datagrid
                              advDataGrid.setRowsLabel(
          "rows: ");
          //create the columns dinamically
          var adv:AdvancedDataGridColumn = new AdvancedDataGridColumn();                    adv.headerText =
          "firstname";
                              adv.dataField =
          "firstname";                    columns.push(adv);
                              adv =
          "Middlename";                    adv.dataField =
          "middlename";
                              columns.push(adv);
          //set the columns in the data grid
                              advDataGrid.setDataGridColumns(columns);
                              advDataGrid.dataProvider= generateProvider();
          private function generateProvider():ArrayCollection{
          var ac:ArrayCollection = new ArrayCollection();
          var obj:Object = new Object();
          for(var i:int=0; i<10000; i++){                         obj =
          new Object();
                                   obj.firstname =
          "My Name "+i;                         obj.middlename =
          "middle "+i;                         obj.lastname =
          "last "+i;                         ac.addItem(obj);
          return ac;               }
          /**                * here we can add a new column in the datagrid in execution time
          private function addcolumn():void{
          "Lastname";
                              adv.dataField =
          "lastname";                    advDataGrid.addNewColumn(adv);
          this.button1.enabled=false;
          </fx:Script>
          <s:BorderContainer>
          <s:layout>
          <s:VerticalLayout/>
          </s:layout>
          <local:AdvancedPagingDataGrid id="advDataGrid" width="500" height="300"/>
          <s:Button id="button1" click="addcolumn()" label="Add last name" enabled="true"/>
          </s:BorderContainer>
          </s:Application>
          • 2. Re: Advanced Datagrid dinamical pagination Component
            balhk Level 1
            AdvancedPaginationDataGrid.as
            <!-- DEVELOPED BY Bal-Hanã on 2010/09/27
            Version 1.0
            open source code with rights to copy -->
            <s:BorderContainer
            xmlns:s="
            xmlns:mx="
            width="
            100%" height="100%" creationComplete="init()" borderVisible="false">
            <s:layout>
            <s:VerticalLayout/>
            </s:layout>
            <fx:Declarations>
            </fx:Declarations>
            <fx:Script>
            <![CDATA[
            import flash.sampler.NewObjectSample;
            import mx.collections.CursorBookmark;
            import mx.collections.ICollectionView;
            import mx.collections.IViewCursor;
            import mx.collections.ListCollectionView;
            import mx.events.CollectionEvent;
            //########## PRIVATE VARIABLES ##########//
            Bindable]
            * var that will show the atual page seen and the Number of pages available in the DataProvider</br>
            * ex.: 1-50 ; 5-300 ; 100-100;
            private var pageCount:String;
            * var that will hold the actual page from the DataProvider seen by the user
            private var actPage:uint = 1;
            * the maximum number of pages available in the Provider
            private var maxPages:uint;
            Bindable]
            * DataProvider that will be created dinamically to show in the AdvancedDataGrid
            private var _dp:ArrayCollection;
            * original Provider from where de AdvancedDataGrid
            private var _dataProvider:ArrayCollection = new ArrayCollection;
            Bindable]
            * the number of rows set by the user
            private var rowCount:int=100;
            * the AdvancedDataGrid columns array
            private var advColumns:Array =[];
            //########## PUBLIC VARIABLES ##########//
            //########## PRIVATE FUNCTIONS ##########//
            * initialize function, set initial providers and labels
            * Function <code>providerChanged</code> will be called each time the <code>provider</code> dispatch a <code>CollectionEvent.COLLECTION_CHANGE</code><br/>
            * this will refresh all the providers needed
            private function providerChanged(ev:Event):void{
            //2.0)refresh the datagrid shown rows
            refresh();
            * function called to set the datagrid dataProvider with the First available page of rows
            private function goToFirst():void{
            //1.0)set the actualpage to the first one
            actPage=1;
            //2.0)set the enabled true/false mode of each buttons
            this.initialPageBtn.enabled=false;
            this.backwardBtn.enabled=false;
            this.forwardBtn.enabled=true;
            this.lastPageBtn.enabled=true;
            refresh();
            * function called to set the datagrid data provider with the last shown page of rows
            private function goBack():void{
            //1.0)go back one index in the actualpage
            actPage--;
            if(actPage==1){
            refresh();
            * function called to set the datagrid data provider with the next available page of rows
            private function goToNext():void{
            //1.0)go to the next page index
            actPage++;
            if(actPage==maxPages){
            this.forwardBtn.enabled=false;
            this.lastPageBtn.enabled=false;
            this.initialPageBtn.enabled=true;
            this.backwardBtn.enabled=true;
            refresh();
            * function called to set the datagrid dataProvider with the Last available page of rows
            private function goToLast():void{
            //1.0)go to the last page index
            actPage=maxPages;
            refresh();
            * Function that will parse throw the Provider, to generate the new datagrid DataProvider
            * @param init:int the first object of the new dataProvider
            * @param end:int the last object of the new dataProvider
            * @return arrC:ArrayCollection the arraycollection that will be shown in the current page
            private function setProvider(init:int, end:int):ArrayCollection{
            //1.0)create local vars and initialize then
            var arrC:ArrayCollection = new ArrayCollection;
            var arr:Array = _dataProvider.toArray();
            //2.0)slice the group of objects we need, and set in the arrayColection
            arrC.source = arr.slice(init,end);
            //3.0)clear the array, we dont need a memory leak
            arr=[];
            return arrC;
            * Handler that will catch the change event in the numericStepper,
            * this numericStepper sets the number of itens seen in the Datagrid for each page
            private function stepperChangeHandler():void{
            setRowCount(
            this.rowCountStepper.value);
            //########## PUBLIC FUNCTIONS ##########//
            * Function called to set the provider of the compoment,<br/>
            * the dataGrid dataProvider will be parsed from the provider
            * @param value:ArrayCollection any kind of arrayObject, that will be plotted in the DataGrid
            public function set dataProvider(value:ArrayCollection):void{
            //remove the old eventlistener
            this._dataProvider.removeEventListener(CollectionEvent.COLLECTION_CHANGE,providerChanged);
            _dataProvider = value;
            //add a new eventlistener
            //everytime the provider is incremented with new objects we call the providerChanged to parse any relative change
            this._dataProvider.addEventListener(CollectionEvent.COLLECTION_CHANGE,providerChanged);
            providerChanged(
            null);
            * function that will return the raw dataprovider of the component of the Datagrid
            public function get dataProvider():ArrayCollection{
            return this._dataProvider;
            * refresh the advancedDataGrid dataProvider
            public function refresh():void{
            //1.0)find the number of available pages
            var i:uint= this._dataProvider.length/rowCount;
            //1.1)check if the available pages will really show all the provider collection
            if(i==0 || i*rowCount < this._dataProvider.length){
            i++;
            //1.2)change the number of max pages available
            this.maxPages=i;
            if(maxPages > actPage){
            if(actPage > maxPages){
            actPage = maxPages;
            var init:int = (actPage-1)*rowCount;
            var end:int = init+rowCount;
            this._dp=setProvider(init,end);
            advDataGrid.dataProvider=_dp;
            //2.0)change the label of "actualpage - maxpages"
            this.pageCount = this.actPage+" - "+this.maxPages;
            * Function that will be called in order to add new column in the AdvancedDataGrid
            * @param newColumn:AdvancedDataGridColumn the new column to be added
            public function addNewColumn(newColumn:AdvancedDataGridColumn):void{
            advColumns.push(newColumn);
            this.advDataGrid.columns = advColumns;
            * Function that will be called to change the AdvancedDataGrid columns array <br/>
            * this will renew the array, the old one will be lost, and a new one will be added
            * @param
            public function setDataGridColumns(gridColumns:Array):void{
            this.advColumns = gridColumns;
            * Function that enables the user to change the number of rows available in the datagrid
            * @param rows:uint new number of rows of the datagrid
            public function setRowCount(rows:uint):void{
            this.rowCount = rows;
            providerChanged(
            null);
            * add the text to the numericStepper rows count label
            public function setRowsLabel(str:String):void{
            this.rowsLabel.text=str;
            </fx:Script>
            <mx:AdvancedDataGrid id="advDataGrid" rowCount="{rowCount}"
            resizableColumns="
            true"
            width="
            100%" height="100%"
            variableRowHeight="
            true"
            rowHeight="
            17" fontSize="9"/>
            <!-- headerRenderer="{header_renderer}"-->
            <s:BorderContainer width="100%" height="21" borderVisible="true">
            <s:layout>
            <s:HorizontalLayout/>
            </s:layout>
            <s:Button id="initialPageBtn" label="&lt;&lt;" width="40" height="20" click="goToFirst()" enabled="false"/>
            <s:Button id="backwardBtn" label="&lt;" width="35" height="20" click="goBack()" enabled="false"/>
            <s:Label id="pageCountLbl" text="{pageCount}" width="100" textAlign="center" verticalAlign="middle" height="20"/>
            <s:Button id="forwardBtn" label="&gt;" width="35" height="20" click="goToNext()" enabled="false"/>
            <s:Button id="lastPageBtn" label="&gt;&gt;" width="40" height="20" click="goToLast()" enabled="false"/>
            <s:Label id="rowsLabel" verticalAlign="middle" height="20"/>
            <s:NumericStepper id="rowCountStepper" minimum="1" value="{rowCount}" maximum="10000" change="stepperChangeHandler()" stepSize="10" snapInterval="1" height="20" width="70"/>
            • 3. Re: Advanced Datagrid dinamical pagination Component
              hernanls
              Excelent component Bal, you are the MAN !
