3 Replies Latest reply on Jul 23, 2007 12:24 AM by BarryGee
    Loading data into a DataGrid from multiple parts of an xml file
    BarryGee Level 1
      Hi.
      I am using Flex Builder 2. I am trying to fill the columns of a datagrid with the contents of various parts of my xml file. The code I have so far is below.
      The location data loads fine into the appropriate column, however if i change the dataProvider details to;
      dataProvider="{feedRequest.lastResult.airshows.airshow.details}" or dataProvider="{feedRequest.lastResult.airshows.airshow.location.details}"
      i get the following error;
      Error: Unknown Property: 'details'.
      at mx.collections::ListCollectionView/ http://www.adobe.com/2006/actionscript/flash/proxy::getProperty()
      at mx.binding::PropertyWatcher/::updateProperty()
      at Function/ http://adobe.com/AS3/2006/builtin::apply()
      at mx.binding::Watcher/mx.binding:Watcher::wrapUpdate()
      at mx.binding::PropertyWatcher/updateParent()
      at mx.binding::Watcher/updateChildren()
      at mx.binding::PropertyWatcher/eventHandler()
      at flash.events::EventDispatcher/flash.events:EventDispatcher::dispatchEventFunction()
      at flash.events::EventDispatcher/dispatchEvent()
      at mx.rpc::AbstractInvoker/ http://www.adobe.com/2006/flex/mx/internal::resultHandler()
      at mx.rpc::Responder/result()
      at mx.rpc::AsyncRequest/acknowledge()
      at ::DirectHTTPMessageResponder/completeHandler()
      at flash.net::URLLoader/flash.net:URLLoader::onComplete()
      and no data loads.
      The mxml and xml file data can be seen below. All advice / code hacks welcome.
      Barry.
      MXML
      <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="feedRequest.send()">
      <mx:HTTPService id="feedRequest" url=" http://www.barrygee.com/apps/AIRShows/airshows.xml" useProxy="false"/>
      <mx:Panel x="10" y="10" width="800" height="400" layout="absolute" title="AIR Shows">
      <mx:DataGrid x="20" y="20" id="dgPosts" width="740" height="320" dataProvider="{feedRequest.lastResult.airshows.airshow}">
      <mx:columns>
      <mx:DataGridColumn headerText="Location" dataField="location" width="150"/>
      <mx:DataGridColumn headerText="Name" dataField="name" width="150"/>
      <mx:DataGridColumn headerText="Frequency" dataField="frequency"/>
      <mx:DataGridColumn headerText="Low" dataField="low"/>
      <mx:DataGridColumn headerText="High" dataField="high"/>
      <mx:DataGridColumn headerText="Band" dataField="band"/>
      <mx:DataGridColumn headerText="Info" dataField="info" width="300"/>
      </mx:columns>
      </mx:DataGrid>
      </mx:Panel>
      </mx:Application>
      XML
      <?xml version="1.0" encoding="UTF-8" ?>
      <airshows>
      <airshow>
      <location>Sunderland. UK.</location>
      <details>
      <name>RAF Red Arrows Aerobatic Display Team</name>
      <frequency></frequency>
      <low>242.2</low>
      <high>243.45</high>
      <band>AM</band>
      <info>Sunday only. All but one of them is air to air</info>
      </details>
      <details>
      <low>242.05</low>
      <high>377.6</high>
      <band>AM</band>
      </details>
      </airshow>
      </airshows>
        • 1. Re: Loading data into a DataGrid from multiple parts of an xml file
          Handycam Level 1
          Not sure what you're trying to accomplish, exactly, but:
          Create two arrayCollections.
          import mx.collections.*;
          import mx.rpc.events.*;
          [Bindable]
          airShowDetails:ArrayCollection;
          [Bindable]
          airShowLocationDetails:ArrayCollection;
          private function dataHandler(event:ResultEvent):void {
          airShowDetails = feedRequest.lastResult.airshows.airshow.details;
          airShowLocationDetails = feedRequest.lastResult.airshows.airshow.location.details
          In the mxml:
          <mx:HTTPService id="feedRequest" url=" http://www.barrygee.com/apps/AIRShows/airshows.xml" useProxy="false" result="dataHandler(event)" />
          Then you assign either of those bound variables as the data provider for your grid(s).
          • 3. Re: Loading data into a DataGrid from multiple parts of an xml file
            BarryGee Level 1
            Hi Handycam.
            Basically I wanted to take the contents of the location tag and place them into the first column and the contents of the remaining tags to populate the remaining columns. I only wanted one location tag per xml document. this was what was causing my problems. I have since decided to place the contents of the lcoation tag into the Panel title and the remaining content into the columns.
            My final code is as follows.
            <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="feedRequest.send()" viewSourceURL="srcview/index.html">
            <mx:HTTPService id="feedRequest" url=" http://www.barrygee.com/apps/AIRShows/sunderlandAirshow.xml" useProxy="false"/>
            <mx:Panel x="10" y="10" width="1000" height="880" layout="absolute" title="{feedRequest.lastResult.airshows.type} : {feedRequest.lastResult.airshows.location}">
            <mx:DataGrid x="20" y="20" id="dgPosts1" width="950" height="800" dataProvider="{feedRequest.lastResult.airshows.details}">
            <mx:columns>
            <mx:DataGridColumn headerText="Name" dataField="name" width="350"/>
            <mx:DataGridColumn headerText="Frequency" dataField="frequency" width="115"/>
            <mx:DataGridColumn headerText="Low" dataField="low" width="70"/>
            <mx:DataGridColumn headerText="High" dataField="high" width="70"/>
            <mx:DataGridColumn headerText="Band" dataField="band" width="50"/>
            <mx:DataGridColumn headerText="Info" dataField="info" width="350"/>
            </mx:columns>
            </mx:DataGrid>
            </mx:Panel>
            </mx:Application>
