• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
Zend AMF Slow Response
New Here ,
Sep 28, 2010 Sep 28, 2010
I am getting slow response times when using Zend AMF in Flash Builder 4.  It is taking between 1.5s to 2s to return the results, which is much slower than when I am returning XML.  However its about the same no matter if no records are returned or if 1000 records are returned. It seems like it is taking a while to make the connection to the gateway.php file. Anyone else noticing issues like this?  All the examples I have seen online use Apache instead of IIS, could that be part of my problem?
Justin
Views
652
Translate
Translate
Report
Report
Community guidelines
community guidelines
Participant ,
Sep 29, 2010 Sep 29, 2010
I experienced the same with Zend and switched to coldfuion as a result. Its better matched
to Flex, and you can go as far as Life Cycle Data services with it if you want. It is also a superior
design to php but works pretty much the same way.
The communications with Flashbuilder have several gotchas which are not explained but are covered here now.
The old php 4 AmfPhp was really impressive performer on speed. But it just took a dive when it went
to zend and 5.
Dan Pride
Votes
Translate
Translate
Report
Report
New Here ,
So this is a known issue with Zend?  I don't really want to pay Adobe more money for Cold Fusion for something that can be done using open source.  I may just have to stick to PHP and XML.
Thanks for the info,
Justin
Votes
Translate
Translate
Report
Report
Participant ,
LATEST
Not sure but I think so, I left Zend in Feb and have not looked back.
At Hostek you get a great hosting package with ColdFusion 9 (the one you want) for $5.00 a Month if you can do shared hosting.
If not, ? i would say take a careful look at coldfusion, watch a video or two on it,... its way ahead of Php generally,
and light years ahead for using as a back end for Flashbuilder.
Dan
Votes
Translate
Translate
Report
Report
