1. Re: reset image to original size shortcut
Nancy O. Sep 28, 2010 1:52 PM (in response to MattBru)Right click on image. Select Re-set Size from list.
Or, remove the height and width from img tags with Find & Replace.
Nancy O.
Alt-Web Design & Publishing
Web | Graphics | Print | Media Specialists
http://alt-web.com/
http://twitter.com/altweb -
2. Re: reset image to original size shortcut
lskadjfklsadjfips Aug 17, 2011 11:27 AM (in response to MattBru)I think what Nancy was trying to say is no. So, the next question would be: "How do I create a shortcut for rest image size, since it is a VERY repetitive task and my hands are already aching today.
3. Re: reset image to original size shortcut
alen_stoica Aug 31, 2011 2:26 AM (in response to MattBru)I've been facing the same problem - i haven't found a very good solution on this but you can use this:
right click on the image / and instead of clicking on "reset size" just push the key z from keyboard - this will trigger the reset size action;
I know its not the best solution but its better then nothing.
Oh - i use Dreamweaver version 8 - i hope this "shortcut" its still available on newer versions.
Cheers.
4. Re: reset image to original size shortcut
MattBru Aug 31, 2011 8:38 AM (in response to alen_stoica)This is awesome. Just what i needed. THANKS so much!
And in case anyone reads this, i have DW CS5 and it does work.
