3 Replies Latest reply on Sep 29, 2010 10:00 AM by mkeatley17
    Detect Folder with Droplet
    mkeatley17 Level 1
      I am making a droplet and I would like it to behave one way when a file is dropped on it and another way when a folder is dropped on it.
      I normally refer to my main object using app.activeDocument.  But if someone drops a folder on the droplet, it doesn't open in Photoshop, so I have no way of referring to the object.
      In other words, when a droplet opens a file and runs an action, is there a way to refer to the file other than just with the app.activeDocument?
      Thank you
        • 1. Re: Detect Folder with Droplet
          Michael L Hale Level 5
          I am not sure what you are asking. Photoshop can not open folders, only image files. Are you saying that when you drop a folder containing images on a droplet the images do not open?
          Droplets are a type of stored batch action and as far as I know there is no way to tell from a script inside the droplet if a single file or folder was dropped. The script will only see one file at a time either way.
          In addition to app.activeDocument you can refer to the doc opened by a droplet by index. app.documents[app.documents.length-1]; refers to the last opened document, which would be the one opened by the droplet.
          • 2. Re: Detect Folder with Droplet
            mkeatley17 Level 1
            so I want a droplet that bascially does this:
            1.  When you drop a FILE on the droplet, it copies the files to our server
            2.  When you drop a FOLDER on the droplet, it renames the FILES inside the FOLDER to the name of the FOLDER, then copies the FILES to our server
            So basically I want the droplet to detect whether a FILE or FOLDER is being dropped on it, and be able to get the name of the FOLDER also.
            Is this possible?
            Thank you
            • 3. Re: Detect Folder with Droplet
              Michael L Hale wrote:
              ... as far as I know there is no way to tell from a script inside the droplet if a single file or folder was dropped.
