0 Replies Latest reply on Sep 28, 2010 3:13 PM by flexchief
    Ampersand url error
    flexchief Level 1
      I've  made a simple mp3 player that plays tracks loaded from an xml file into  a datagrid. Once the data is loaded into the datagrid the user can  select a track and play it. Everything works fine until i try to play a  track with '&' in its path.
      This causes the following error:
      Error #2044: Unhandled IOErrorEvent:. text=Error #2032: Stream Error.
      I  assume this is because the URL appears incorrect to the player. If I  simlpy remove the '&' and replace it with '&' the file plays  fine?
      In my xml file, which is used to populate the  datagrid, the location of each file is stored as well as various other  information such as artist name, year, genre, path, etc. All '&'  values in this xml file appear as '&'
      Is there any way to convert these values into a form that my player can read?
      Any ideas here would really help me out?
      Adam
      Flexchief
