1. Re: restore catalog
saurabh288 Sep 28, 2010 9:02 PM (in response to Jean- Pierre Lemonde)The files can be restored only if youhad taken the backup of the catalog. Do you have the old catalog files with you. If yes, then you need to open the same catalog in PSE and then you can perform the reconnect operation. In case you don't have the catalog files, then you need to import the images again in the catalog.
2. Re: restore catalog
dj_paige Sep 29, 2010 5:05 AM (in response to Jean- Pierre Lemonde)I did not made a back up with PE8 but with Sync Back on an external Disk.
Did you use Sync Back to make a copy of the PSE catalog file?
3. Re: restore catalog
Jean- Pierre Lemonde Sep 29, 2010 8:54 AM (in response to dj_paige)I use Sync Back to make a back up of every data contained in my two hard disk. Of course, these were made through SB and through PE8.
Thank's
4. Re: restore catalog
dj_paige Sep 29, 2010 9:00 AM (in response to Jean- Pierre Lemonde)I use Sync Back to make a back up of every data contained in my two hard disk. Of course, these were made through SB and through PE8.
This is vague, because I don't know what you mean by "every data". What do you (what does Sync Back) consider to be data?
I asked if you made a backup of your catalog file, the only two answers that make sense to me is "Yes" or "No". I suppose I could also accept "I don't know" as a valid answer.
