2 Replies Latest reply on Sep 29, 2010 12:10 AM by Rajiv Jha
    Issue : drag and drop from list control to tree control
    Rajiv Jha
      I was trying a drag and drop from list control to tree control. I have used some sample data to populate list and tree controls .
      It is working fine . except one problem ..
      Prob : when i drag an item to tree control .. it gets added .. now tree contains (X+1) data in list .. say X is the inital number of nodes in a tree node.
                now if i drag another item from list to last item in the tree node  .. i.e at X+1 index. .. it throws null pointer exception.
      I am considerably new in flex programming . looking for help from experts ..
      Below is my code :
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
                      layout="horizontal"
                      creationComplete="init()">
          <mx:Script>
              <![CDATA[
                  import mx.controls.listClasses.IListItemRenderer;
                  import mx.rpc.events.FaultEvent;
                  import mx.rpc.events.ResultEvent;
                  import mx.utils.ObjectUtil;
                  import mx.collections.ICollectionView;
                  import mx.core.UIComponent;
                  import mx.managers.DragManager;
                  import mx.events.DragEvent;
                  import mx.controls.Alert;
                  import mx.controls.Label;
                  import mx.events.CloseEvent;
                  private var homePath:String="/home/e311394/dndTest/";
                  private var destPath:String="/home/e311394/dndDest/";
                  private var eid:String="e311394";
                  private var actn:String;
                  [Bindable]
                  private var cm:ContextMenu;
                  private var cmi:ContextMenuItem;
                  [Bindable]
                  private var dp:ArrayCollection;
                  private function init():void
                      cmi=new ContextMenuItem("Remove");
                      cmi.enabled=true;
                      cmi.addEventListener(ContextMenuEvent.MENU_ITEM_SELECT, contextMenuItem_menuItemSelect);
                      cm=new ContextMenu();
                      cm.hideBuiltInItems();
                      cm.customItems=[cmi];
                      cm.addEventListener(ContextMenuEvent.MENU_SELECT, contextMenuItem_menuSelect);
                      list.contextMenu=cm;
                  private function contextMenuItem_menuSelect(evt:ContextMenuEvent):void
                      list.selectedIndex=lastRollOverIndex;
                  private function contextMenuItem_menuItemSelect(evt:ContextMenuEvent):void
                      var loclSelectedRow:Object=list.selectedItem;
                      var lostrSelectedMenuItem:String;
                      lostrSelectedMenuItem=evt.target.caption;
                      if (loclSelectedRow != null)
                          var obj:Object=new Object()
                          obj.label=loclSelectedRow.label as String;
                              //Alert.show(obj.label);
                      if (lostrSelectedMenuItem == "Remove")
                          if(loclSelectedRow!=null)
                          var pth:String=homePath.concat(loclSelectedRow.label);
                          //Alert.show(pth);
                          //FlexDnDRemoteService.process(eid,"delete",pth,"-");
                          var coll:ArrayCollection=list.dataProvider as ArrayCollection;
                          if (coll.contains(loclSelectedRow))
                              coll.removeItemAt(coll.getItemIndex(loclSelectedRow));
                  public function onTreeDragEnter(event:DragEvent):void
                      event.preventDefault();
                      DragManager.acceptDragDrop(event.target as UIComponent);
                      tree.showDropFeedback(event);
                  protected function onTreeDragOver(event:DragEvent):void
                      event.currentTarget.hideDropFeedback(event);
                      try
                          var index:int=tree.calculateDropIndex(event);
                      catch (e:Error)
                          DragManager.showFeedback(DragManager.NONE);
                          return;
                      tree.selectedIndex=index;
                      var draggedOverItem:Object=tree.selectedItem;
                  public function onTreeDragExit(event:DragEvent):void
                      tree.hideDropFeedback(event);
                  private function showAlert():void
                      Alert.yesLabel="Move";
                      Alert.noLabel="Copy";
                      Alert.buttonWidth=70;
                      Alert.show("Copy / Move ?", "Confirm", Alert.YES | Alert.NO | Alert.CANCEL, this, alertListener, null, Alert.OK);
                  private function alertListener(eventObj:CloseEvent):void
                      var result:Boolean=false;
                      if (eventObj.detail == Alert.CANCEL)
                          //Alert.show("CANCEL");
                          return;
                      if (eventObj.detail == Alert.YES)
                          //Alert.show("YES");
                          result=true;
                      else if (eventObj.detail == Alert.NO)
                          //Alert.show("NO");
                          result=false;
                      var index:int=tree.calculateDropIndex(treedropevt);
                      //Alert.show("Drop Pos" + index.toString());
                      /* var treeList:ArrayCollection=tree.dataProvider as ArrayCollection;
                         Alert.show(" index"+index+"Length "+treeList.length);
                         if(index > treeList.length)
                         Alert.show("Returning");
                         return;
                      var items:Array=new Array();
                      if (treedropevt.dragSource.hasFormat("items"))
                          items=items.concat(treedropevt.dragSource.dataForFormat("items") as Array);
                      var parentItem:Object;
                      parentItem=getObjectTarget();
                      /* if (tree.dataDescriptor.isBranch(tree.indexToItemRenderer(index).data))
                         parentItem=tree.indexToItemRenderer(index).data;
                         else
                         var dropParentPackage:Object = tree.mx_internal::_dropData.parent as Object;
                         Alert.show("HAck"+dropParentPackage.toString());
                         parentItem=tree.getParentItem(tree.indexToItemRenderer(index).data);
                         //Alert.show("Lenght "+ObjectUtil.getClassInfo(parentItem).properties.length);
                      var position:int=0;
                      /* if(ObjectUtil.getClassInfo(parentItem).properties.length==0)
                         return;
                      if (parentItem != null)
                          try
                              while (tree.indexToItemRenderer(index).data != parentItem)
                                  //Alert.show(tree.indexToItemRenderer(index).data.toString());
                                  if (index > 0)
                                      index--;
                                  //Alert.show("Insiade");
                                  position++;
                          catch (e:Error)
                              Alert.show("Catch" + index.toString());
                              return;
                      for each (var item:Object in items)
                          obj.label=item.label as String;
                              //Alert.show("ADDED");
                              tree.dataDescriptor.addChildAt(parentItem, obj, position++);
                          else
                              //Alert.show("PARENT NULL");
                              tree.dataDescriptor.addChildAt(tree.selectedItem, obj, position++);
                          var spth:String=homePath.concat(item.label);
                          //Alert.show(spth);
                          var dpth:String=destPath.concat(item.label);
                          //Alert.show(dpth);
                          if (result == true)
                              removeItems();
                                  //FlexDnDRemoteService.process(eid,"move",spth,dpth);
                          else
                              //FlexDnDRemoteService.process(eid,"copy",spth,dpth);
                          tree.validateNow();
                  public function getObjectTarget():Object
                      var dropData:Object=tree.mx_internal::_dropData as Object;
                      if (dropData.parent != null)
                          return dropData.parent;
                      else
                          // if there is not parent (root of the tree), I take the root directly
                          var renderer:IListItemRenderer=tree.indexToItemRenderer(0);
                          return renderer.data;
                  public function removeItems():void
                      //remove moved elements
                      var items:Array=treedropevt.dragSource.dataForFormat("items") as Array;
                          if (coll.contains(item))
                              coll.removeItemAt(coll.getItemIndex(item));
                  private var treedropevt:DragEvent;
                  public function onTreeDragDrop(event:DragEvent):void
                      treedropevt=event;
                      showAlert();
                  public function resultHandler(event:ResultEvent):void
                      Alert.show("Success", "Status");
                  public function faultHandler(event:FaultEvent):void
                      Alert.show(event.fault.faultString, "Failure");
          </mx:Script>
          <mx:ArrayCollection id="listDP">
              <mx:Object label="File1.dnd"/>
              <mx:Object label="File2.dnd"/>
              <mx:Object label="File3.dnd"/>
              <mx:Object label="File4.dnd"/>
              <mx:Object label="File5.dnd"/>
          </mx:ArrayCollection>
          <mx:Number id="lastRollOverIndex"/>
               <mx:ArrayCollection id="treeDP">
               <mx:Object label="/home">
               <mx:children>
               <mx:Object label="dummy1.ks"/>
               <mx:Object label="dummy2.ks"/>
               <mx:Object label="e493126">
               <mx:children>
               <mx:ArrayCollection>
               <mx:Object label="/home/e493126/sample1.ks"/>
               </mx:children>
               </mx:Object>
               </mx:children>
               </mx:Object>
              <mx:Object label="/dndDest">
                  <mx:children>
                          <mx:Object label="sample1.ks"/>
                          <mx:Object label="sample2.ks"/>
                          <mx:Object label="sample3.ks"/>
                          <mx:Object label="sample4.ks"/>
                          <mx:Object label="sample5.ks"/>
                          <mx:Object label="sample6.ks"/>
                  </mx:children>
              </mx:Object>
          <mx:List id="list"
                   itemRollOver="lastRollOverIndex = event.rowIndex"
                   width="50%"
                   dragEnabled="true"
                   dataProvider="{listDP}"
                   labelField="label"
                   allowMultipleSelection="true"
                   dragMoveEnabled="false">
          </mx:List>
          <mx:Tree id="tree"
                   width="50%"
                   dragEnabled="true"
                   dataProvider="{treeDP}"
                   dragEnter="onTreeDragEnter(event)"
                   dragOver="onTreeDragOver(event)"
                   dragExit="onTreeDragExit(event)"
                   dragDrop="onTreeDragDrop(event)"
                   labelField="label"
                   liveScrolling="true">
          </mx:Tree>
          <mx:RemoteObject id="FlexDnDRemoteService"
                           showBusyCursor="true"
                           destination="FlexDnD">
              <mx:method name="process"
                         result="resultHandler(event)"
                         fault="faultHandler(event)"/>
          </mx:RemoteObject>
      </mx:Application>
      Rajiv
