23 Replies Latest reply on Sep 30, 2010 11:58 PM by VertexBee
    script request: switch Presets
    VertexBee Level 1
      http://www.vertexbee.com/pics/vBee_PSswitchPresets.jpg
      Martin
        • 1. Re: script request: switch Presets
          c.pfaffenbichler Level 9
          Sounds interesting.
          Unfortunately that would take a lot of insight into what I consider the more complex aspects of Photoshop-Scripting, but maybe it will pique the interest of some of the more experienced Scripters.
          Because so far I have not been able to determine the number and names of presets for a selected tool or select them other than by name.
          Another point: If you post your question as an image I doubt that it will be catalogued properly and may subsequently not get listed in Forum-searches it should turn up in, so you might want to reconsider that.
          • 2. Re: script request: switch Presets
            VertexBee Level 1
            I'm glad you find it interesting and thank you for the tip, I'll edit the first post to include a plain text along with the image
            I didn't know is hart to be implemented...hmmm...Is it possible to cycle through actions, instead of presets ?
            An action can load a particular preset file(.tpl or .abr).This way the user must first record several actions, each corresponding to a preset, and than
            the script could cycle through these actions. Is that possible ?
            • 3. Re: script request: switch Presets
              No hassle, just for future reference maybe.
              I suspect it is not really »hard« – I just haven’t been able to figure it out.
              Some of the regulars there usually also drop by here, but you could try posting at ps-scripts, too.
              http://www.ps-scripts.com/
              Anyway the Actions-approach might work, but it seems a bit convoluted.
              And one would still have to determine the currently selected toolPreset (which I also have not been able to) to be able to find out which one is the next or write a prefs-file which records the last Action performed or something …
              • 4. Re: script request: switch Presets
                Paul Riggott Level 6
                The difficulty will be that the presets include crops etc.
                The following code will list all the presets to ESTK console...
                var Presets = getPresetList();
                for(var v in Presets){
                 $.writeln(Presets[v]);
                function getPresetList(){
                var ref = new ActionReference();
                   ref.putEnumerated( charIDToTypeID("capp"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
                   var appDesc = executeActionGet(ref);
                  var List = appDesc.getList(stringIDToTypeID('presetManager'));
                  var presetNames=[];
                    var list = List.getObjectValue(7).getList(charIDToTypeID('Nm  '));
                    for (var i = 0; i < list.count; i++) {
                      var str = list.getString(i);
                      presetNames.push(str);
                presetNames=ReturnUniqueSortedList(presetNames);
                return presetNames;
                function ReturnUniqueSortedList(ArrayName){
                var unduped = new Object;
                for (var i = 0; i < ArrayName.length; i++) {
                unduped[ArrayName[i]] = ArrayName[i];
                var uniques = new Array;
                 for (var k in unduped) {
                   uniques.push(unduped[k]);
                return uniques.sort();
                • 5. Re: script request: switch Presets
                  Muppet Mark-QAl63s Level 4
                  Have you looked at X's script PresetLister that is part of his tool kit? This breaks them down into groups brushes, styles, etc. etc. I think you would have to make use of Action's to be able to add keyboard shrotcut functionality…
                  • 6. Re: script request: switch Presets
                    btw… X you have been jinxed by the jive fairies… you need to contact forum admin to get that fixed else you'll end up with them silly 2 id's like what I have… They never did fix that for me… the aka is still lurking about…
                    • 7. Re: script request: switch Presets
                      Hi Mark, I don't think the "toolPreset" list can be broken down any more. The lists avilable are:-
                      0=brush
                      1=color
                      2=gradientClassEvent
                      3=styleClass
                      4= null not used
                      5=shapeCurveType
                      6=customShape
                      7=toolPreset
                      • 8. Re: script request: switch Presets
                        Sorry Paul may have things a bit confused your script return me…
                        0.5 cm Black Arrow
                        5 Point White Star
                        Airbrush Soft Round 50% flow
                        Art History Brush 20 pixels
                        Aurora
                        Background Eraser 30 pixels
                        Chalk Build Up
                        Chalk with Medium Heavy Flow
                        Circular Rainbow
                        Close Cross Hatch
                        Crop 4 inch x 6 inch 300 ppi
                        Crop 5 inch x 3 inch 300 ppi
                        Crop 5 inch x 4 inch 300 ppi
                        Crop 5 inch x 7 inch 300 ppi
                        Crop 8 inch x 10 inch 300 ppi
                        Desaturate 13 pixels
                        Fill with Bubbles Pattern
                        Fuzzy Cluster Loose
                        Fuzzy Gesture Tool Small
                        Granite
                        Healing Brush 21 pixels
                        Heavy Marker Smaller Tip
                        Heavy Marker with Fuzzy Edges
                        Horizontal Type Myriad Roman 24 pt
                        Magnetic Lasso 24 pixels
                        Marker Medium Tip
                        No Style
                        Paintbrush Oval 45 pixels Multiply
                        Pointillism
                        Scattered Ornament Flower
                        Spongy
                        Spray Can
                        Starburst Color Target
                        Texture with Brush
                        TieDyed Impressionist 25 pixels
                        Transparent Red Spray Paint
                        Vertical Type Myriad Roman 24 pt
                        Which is my tools presets yes? Where as X's gives me…
                        [Brushes]
                        Hard Round 1 pixel
                        Hard Round 3 pixels
                        Hard Round 5 pixels
                        Hard Round 9 pixels
                        Hard Round 13 pixels
                        Hard Round 19 pixels
                        Soft Round 5 pixels
                        Soft Round 9 pixels
                        Soft Round 13 pixels
                        Soft Round 17 pixels
                        Soft Round 21 pixels
                        Soft Round 27 pixels
                        Soft Round 35 pixels
                        Soft Round 45 pixels
                        Soft Round 65 pixels
                        Soft Round 100 pixels
                        Soft Round 200 pixels
                        Soft Round 300 pixels
                        Airbrush Hard Round 9
                        Airbrush Hard Round 13
                        Airbrush Pen Opacity Flow
                        Airbrush Soft Round 17
                        Airbrush Soft Round 45
                        Airbrush Soft Round 65
                        Airbrush Soft Round 100
                        Airbrush Soft Round 200
                        Airbrush Soft Round 300
                        Spatter 14 pixels
                        Spatter 24 pixels
                        Spatter 27 pixels
                        Spatter 39 pixels
                        Spatter 46 pixels
                        Spatter 59 pixels
                        Chalk 11 pixels
                        Chalk 17 pixels
                        Chalk 23 pixels
                        Chalk 36 pixels
                        Chalk 44 pixels
                        Chalk 60 pixels
                        Star 14 pixels
                        Star 26 pixels
                        Star 33 pixels
                        Star 42 pixels
                        Star 55 pixels
                        Star 70 pixels
                        Dune Grass
                        Grass
                        Scattered Maple Leaves
                        Scattered Leaves
                        Flowing Stars
                        Fuzzball
                        Chalk
                        Charcoal Large Smear
                        Hard Pastel on Canvas
                        Oil Pastel Large
                        Dry Brush Tip Light Flow
                        Dry Brush
                        Watercolor Loaded Wet Flat Tip
                        Watercolor Small Round Tip
                        Oil Heavy Flow Dry Edges
                        Oil Medium Wet Flow
                        Wet Sponge
                        Rough Round Bristle
                        Airbrush 75 Tilt Size and Angle
                        Airbrush Dual Brush Soft Round 45
                        Sampled Brush 1
                        Circle 1
                        Circle 2
                        Circle 3
                        Circle 4
                        Concentric Circles
                        Crosshatch 1
                        Crosshatch 2
                        Crosshatch 3
                        Crosshatch 4
                        Dashed Circle 1
                        Dashed Circle 2
                        Dashed Circle 3
                        Diamond
                        Ornament 1
                        Ornament 2
                        Ornament 3
                        Ornament 4
                        Ornament 5
                        Ornament 6
                        Ornament 7
                        Ornament 8
                        Snowflake
                        Star - Small
                        Star - Large
                        Starburst - Small
                        Starburst - Large
                        Texture 1
                        Texture 2
                        Texture 3
                        Texture 4
                        Texture 5
                        Texture 6
                        Triangle
                        Triangle - Dots
                        Brush Heavy Flow Scattered
                        Drippy Water
                        Dry Brush on Towel
                        Heavy Scatter Flow
                        Heavy Stipple
                        Brush on Light Weave
                        Light Oil Flat Tip
                        Paint on Rough Texture
                        Paintbrush Tool Texture Comb
                        Rough Dry Brush
                        Rough Ink
                        Scattered Dry Brush
                        Scattered Dry Brush Small Tip
                        Large Texture Stroke
                        Oil Heavy Flow Small Tip
                        Brush with Thick Flow Medium Tip
                        Oil Medium Brush  Wet Edges
                        Oil Small Tip
                        Oil Medium to Large Tip
                        Brush Light Texture Medium Tip
                        Watercolor Heavy Loaded
                        Watercolor Heavy Pigments
                        Watercolor Heavy Medium Tip
                        Watercolor Fat Tip
                        Watercolor Textured Surface
                        Watercolor Light Opacity
                        [Colors]
                        Red
                        Orange
                        Yellow-???
                        Green
                        Blue
                        Violet
                        [Gradients]
                        Foreground to Background
                        Foreground to Transparent
                        Black, White
                        Red, Green
                        Violet, Orange
                        Blue, Red, Yellow
                        Blue, Yellow, Blue
                        Orange, Yellow, Orange
                        Violet, Green, Orange
                        Yellow, Violet, Orange, Blue
                        Copper
                        Chrome
                        Spectrum
                        Transparent Rainbow
                        Transparent Stripes
                        [Styles]
                        Default Style (None)
                        Color Target (Button)
                        Double Ring Glow (Button)
                        Striped Cone (Button)
                        Blue Glass (Button)
                        Negative (Image)
                        Puzzle (Image)
                        Sepia Tone (Image)
                        Sun Faded Photo (Image)
                        Blanket (Texture)
                        Nebula (Texture)
                        Sunspots (Texture)
                        Tie-Dyed Silk (Texture)
                        Chiseled Sky (Text)
                        Chromed Satin (Text)
                        Overspray (Text)
                        Sunset Sky (Text)
                        Basic Drop Shadow
                        1 Px Stroke 0% Fill Opacity
                        1 Px stroke 100% Fill Opacity
                        Blue Glass (Button)
                        Negative (Image)
                        Puzzle (Image)
                        Sepia Tone (Image)
                        Blanket (Texture)
                        Nebula (Texture)
                        Sunspots (Texture)
                        Chiseled Sky (Text)
                        Overspray (Text)
                        Sunset Sky (Text)
                        Basic Drop Shadow
                        Pink Gloss
                        White Gloss
                        Orange Gloss
                        Black 3D
                        Blue 3D
                        White Gloss
                        Grey 3D
                        Blue 3D
                        Wax Flat
                        Yellow 3D
                        Yellow 3D
                        Grey Gloss
                        Green Flat
                        Black 3D
                        Pink Gloss
                        Orange Flat
                        Grey Blue 3D
                        Wax 3D
                        Red 3D
                        Blue 3D
                        Yellow Flat
                        Grey Gloss
                        Red Flat
                        Blue 3D
                        Blue Gloss
                        Red Gloss
                        Grey Flat
                        Green 3D
                        Blue 3D
                        Green Gloss
                        Black Gloss
                        Blue 3D
                        Wax 3D
                        Green 3D
                        Blue 3D
                        Blue 3D
                        Orange 3D
                        Green 3D
                        Pink 3D
                        Red 3D
                        Gren 3D
                        Olive 3D
                        Yellow 3D
                        Red 3D
                        Blue Gloss\
                        Blue Gloss
                        Pink 3D
                        White 3D
                        Blue Grey 3D
                        Orange 3D
                        Blue Flat
                        Olive Flat
                        Blue Gloss
                        Green 3D
                        Orange 3D
                        Olive 3D
                        Gold 3D
                        Pink 3D
                        Green Gloss
                        Green Flat
                        Grey Blue 3D
                        Blue 3D
                        Blue Gloss
                        Blue 3D
                        Blue Pipe
                        Purple 3D
                        Olive 3D
                        Blue 3D
                        Olive 3D
                        Green Flat
                        Green Flat
                        Orange 3D
                        Black Gloss Pipe
                        Blue 3D
                        Green Semi Flat
                        Blue 3D
                        Blue 3D
                        Pink Flat
                        Blue 3D
                        Blue 3D
                        Blue Pipe\
                        Green 3D
                        Grey Gloss
                        Grey 3D
                        Neon -  Use on Black BG
                        Grey Blue Gloss
                        Ornage 3D
                        Green Flat
                        Blue Pipe
                        Orange Flat
                        Wax 3D
                        Blue 3D
                        Grey 3D
                        Wax 3D
                        Black Gloss
                        Yellow 3D
                        Red Gloss
                        Green 3D
                        Blue Gloss
                        Blue 3D
                        Pink 3D
                        White Gloss
                        Blue Flat
                        Grey Pipe
                        White 3D
                        Blue Grey Flat
                        Green Flat
                        Blue 3D
                        Purple 3D
                        Lavendar 3D
                        Blue Flat
                        Blue 3D
                        Blue 3D
                        Red Flat
                        Grey 3D
                        Yellow Flat
                        Green 3D
                        Brown 3D
                        Brown Red 3D
                        L Green 3D
                        Grey Black 3D
                        Grey 3D
                        Blue 3D
                        Green Gloss
                        Orange 3D
                        Red Gloss
                        Brown Gloss
                        L Brown 3D
                        Red Gloss
                        Blue Gloss
                        Blue Gloss
                        drop
                        tj hughes blue
                        tj hughes yellow
                        tj hughes red
                        tj hughes green
                        tj hughes warehouse
                        [Patterns]
                        Bubbles
                        Wrinkles
                        Woven
                        Wood
                        Tie Dye
                        Satin
                        Optical Checkerboard
                        Nebula
                        Molecular
                        Metal Landscape
                        Herringbone 2
                        Clouds
                        Pattern 1
                        Pattern 2
                        Pattern 3
                        [Shaping Curves]
                        Linear
                        Cone
                        Cone - Inverted
                        Cove - Deep
                        Cove - Shallow
                        Gaussian
                        Half Round
                        Ring
                        Ring - Double
                        Rolling Slope - Descending
                        Rounded Steps
                        Sawtooth 1
                        [Custom Shapes]
                        Arrow 5
                        Arrow 7
                        Arrow 9
                        Banner 3
                        Frame 7
                        Eighth Notes
                        Lightning
                        Flower 5
                        Grass 2
                        Light Bulb 2
                        Thumb Tack
                        Envelope 2
                        Scissors 2
                        Stamp 2
                        Fleur-De-Lis
                        Hedera 2
                        Heart Card
                        Blob 1
                        Checkmark
                        Registration Target 1
                        "No" Sign
                        Talk 1
                        Tile 2
                        Tile 4
                        Grid
                        Starburst
                        Cat Print
                        Circle Thin Frame
                        Square Thin Frame
                        Copyright symbol
                        Registered Trademark symbol
                        Trademark symbol
                        Talk 1
                        Talk 2
                        Talk 3
                        Talk 4
                        Talk 5
                        Thought 1
                        Thought 2
                        Bone
                        Fish
                        Cat
                        Dog
                        Snail
                        Rabbit
                        Bird 1
                        Bird 2
                        Dog Print
                        Cat Print
                        Arrow 1
                        Arrow 2
                        Arrow 3
                        Arrow 4
                        Arrow 5
                        Arrow 6
                        Arrow 7
                        Arrow 8
                        Arrow 9
                        Arrow 10
                        Arrow 11
                        Arrow 12
                        Arrow 13
                        Arrow 14
                        Arrow 15
                        Arrow 16
                        Arrow 17
                        Arrow 18
                        Arrow 19
                        Arrow 20
                        Banner 1
                        Banner 2
                        Banner 3
                        Banner 4
                        Ribbon 1
                        Ribbon 2
                        Seal
                        Frame 1
                        Frame 2
                        Frame 3
                        Frame 4
                        Frame 5
                        Frame 6
                        Frame 7
                        Frame 8
                        Whole Note
                        Half Note
                        Quarter Note
                        Eighth Note
                        Eighth Notes
                        Sixteenth Note
                        Bass Clef
                        Treble Clef
                        Flat Symbol
                        Sharp Symbol
                        Tree
                        Fern
                        Shamrock
                        Butterfly
                        Sun 1
                        Sun 2
                        Waves
                        Raindrop
                        Cloud 1
                        Cloud 2
                        Lightning
                        Fire
                        Snowflake 1
                        Snowflake 2
                        Snowflake 3
                        Moon
                        Leaf 1
                        Leaf 2
                        Leaf 3
                        Leaf 4
                        Leaf 5
                        Leaf 6
                        Leaf 7
                        Flower 1
                        Flower 2
                        Flower 3
                        Flower 4
                        Flower 5
                        Flower 6
                        Flower 7
                        Grass 1
                        Grass 2
                        Grass 3
                        Light Bulb 1
                        Light Bulb 2
                        Left Hand
                        Right Hand
                        Left Foot
                        Right Foot
                        Umbrella
                        Key 1
                        Key 2
                        Bow
                        Puzzle 1
                        Puzzle 2
                        Puzzle 3
                        Puzzle 4
                        Pencil
                        Pen
                        Marker
                        Paintbrush
                        Crayon
                        Phone 1
                        Phone 2
                        Hourglass
                        Thumb Tack
                        Sheriff's Badge
                        Crown 1
                        Crown 2
                        Crown 3
                        Crown 4
                        Crown 5
                        Envelope 1
                        Envelope 2
                        Scissors 1
                        Scissors 2
                        Paper Clip
                        Stamp 1
                        Stamp 2
                        Confetti
                        Splatter
                        Holly
                        US Flag
                        Point Right
                        Point Left
                        Fleur-De-Lis
                        Ornament 1
                        Ornament 2
                        Ornament 3
                        Ornament 4
                        Ornament 5
                        Ornament 6
                        Ornament 7
                        Ornament 8
                        Leaf Ornament 1
                        Leaf Ornament 2
                        Leaf Ornament 3
                        Floral Ornament 1
                        Floral Ornament 2
                        Floral Ornament 3
                        Floral Ornament 4
                        Hedera 1
                        Hedera 2
                        Hedera 3
                        Spiral
                        ZigZag
                        10 Point Star
                        10 Point Star Frame
                        5 Point Star
                        5 Point Star Frame
                        Flower 1
                        Flower 1 Frame
                        Flower 2
                        Flower 2 Frame
                        Hexagon
                        Hexagon Frame
                        Club Card
                        Heart Card
                        Spade Card
                        Diamond Card
                        Crescent Moon
                        Crescent Moon Frame
                        Diamond
                        Diamond Frame
                        Heart
                        Heart Frame
                        8 Point Star
                        8 Point Star Frame
                        Rounded Square
                        Rounded Square Frame
                        Triangle
                        Triangle Frame
                        Blob 1
                        Blob 1 Frame
                        Blob 2
                        Blob 2 Frame
                        Circle
                        Circle Frame
                        Circle Thin Frame
                        Square
                        Square Frame
                        Square Thin Frame
                        Woman
                        Man
                        Airplane
                        Help
                        Phone 3
                        Checkmark
                        Exclamation Point
                        Question Mark
                        Starburst
                        X
                        Pedestrian
                        School
                        Wheelchair
                        Sign 1
                        Sign 2
                        Sign 3
                        Sign 4
                        Sign 5
                        Sign 6
                        Car 1
                        Car 2
                        Bicycle
                        Recycle 1
                        Recycle 2
                        Yin Yang
                        Female Symbol
                        Male Symbol
                        Bull's Eye
                        Radioactive
                        Nuclear
                        World
                        Compass
                        Boom 1
                        Boom 2
                        Star
                        Copyright
                        Registered
                        Trademark
                        Registration Target 2
                        Information
                        Campfire
                        "No" Sign
                        Mac Pointer
                        Windows Pointer
                        Checked Box
                        Check Box
                        Talk 1
                        Talk 2
                        Talk 3
                        Talk 4
                        Talk 5
                        Thought 1
                        Thought 2
                        Paw Prints
                        Tracks
                        Tile 1
                        Tile 2
                        Tile 3
                        Tile 4
                        Tile 5
                        Grid
                        Add
                        Delete
                        Back
                        Forward
                        Down
                        Up
                        Save
                        Mail
                        Checked Box
                        Home
                        Help
                        "No" Symbol
                        Movie
                        Music On
                        Music Off
                        Search
                        World Wide Web Search
                        Shopping Cart
                        Volume
                        Tabbed Button
                        Time
                        Tools
                        World Wide Web
                        [Tool Presets]
                        5 Point White Star
                        0.5 cm Black Arrow
                        Circular Rainbow
                        Aurora
                        Chalk Build Up
                        Close Cross Hatch
                        Fuzzy Cluster Loose
                        Granite
                        Marker Medium Tip
                        No Style
                        Pointillism
                        Spongy
                        Spray Can
                        Texture with Brush
                        Is this all the presets that I currently have loaded where I have used load/replace/Reset? Sorry about the length of all the junk
                        • 9. Re: script request: switch Presets
                          Yes that's your toolPresets trying to sort just the brush presets would be a nightmare!
                          • 10. Re: script request: switch Presets
                            Beyond me oh yes… I thought it 'may' be possible if some name prefixing was maybe added to the brushes before hand… I will go see if it lets me edit that post down now…
                            • 11. Re: script request: switch Presets
                              VertexBee Level 1
                              Hi, guys
                              10x for the replies, although I don't know if you have understood my request completely.
                              I just want to swap brushes on the fly, whole sets of them = to cycle between several .abr files, that is all.
                              The simplest way for me to do this is to create actions that load different .abr files, but this can result in large amount of actions and if all of them are binded to a hotkey...it is not very efficient.
                              I have no scripting experience, I would be really thankful if someone of you could write a script that cycles through several actions..if that's possible.
                              Cheers!
                              • 12. Re: script request: switch Presets
                                jugenjury Level 2
                                Maybe I'm confused or missing something, but didn't the output Mark showed separate out the Brush presets?
                                I think a simple solution would be to actually make 2 scripts. One to set up your groups and save them into a config (.ini) file and another to cycle through the groups. This could be done with a single script, but since you want hot-key cycling you most likely wouldn't want a dialog to open up each time you run the script to ask if you want to alter the configuration. A way around this is to have the script cycle through the groups only if the brush tool is the actively selected tool. Otherwise, run the configuration dialog.
                                • 13. Re: script request: switch Presets
                                  jugenjury Level 2
                                  This is kinda what I thought you meant and the outline I just posted would work fine for this.
                                  • 14. Re: script request: switch Presets
                                    Michael L Hale Level 5
                                    Mark, the difference between X's script and Pauls' is X's lists all the presets, Paul's only the tool presets.
                                    You don't have to change the way you name your brush presets. Just change the 7 in Paul's code to 0. Then it will list only brush presets.
                                    • 15. Re: script request: switch Presets
                                      VertexBee Level 1
                                      Yes, that could do the work !
                                      Another way to tell the script which groups to use is to make an action set :
                                      http://www.vertexbee.com/pics/ActionPallete.png
                                      Than whenever you want to put another group you just put in one more action into the action set.
                                      This way such script could be useful not only for switching between groups of brushes (.abr files),
                                      but also for any single tool. For instance you can switch between the brush and eraser tools with
                                      one hotkey. Any given combination is possible - brush, eraser, stamp tool, etc.
                                      Could someone write such script ? PLEASEEEEEEE :)))))))))))))
                                      • 16. Re: script request: switch Presets
                                        Mike, that is pretty much what I was thinking of (although bogged down at work) X's code did appear to me to break the presets down in to all their relative groupings. I was only trying to suggest where I would be looking to for a starting point if I were looking at this…
                                        • 17. Re: script request: switch Presets
                                          This should loop through the loaded brushes.....
                                          N.B. You need to have tool selected that uses brushes.
                                          main();
                                          function main(){
                                          //Reset Custom Options.
                                          //app.eraseCustomOptions( '1ee71ba0-cc95-11df-bd3b-0800200c9a66' ); return;
                                          var Prefs = {};
                                          try{
                                          var desc1 = app.getCustomOptions('1ee71ba0-cc95-11df-bd3b-0800200c9a66');
                                          Prefs = eval(desc1.getString(0));
                                          }catch(e){
                                          Prefs.Brush=1;
                                          Prefs.BrushCount = getBrushCount();
                                          var desc2 = new ActionDescriptor();
                                          desc2.putString(0, Prefs.toSource());
                                          app.putCustomOptions('1ee71ba0-cc95-11df-bd3b-0800200c9a66', desc2, true );
                                          if(Prefs.Brush > Prefs.BrushCount) Prefs.Brush = 1;
                                          selectBrushAtIndex(Number(Prefs.Brush));
                                          Prefs.Brush++;
                                          function getBrushCount(){
                                          var List = List.getObjectValue(0).getList(charIDToTypeID('Nm  '));
                                          return List.count;
                                          function selectBrushAtIndex(index){
                                             var idSlct = charIDToTypeID( "slct" );
                                                 var desc1 = new ActionDescriptor();
                                                 var idNull = charIDToTypeID( "null" );
                                                     var ref1 = new ActionReference();
                                                     var idBrsh = charIDToTypeID( "Brsh" );
                                                     ref1.putIndex( idBrsh, index );
                                                 desc1.putReference( idNull, ref1 );
                                             executeAction( idSlct, desc1, DialogModes.NO );
                                          • 18. Re: script request: switch Presets
                                            I think the OP wants it to loop through the Tool Presets, not the
                                            Brush Presets.
                                            • 19. Re: script request: switch Presets
                                              VertexBee Level 1
                                              I hope the image below does explain the original idea :
                                              http://www.vertexbee.com/pics/vBee_PresetSwitcherExplained.jpg
                                              Paul, great script, although that is not what I tried to explain.
                                              As I wrote in my previous post, is it possible to cycle between actions:
                                              "Another way to tell the script which groups to use is to make an action set :
                                              one hotkey. Any given combination is possible - brush, eraser, stamp tool, etc."
                                              • 20. Re: script request: switch Presets
                                                Some tools are not selectable via an action and might be better to create another script with the tools required, in the mean time would this be any good as it loops through all the abrs?
                                                main();
                                                function main(){
                                                var abrPath = Folder(app.path+"/Presets/Brushes");
                                                var abrFiles = abrPath.getFiles("*.abr");
                                                //app.eraseCustomOptions( '4a01e9f0-cc9f-11df-bd3b-0800200c9a66' ); return;
                                                var Prefs = {};
                                                try{
                                                var desc1 = app.getCustomOptions('4a01e9f0-cc9f-11df-bd3b-0800200c9a66');
                                                }catch(e){
                                                Prefs.ABR=0;
                                                Prefs.ABRCount = abrFiles.length;
                                                app.putCustomOptions('4a01e9f0-cc9f-11df-bd3b-0800200c9a66', desc2, true );
                                                if(Prefs.ABR == Prefs.ABRCount) Prefs.ABR = 0;
                                                loadABR(abrFiles[Number(Prefs.ABR)]);
                                                Prefs.ABR++;
                                                function loadABR(fileName) {
                                                    var desc10 = new ActionDescriptor();
                                                        var ref10 = new ActionReference();
                                                        ref10.putProperty( charIDToTypeID('Prpr'), charIDToTypeID('Brsh') );
                                                        ref10.putEnumerated( charIDToTypeID('capp'), charIDToTypeID('Ordn'), charIDToTypeID('Trgt') );
                                                    desc10.putReference( charIDToTypeID('null'), ref10 );
                                                    desc10.putPath( charIDToTypeID('T   '), new File( fileName) );
                                                    executeAction( charIDToTypeID('setd'), desc10, DialogModes.NO );
                                                • 21. Re: script request: switch Presets
                                                  VertexBee Level 1
                                                  Wow, Paul, 10x !!! That is exactly what I wanted, thank you for the quick responce ))))
                                                  One thing to know , it works fine in CS3 , but fails in CS2
                                                  • 22. Re: script request: switch Presets
                                                    Ah, yes it would fail as it doesn't understand custom option, for CS2 the results would have to be stored in a file, could you please try this with CS2...
                                                    main();
                                                    function main(){
                                                    var PrefFile = new File("~/ABR_Prefs.dat");
                                                    var abrPath = Folder(decodeURI(app.path) + "/Presets/Brushes");
                                                    Prefs = {};
                                                    if(PrefFile.exists){
                                                    PrefFile.open('r');
                                                    Prefs = eval(PrefFile.read());
                                                    PrefFile.close();
                                                    }else{
                                                    Prefs.ABR=0;
                                                    Prefs.ABR++;
                                                    PrefFile.open('w');
                                                    PrefFile.write(Prefs.toSource());
                                                    PrefFile.close();
                                                    • 23. Re: script request: switch Presets
                                                      VertexBee Level 1
                                                      Yep, it works !
                                                      Thank you, Paul
