1 Reply Latest reply on Aug 13, 2006 11:25 AM by Newsgroup_User
    PHP Form...
    Level 7
      Hey gang,
      I have a quote form in which I'm using Javascript to show/hide fields
      depending upon which radio button is selected (e.g., "Yes" or "No").
      Basically, this bit is in the Javascript file that will automatically "hide"
      all of the show/hide fields when the page loads - this way, if Javascript is
      disabled - the user isn't hindered - all fields display:
      function hideOnLoad() //hides listed divs on body load. This is to allow all
      divs to show if JS is turned off.
      changeDiv("currentdomain","none");
      changeDiv("completedate","none");
      Okay - and this is how I'm showing/hiding the optional fields contained in
      either the "currentdomain" div ID or in the "completedate" div ID.
      For "No":
      onclick="changeDiv('currentdomain','none');"
      For "Yes":
      onclick="changeDiv('currentdomain','block');"
      Now, my problem is that when the user submits the form - if there is
      mistakes, all the optional fields they filled out if they selected "Yes" -
      are hidden by the hideOnLoad function.
      How can I tell this to only "hide" them if it's the first time the page has
      loaded, or something to that matter.
      And by-the-way the Javascript function is in an external Javascript (.js)
      file.
      If you need a page to reference, here is the mock page I've been working
      with it on:
      http://www.avenuedesigners.com/quote_mess.php
      There are only two places this is being used, both "Yes" or "No" radio
      button questions.
      Thank you!
      Shane H
      shane@NOSPAMavenuedesigners.com
      Proud GAWDS Member
      http://www.gawds.org/showmember.php?memberid=1495
      Delivering accessible websites to all ...
        • 1. Re: PHP Form...
          Level 7
          SOLVED by myself:
          <?php
          echo '<script type="text/javascript">';
          echo 'function hideOnLoad() {';
          if(isset($_POST['sent'])) {
          if($_POST['havewebsite'] == "yes") {
          echo 'changeDiv("currentdomain","block");';
          else {
          echo 'changeDiv("currentdomain","none");';
          if($_POST['dateyesno'] == "yes") {
          echo 'changeDiv("completedate","block");';
          else {
          echo 'changeDiv("completedate","none");';
          else {
          echo '}';
          echo '</script>';
          Shane H
          Proud GAWDS Member
          "Shane H" <shane@NOSPAMavenuedesigners.com> wrote in message
          news:ebmd57$oug$1@forums.macromedia.com...
          > Hey gang,
          > "hide" all of the show/hide fields when the page loads - this way, if
          > Javascript is disabled - the user isn't hindered - all fields display:
          > all divs to show if JS is turned off.
          > For "No":
          > For "Yes":
          > has loaded, or something to that matter.
          > file.
          > with it on:
          > button questions.
          > Thank you!
          > Shane H
          > Proud GAWDS Member
