3 Replies Latest reply on Sep 29, 2010 9:32 PM by Michael L Hale
    Is there something like the Actions Palette insert menu Item for Scripts?
      The Action Palette has a feature that let you insert steps into actions that can not be recorded.  That means the ScriptListener can not be used to generate script  code for these steps to use the action manager interface.  Is there anything beside making an Action and using doaction(name,set) within a script to pull off the action step in a script.  I would like to make a script that doesn't have to depend on a particular action set being loaded.
        • 1. Re: Is there something like the Actions Palette insert menu Item for Scripts?
          Michael L Hale Level 5
          Xbytor has a script in his xtools that will convert actions to javascript( action manager ). You can use that to get access the code created by imsert menu item.
          Or if you will list the menuItems you want to script either X or I should be able to post the code for you. We both have function libs and we have already converted most of the useful menuItems.
          • 2. Re: Is there something like the Actions Palette insert menu Item for Scripts?
            Yes I forgot about X's ActionFileToJavaScript!  I did not install his whole toolkit I only hack at scripts his stuff ie beyond me. I did extract his tools and had install his utility scripts like ActionFileToJavaScript  it work on the actions I needed to convert  menu items to change display screen mode, fit on screen and zoom, menu place and menu free transform.  Just need to add code to catch the cancel case. Thanks my memory is not what it ise to be...
            • 3. Re: Is there something like the Actions Palette insert menu Item for Scripts?
              Here is how to control the screen.
              imageView ("FtOn");// fit on screen
              imageView ("ActP");// actual pixels
              imageView ("ZmIn");// zoom in
              imageView ("ZmOt");// zoom out
              imageView ("screenModeFullScreen");
              imageView ("screenModeStandard");
              stringIDToTypeID( "screenModeFullScreenWithMenubar" );
              function imageView (view) {
                  desc= new ActionDescriptor();
                      ref = new ActionReference();
                    if (view.length < 5){
                       var viewID = charIDToTypeID( view );
                    }else{
                       var viewID = stringIDToTypeID( view );
                    ref.putEnumerated( charIDToTypeID( "Mn  " ), charIDToTypeID( "MnIt" ), viewID );
                  desc.putReference( charIDToTypeID( "null" ), ref );
                 executeAction( charIDToTypeID( "slct" ), desc, DialogModes.NO );
              Place and transform should appear in the log. But...
              function placeSmartObject(fileRef){
              //create a new smart object  layer using a file
              cTID = function(s) { return app.charIDToTypeID(s); };
                   try {
                        var desc = new ActionDescriptor();
                            desc.putPath( cTID( "null" ), new File( fileRef ) );
                            desc.putEnumerated( cTID( "FTcs" ), cTID( "QCSt" ),cTID( "Qcsa" ));
                            desc.putUnitDouble( cTID( "Wdth" ),cTID( "#Prc" ), 100 );
                            desc.putUnitDouble( cTID( "Hght" ), cTID( "#Prc" ), 100 );
                            desc.putUnitDouble( cTID( "Angl" ), cTID( "#Ang" ), 0 );
                            desc.putBoolean( cTID( "Lnkd" ), true );
                        executeAction( cTID( "Plc " ), desc, DialogModes.NO );
                             //activeDocument.activeLayer.resize(100 ,100,AnchorPosition.MIDDLECENTER);
                             //activeDocument.revealAll();
                    } catch (e) {
                if (!e.toString().match(/Place.+is not currently available/)) {
                    throw e;
              //or
              function placeSmartObject(){// opens the place dialog.
                   try {
                        executeAction( cTID( "Plc " ), desc, DialogModes.ALL );
                    } catch (e) {
                    throw e;
              And for transform
              function transform(){
              try{
                      var ref = new ActionReference();
                      ref.putEnumerated( app.charIDToTypeID('Lyr '), app.charIDToTypeID('Ordn'), app.charIDToTypeID('Trgt') );
                  desc.putReference( app.charIDToTypeID('null'), ref );
                  executeAction( app.charIDToTypeID('Trnf'), desc, DialogModes.ALL );
                  }catch(e){
                if (e.toString().match(/User cancelled/)) {
                     return -1;
                     }else{
                    throw e;
              Transform is harder to convert into a function without a dialog.  Except for simple scale or translate, the values in the log can be different from those entered in the dialog.
