2 Replies Latest reply on Sep 29, 2010 6:57 PM by dr_pompeii
    Confusion about s:TextArea and mx:TextArea
    dr_pompeii Level 1
      Hello Guys
      I am starting to do some experiments with Flex Builder 4, I am a beginner
      I have a huge confusion about the follow
      I can create/insert a mx:Form layout component with FB4.
      when I drag many TextInput controls all work well, I mean, compile and I can interact with the application through a Web Browser (Firefox)
      The problem is when I drag a TextArea then the follow code is generated
      <mx:FormItem label="Label" id="Observaciones">
          <s:TextArea id="idObservaciones"
                      enabled="true"
                      width="260"
                      height="100"
                      maxChars="500"/>
      </mx:FormItem>
      Notice it is a s:TextArea (BTW I have many *s:TextInput* within the mx:Form and work well)
      I can compile without problems, but when I go to Firefox and refresh the page, all stay in blank or white, no error, nothing
      But if I change s to mx
          <m:TextArea id="idObservaciones"
                      enabled="true"
                      width="260"
                      height="100"
                      maxChars="500"/>
      </mx:FormItem>
      I can compile without problems, and when I go to Firefox and refresh the page, all work normal again, I can see all the components
      Why?
      I have read in Flex documentation both types of components
      s:textArea and mx:TextArea
      The mx version said the follow
      While you can use the MX controls in your application, Adobe recommends that you use the Spark controls instead
      OK, I have the follow questions
      1) Why no work s:TextArea within a mx:Form?
      2) Why Spark Control (s) types are recommended against mx?
      3) I did realize that not all mx has a s version, like mx:DateField, then if Spark Control are better, why all the mx has no an equivalent to s?
      Thanks in advanced
        • 1. Re: Confusion about s:TextArea and mx:TextArea
          Flex harUI Adobe Employee
          Don't know why it doesn't work unless you are embedding fonts.  If you hae a
          small test case, post it.
          Spark controls should work with MX and vice-versa, but Spark is the next
          generation of components and is optimized to work well with other Spark
          Components and MX components work better with other MX components.
          Some Spark versions of the MX components have not shipped yet but all MX
          components are scheduled for replacement eventually.
          • 2. Re: Confusion about s:TextArea and mx:TextArea
            dr_pompeii Level 1
            Hello Flex harUI
            Thanks for the reply
            No I dont use that
            The follow experience is very weird.
            I created other simple Flex Project and using the same original code, and work fine,
            yes with the s:TextArea!.
            Yes, two differents projects with the same source code, one fails and the other work fine
            I am totally confused
            And even I did the follow, in the failed project I cutted/moved all the code, compile, and pasted again
            and work now, really wondered about this behavior
            Some idea?
            Ok, I understand that
            • Spark and MX are compatible between them
            • Spark work fine among others Spark components
            • MX work fine among others MX components
            But what is the advantages of this new generation against MX?, thats my point
            Thanks for the advice
            Thanks for your support
            -Manuel
