7 Replies Latest reply on Sep 29, 2010 2:24 PM by JK2075
    Alert Control Popup Message is blank
    JK2075
      I am using Alert control to display a popup message. For some reason message is blank and the label for Ok button is also blank. Popup does come up
      with a blank button. If you click on button then it does go away as it should. Any suggestions?
      Thanks in advance!
        • 1. Re: Alert Control Popup Message is blank
          BhaskerChari Level 4
          Hi JK2075,
          This doesn't resolve your problem..Give some sample code or brief the scenario in which case you are getting the problem. Are you using the Alert control with dynamic text or static text..??
          Bhasker
          • 2. Re: Alert Control Popup Message is blank
            JK2075 Level 1
            Sample of Main.xml - code has been written by someone else so I am having trouble to figure this out. Code does work but any popups or custom popups that are needed come blank.
            <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
                initialize="onAppInitialize()"
                creationComplete="initHttpService()"
                applicationComplete="init()"
                layout="absolute"
                verticalScrollPolicy="off"
                horizontalScrollPolicy="off"
                backgroundAlpha="0"
                xmlns:actionscript="actionscript.*">
            Inside initHttpService function I have Alert on first line...
              private function initHttpService():void
                try
                 Alert("test","test");
                 httpService.url=CONFIG_XML_PATH;
                 httpService.send();
                 httpService.addEventListener(ResultEvent.RESULT, invokeCreationComplete);
                 httpService.addEventListener("fault", httpFault);
                 ExternalInterface.addCallback("startQuestionScreen", startQusetionPages);
                 ExternalInterface.addCallback("openMessageBox", openMessageBox);
                 ExternalInterface.addCallback("gotoOnFirstScreen", gotoOnFirstScreen);
                 ExternalInterface.addCallback("setPrinterInFlex", setPrinter);
                 ExternalInterface.call("setPrinter");
                catch (e:Error)
                 trace("error : " + e.message);
               protected function onAppInitialize():void
                objResourceXML=new ResourceXMLLoader();
                objResourceXML.addEventListener("ResourceXMLLoaded", onResourceLoadComplete);
                objResourceXML.sendLoadRequest("xml/ResourceXML.xml");
               private function init():void
                stage.showDefaultContextMenu=false;
            Thanks!!
            • 3. Re: Alert Control Popup Message is blank
              Hi JK2075,
              The Alert should be Alert.show and not just Alert....and also import the namespace as well..
              import mx.controls.Alert;
              Alert.show("test","test");
              Bhasker
              • 4. Re: Alert Control Popup Message is blank
                JK2075 Level 1
                Sorry...they are there. I did not include all the variables...And yes alert is Alert.show (I mistyped it while copying)
                <mx:Script>
                  <![CDATA[
                   //ALL IMPORT CLASSES AND PACKAGE
                   import mx.controls.Text;
                   import mx.controls.Image;
                   import mx.controls.Label;
                   import mx.controls.Button;
                   import mx.states.SetStyle;
                   import mx.containers.Panel;
                   import mx.managers.PopUpManager;
                   import mx.rpc.events.ResultEvent;
                   import flash.sampler.NewObjectSample;
                   import mx.collections.XMLListCollection;
                   import mx.messaging.management.Attribute;
                   import mx.messaging.channels.StreamingAMFChannel;
                   import FrameComponents.*;
                   import actionscript.*;
                   import actionscript.ResourceLanguage;
                   import actionscript.ResourceXMLLoader;
                   import flash.display.Stage;
                   import flash.system.fscommand;
                   import mx.rpc.events.FaultEvent;
                Thanks!
                • 5. Re: Alert Control Popup Message is blank
                  Hi JK2075,
                  I dont think there is any reason as why such a simple Alert is not appearing correctly. Have you tested with some sample application with an Alert..??
                  Are you using any css for Alert control.??
                  Bhasker
                  • 6. Re: Alert Control Popup Message is blank
                    Flex harUI Adobe Employee
                    If you are using Flex 4.1 and Flex 3 compatibility mode, popups can lose
                    text unless you set layoutDirection='ltr' on the global CSS selector.
                    • 7. Re: Alert Control Popup Message is blank
                      JK2075 Level 1
                      Thanks!! That did the trick. And yes the code was originally in 3.0.
                      Thanks again!!
