4 Replies Latest reply on Sep 29, 2010 2:51 PM by Scaljeri
    extend Image and define rollover effect
    Scaljeri Level 1
      Hi All
      I have a couple of images which should do something on the rollOver event
      So, I thought I create my own class and extend Image, here is what I can think of
      package eu.mysite.utils
         import mx.controls.Image;
         import mx.controls.Alert ;
         public class RollOverImage extends Image
             public var rollOver:String = "this._rollOver()" ;
             public function RollOverImage()
                super() ;
             public function _rollOver():void {
                     mx.controls.Alert.show("ROLLOVER") ;
      And the mxml
      <utils:RollOverImage id="img1" source="..." />
      My RollOverImage doesn't do nothing (I want to see the Alert) when the mouse moves over the image.
      ANy suggestions ?
      cheers
        • 1. Re: extend Image and define rollover effect
          BhaskerChari Level 4
          Replace your as file code with the below one then it will work fine...
             import flash.events.MouseEvent;
             import mx.controls.Alert;
             import mx.controls.Image;;
                     super() ;
                     this.addEventListener(MouseEvent.ROLL_OVER, onMouseRollOver);
               public function onMouseRollOver(event:MouseEvent):void
          Bhasker
          • 2. Re: extend Image and define rollover effect
            Scaljeri Level 1
            thanks a lot!
            One last question
            What do I have to add to this class if I want to use it like
            <utils:RollOverImage specialOption="true" SomeOtherValue="1" ......>
            I thought adding public properties was the trick but isn't, like
                 public var makeSpecial:String ;
                 public var SomeOtherValue:int ;
            Any suggestions ?
            • 3. Re: extend Image and define rollover effect
              You can write set/get methods to acheive that..
                   public var _specialOption:Boolean;
                   public var _someOtherValue:String;
                         super() ;
                   public function set specialOption(bool:Boolean):void
                        _specialOption = bool;
                   public function get specialOption():Boolean
                       return  _specialOption;
                   public function set specialOption(data:String):void
                        _someOtherValue = data;
                   public function get specialOption():String
                        return _someOtherValue;
              Bhasker
              • 4. Re: extend Image and define rollover effect
                Scaljeri Level 1
                great, thanks again!!!
                cheers
