5 Replies Latest reply on Jun 28, 2016 1:25 AM by drone_creative
    Replace Text with Image and Stroke Image
    SoccerGuy3x
      I need to be able to insert an image in place of text in a story and have the image placed with a 1pt black stroke. I had a script that did this for me, but it is very old and it has stopped working with CS5. I managed to cobble together a new script by using stuff in the forums that handles the replacement, but cannot figure out how to adapt it for the stroke. Help!
      Current script:
      if(app.documents.length != 0){
      var myFolder = Folder.selectDialog ('Choose a folder with images');
        if(myFolder != null){
      // reset the Find/Change dialog
      app.findGrepPreferences = app.changeGrepPreferences = null;
      // formulate a grep search string
      app.findGrepPreferences.findWhat = '@.+?@';
      // find all occurrence, last one first
      f = app.activeDocument.findGrep (true);
      for (i = 0; i < f.length; i++)
         // construct file name
         name = f[i].contents.replace (/@/g, '');
         // place the image
         f[i].insertionPoints[0].place (File (myFolder.fsName + '/' + name));
      // delete all @??@ codes
      app.activeDocument.changeGrep()
      else{
         alert('Please open a document and try again.');
        • 1. Re: Replace Text with Image and Stroke Image
          milligramme Level 3
          I tried your code  on InDesign CS4 (not CS5) and changed a little, it works for me.
          When search results replace to the images,
          at first create graphic frame
          And place images instead of  placing image into story directly.
          Fit graphic frame to content.
          Set  stroke weight and color (1pt / Black) to graphic frame.
                  for (i = 0; i < f.length; i++){
                      // place the image
                      var tempRect = f[i].insertionPoints[0].rectangles.add();
                      tempRect.place (File (myFolder.fsName + '/' + name));
                      tempRect.fit(FitOptions.FRAME_TO_CONTENT);
                      tempRect.strokeWeight = "1pt";
                      tempRect.strokeColor = "Black";
              app.activeDocument.changeGrep();
          else{
          mg
          • 2. Re: Replace Text with Image and Stroke Image
            Milligramme (& Soccerguy),
            No need to use this:
            // place the image
            since "place" returns the placed object(s). The possible plural is because "place" always returns an array! (Typically, this will only have one element.)
            This ought to work as well. Untested.
                        var placedObjects = place (File (myFolder.fsName + '/' + name));
                        placedObjects[0].parent.strokeWeight = "1pt";
                        placedObjects[0].parent.strokeColor = "Black";
            The placed object itself is an "Image", so you need to set stroke weight and color for its parent, the containing rectangle.
            • 3. Re: Replace Text with Image and Stroke Image
              milligramme Level 3
              Jongware (& Soccerguy),
              Thank you for your advice.
              your code not works, but it solved with the code below.
                   // place the image
                   var placedObjects = f[i].insertionPoints[0].place (File (myFolder.fsName + '/' + name));
              mg
              • 4. Re: Replace Text with Image and Stroke Image
                SoccerGuy3x Level 1
                Sweet guys! Thanks for the help!
                • 5. Re: Replace Text with Image and Stroke Image
                  drone_creative
                  thanks for sharing this script, it works great, but I couldn't figure out how I could also define a specified height for the placed image frame. Do You have any suggestions for this?
                  Thanks in advance!
