1 Reply Latest reply on Jul 19, 2007 4:07 PM by Steve Butcher
    Can you drag and drop within the same list*?
    Steve Butcher
      *without completely strange things happening?
      It seems like this ought to be fairly straight forward. This code is taken from the Flex 2 Component Explorer and I've just added a few Drag and Drop parameters to the list. It doesn't quite work. The items are duplicated, not selected, selectable. The behavior is a bit erratic.
      It seems very natural to want to be able to re-order a list using drag and drop so it seems like it should be easy. Obviously, I could create a second, empty list--but that would take up valuable screen real estate. I've seen a few posts about this and none of them were answered so either the solution is obvious (please share) or it's impossible (please share).
      Cheers,
      Steve
      <?xml version="1.0"?>
      <!-- Simple example to demonstrate the List Control -->
      <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml">
      <mx:Script>
      <![CDATA[
      [Bindable]
      public var selectedItem:Object;
      </mx:Script>
      <mx:Model id="mystates">
      <states>
      <state label="Alabama" data="AL"/>
      <state label="Alaska" data="AK"/>
      <state label="Arizona" data="AZ"/>
      <state label="Arkansas" data="AR"/>
      <state label="California" data="CA"/>
      <state label="Colorado" data="CO"/>
      <state label="Connecticut" data="CT"/>
      </states>
      </mx:Model>
      <mx:Panel title="List Control Example" height="75%" width="75%"
      paddingTop="10" paddingBottom="10" paddingLeft="10" paddingRight="10">
      <mx:Label text="Select a state to see its abbreviation."/>
      <mx:List id="source" width="100%" color="blue"
      dataProvider="{mystates.state}"
      change="this.selectedItem=List(event.target).selectedItem"
      dragEnabled="true"
      dropEnabled="true"
      dragMoveEnabled="true"/>
      <mx:VBox width="100%">
      <mx:Label text="Selected State: {selectedItem.label}"/>
      <mx:Label text="State abbreviation: {selectedItem.data}"/>
      </mx:VBox>
      </mx:Panel>
      </mx:Application>
        • 1. Re: Can you drag and drop within the same list*?
          Steve Butcher Level 1
          The answer is, yes you can. However, I'm not sure why this makes a difference.
          I added creationComplete="init();" to the application tag. <em>Removed the model</em> and implemented this method:
          public function init(): void {
          source.dataProvider = [
          {label: "Alabama", data: "AL"},
          {label: "Alaska", data: "AK"},
          {label: "Arizona", data: "AZ"},
          {label: "California", data: "CA"},
          {label: "Colorado", data: "CO"},
          {label: "Connecticut", data: "CT"}
          and removed the dataProvider attribute from the List tag.
          Can anyone tell me why the one works and the other doesn't?
